928 Forum 1978-1995
Sponsored by: 928 Specialists
Cheap 996 Turbo wheels at Discount $51
Old 01-30-2008, 08:31 PM
  #121
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,168 Likes on 1,225 Posts
Mine are here, opened two (one had a damage box). The outer lip had a small chip in it. No big deal for the price.
They weight 29bs. At my friends shop is a Champion 18" wheel (set costs $3,000) same size or maybe an inch wider - weighs 18lbs. So for a few thousand less, not bad at all.
Old 01-30-2008, 08:50 PM
  #122
FBIII
FBIII's Avatar
When posting tire sizes that work, it would be helpful to know year of car and on pre 86.5 if your running the original suspension or S4. I imagine a number of people are sitting back waiting to see what works. I know I am.
Old 01-30-2008, 09:56 PM
  #123
Rick Carter
Rick Carter's Avatar
http://wheeldynamics.net/appguide.html
78-85 928
Can use all of the narrow body wheels from 993-986-996-997 50mm -65mm et front and 48mm - 65mm et rear. 1981 to 1984 cars have 21mm spacers in the rear. These can be removed to fit some wide body wheels. (18x10 40mm 18x11 45mm) You may still need to do some fender mods depending on the tire size.
Most extreme fit 18x10 et65mm front and 18x11 et45mm-63mm. The 18x11 et63mm wheel fits nicely on the rear with a 285/30/18 tire. 19"s fit very nicely on the car
928 86-91
Can use all of the narrow body wheels from 993-986-996-997 50mm -65mmet front and 48mm-65mm et rear. Some manual 89gt cars have 17mm spacers in the rear so you may have to chuck them when using wider wheels and tires
Most extreme fit 18x10 et65mm on all four corners. The 18x11 et63mm wheel fits nicely on the rear with a 285/30/18 tire. 19"s are possible
928 GTS Can use all of the narrow body wheels from 993-986-996-997 50mm-65mmet front and 48mm-65mm et rear. Cars have spacers in the rear for the flared fenders. These can be removed to use wide body wheels.
Old 01-30-2008, 10:37 PM
  #124
RngTrtl
RngTrtl's Avatar
I just got mine and am completely happy I can hardly wait until I can get some tires to put on!
Old 01-30-2008, 10:44 PM
  #125
Tom. M
Deleted
Tom. M's Avatar
Ouch...so 44 pounds of added unsprung weight....that's pretty high..but I guess it's the old dollars vs. performance....Let us know how they feel on the track when you get out there.. I'm curious..
later,
Tom
89GT
82 Track Car
Old 01-31-2008, 03:26 AM
  #126
hacker-pschorr
later,
Tom
89GT
82 Track Car
Going from an 8" wide wheel with street tires to 10" wide with R-compounds.....I doubt the wheel weight will make much of a difference
Old 01-31-2008, 03:28 AM
  #127
heinrich
928 Collector
heinrich's Avatar
Nice info Rick but they do forget the wonderful feature of 85/86 cars tnamely the extra space under the fenders in the rear after pulling the factory spacers
78-85 928
928 86-91
Old 01-31-2008, 09:49 AM
  #128
FlyingDog
FlyingDog's Avatar
That's mentioned in the 78-85 part as being 81-84.
Old 01-31-2008, 12:11 PM
  #129
Tom. M
Deleted
Tom. M's Avatar
Maybe in the corners..but in terms of acceleration...I bet you feel it..thats adding a lot on each corner. I'm just curious..I think you will loose some of the snappiness during acceleration...even if you make up for it by going deeper in the corners..
later,
Tom
89GT
82 Track car
Old 01-31-2008, 12:23 PM
  #130
hacker-pschorr
6psi will more than make up for it
The wheels I compared it to is one extreme.
These are only 4lbs heavier then the wheels that are already on the car, 8" wide. I'm not taking off 18lb wheels for 30lb wheels.
The benefits outweigh the negatives in this one.
Old 01-31-2008, 12:35 PM
  #131
Tom. M
Deleted
Tom. M's Avatar
OK..that sounds a little better....Look forward to seeing how they fit on the car....take some pics when you get them mounted.
later,
Tom
89GT
82 Track car
Old 01-31-2008, 12:43 PM
  #132
hacker-pschorr
It's going to be a while since I'm also going to do the upper control arm swap.
Old 01-31-2008, 12:48 PM
  #133
Tom. M
Deleted
Tom. M's Avatar
Doing the S4 upper with older lower? to get more camber?
Later,
Tom
89GT
82 Track Car
  #134
Tom. M
Deleted
Tom. M's Avatar
Later,
Tom
89GT
82 Track Car
Old 01-31-2008, 12:50 PM
  #135
hacker-pschorr
Yup - might as well.
Quick Reply: Cheap 996 Turbo wheels at Discount $51
