Installing an Aftermarket Remote Entry System?
#136
The more features (security/convenience) you add over simple KE, the more wire hacks to the factory harness. That's the main reason for keeping the factory alarm (which includes a crude immobilizer feature), as it minimizes the number of wire taps.
#137
Electron Wrangler
All stock alarm features work exactly the same - you can even open/close disarm/arm with the key in exactly the normal way and can interchange key vs remote at will - the central locks work exactly as stock including the button. Make no connections for alarm or interior lights - on the late models the light controller already does everything you might need. you can connect the KE panic/confirm chirp to the stock alarm horn if you want (usually requires an additional relay).
So ... If it aint broke don't fix it.... & if it is broke - do fix it
(.....rather than replace it with crap you will regret).
Alan
#138
But - if you do that you cannot use the remote lock to close the windows & doors...
Just configuring for short pulses on the KE should be enough. Do also configure for the pulses to last at least as long as you hold the button (some may have a seperate output for this) - this way you can hold the lock button to close the windows/sunroof as with the key in lock mode.
Alan
Alan
My Prestige (Audioxox) unit doesn't support these features, so I used the diodes to isolate the window/sunroof controller.
#139
Electron Wrangler
Hi Alan: Your scheme, although it only uses one SPST relay, involves wiring changes (permanent ground at the hatch motor, rerouting hatch pull wires to different spot on CE panel), so I will probably finish up the current install as I show in the diagram a few posts up, using a DPDT relay. I kinda like not having to cut or move any of the stock wiring at all. Do you see any problems with that scheme?...
One other thing to note here - since the rear hatch key switch contact is now connected to the relay coil (so the remote disables the alarm) - and since this contact engages before the latch actually unlocks mechanically - you only need to turn the key a little and the hatch will start to unlock electrically - rather than mechanically via the key ... neat.
Alan.
#140
Electron Wrangler
Alan
#141
Too late for me. Mine was also <$50. Besides, the one window up at a time feature is too slow for me. I like the minature transmitter that came with my Prestige; less bulky than what I found with other units I looked at.
#142
Under the Lift
Alan
Alan
#143
Under the Lift
I used a KE Commando and didn't like the default settings. Can't remember which they were exactly. I like the Audiovox default settings and their small 3 button remote too. So, the Audiovox is simpler when I install in other cars as there is no change needed to the defaults for users to need to know about.
#144
Looks like you can, but I don't have an OB to examine. If you look at the wiring diagrams, Part VI, it shows a "centrol locking control motor", right and left. It appears they have a yellow wire and a green/black wire that are positive leads rather than grounding, as in the later cars this thread covers. These wires pass through a couple of different connectors where you might intercept them.
http://www.ebay.co.uk/itm/Remote-Key...item53eaa86a06
Ken
80 928 S
5 Speed
UK
#145
928 Collector
Borland, Alan, thank you Guys. If I manage to get my car usable, I'll ask you more questions as I have a great Viper with 2-way I want to integrate gracefully ... my stock system works well.
#146
Under the Lift
.., thanks for that Bill, while I,m on, could you take a look at this kit I saw on ebay and tell me if it would be suitable for my car, looks quite simple (which I like). It,s not all bells and whistles I agree, but after twenty years of turning a key in the lock it would be total luxury .
Ken
80 928 S
5 Speed
UK
Ken
80 928 S
5 Speed
UK
#148
Under the Lift
Well, it doesn't work correctly. Below is my scheme with a DPDT relay.
The doors work, of course. The hatch pops but the motor stops at a point where it won't relatch. The pulse on the remote's option button is not adjustable on the unit I'm using. It's a short pulse for power and ground. Still, I thought the motor cycled the same regardless of how short the switch pulse is. I thought maybe the ground needs to be longer, but even with the doors open, the motor does not complete the cycle. [EDIT: actually it does!]
Also, when I open the doors, sometimes the hatch opens. I don't get that either. It's as if opening the doors provides ground [EDIT: It is.], but where is the power coming from [EDIT: the red wire on the motor, dummy. The yellow wire is just initiates the cycle.] I am enamored with this scheme as there are no wire cuts or swaps, but it's not working. Any ideas?
#149
Electron Wrangler
Bill - does a double unlock click operate the 3rd channel hatch release - try that quite deliberately? Whe you say opening the doors triggets the hatch - do you mean unlocking remotely (or actually 'opening' manually)...
If yes - it may be configurable to NOT do that.
I think it sounds like the grounding pulse at the motor needs to last long enough to pop the hatch (and enable the interior lights) - to complete the parking cycle. Sounds like it won't work that way unless you can configure for a longer pulse... does
However what you says makes me wonder - does the hatch pull work normally still? is it just the KE that doesn't work. Does the hatch open trigger the interior lights?
Are you sure you have the grounding to the lights connected correctly - do the interior lights trigger as expected by
hatch release?
Alan
hatch release?
Alan
#150
Under the Lift
Hi Alan:
Thanks for trying to help me sort through this.
This is not a KE unit - it's Audiovox. I think I do have a KE for backup. The Audiovox is very simple and the door open/close pulse is not configurable.
I went out an re-examined what was happeneing and now it all makes sense. My report above was not quite right and it is now clear that the ground pulse is too short, so the remote hatch pop fails to run the full cycle. The remote will operate the hatch perfectly IF the side door is open, in which case the door pin provdes the needed ground. Also, if I open a door after operating the hatch with the remote, it finishes the cycle.
Studying the wiring diagrams some more, I see the front door pins are the only ones providing ground to the hatch. So, even though the hatch pin switch also trips and the interior lights go on, that does not provide ground to the hatch motor. I see a few posts back you did some swapping with the interior light circuit. Maybe that's another way to get ground to the hatch motor, so once the hatch pops it has ground until the interior lights go out.
