No longer in denial, engine is coming out! Refurbishing the heads.
OK, after being in denial for almost 18 months, I am giving in to the inevitable. I am pulling the engine in the Red Witch.
The last set of replies to my thread of replacing the cam chains and tensioner pads pushed me over the tipping point.
You guys are right, I am already at that point. Go ahead and pull the engine and do the head gaskets.
As such, I am documenting all further engine and accessory work in this thread. I am redirecting all these threads to here:
https://rennlist.com/forums/928-foru...ts-for-s3.html
https://rennlist.com/forums/928-foru...s-as-well.html
https://rennlist.com/forums/928-foru...breathing.html
https://rennlist.com/forums/928-foru...t-45-btdc.html
https://rennlist.com/forums/928-foru...ing-strap.html
https://rennlist.com/forums/928-foru...tube-ends.html
https://rennlist.com/forums/928-foru...a-blink-r.html
https://rennlist.com/forums/928-foru...t-housing.html
https://rennlist.com/forums/928-foru...questions.html
https://rennlist.com/forums/928-foru...ter-necks.html
https://rennlist.com/forums/928-foru...turn-line.html
https://rennlist.com/forums/928-foru...r-replace.html
https://rennlist.com/forums/928-foru...ming-belt.html
https://rennlist.com/forums/928-foru...32v-s-3-a.html
https://rennlist.com/forums/928-foru...n-testing.html
https://rennlist.com/forums/928-foru...er-refurb.html
https://rennlist.com/forums/928-foru...-balancer.html
https://rennlist.com/forums/928-foru...-and-ends.html
https://rennlist.com/forums/928-foru...cam-gears.html
Stay tuned...
Stay tuned...
You've made your decision, and that's good, but let me give you a warning. Facebook reminded me the other day that I pulled my engine 2 years ago, and it's still in pieces in my basement.
Head gaskets, gorgeous. Heads, gorgeous. Cylinder bores, perfect. I kept digging deeper and deeper to find something wrong to justify the project, and literally the entire engine got disassembled. I did find some wear on the #1 main bearing, suspected from the damper issues, but I'm well over the purchase price of my car into parts on a project that started with an intake refresh that should have stayed an intake refresh.
Hello, my name is Jeremy and I'm a WYAIT-aholic.
scoper (10-06-2020)
Hi, Jeremy. My name is Seth. I too am a WYAIT-aholic. The Red Witch has been off the road for 15 months, and likely will not be back on for many more.
I have double the purchase price of the Red Witch in her for parts and repairs. This is before doing the heads...
You bring up a very good point. I am hoping this is as far as I need to go with the engine. I don't see the need to split the girdle and replace the main bearings. Going by a post from Greg Brown some time ago, and I am paraphrasing here, rod bearings can be an issue, but main bearings go for a long time... I am hoping to leave mine alone.
I have done:
-rod bearings and nuts
-new ATI Superdamper
-new Laso water pump
-fully rebuilt tensioner and all rollers, bushings, etc...that go with that
-new Gates timing belt
-new oil pump
-new front crank seal
-cam, crank, and oil pump belt sprockets look good
Am doing:
-replacing cam chains
-replacing tensioner pads
-replacing ALL seals associated with the above
-full intake refresh with all hoses, ISV, TPS, etc...
-GB fuel lines
-new fuel dampers, new higher pressure 88+ fuel pressure regulator
-Porken S300s chips for LH and EZF
-4-hole Design III fuel injectors
-replaced bearings and seals in the throttle body
-rebuilt MAF
-new CPS
-replacing all the connectors on the fuel injector harness
-new 12-pin harness from Sean Ratts
-full ignition refresh, including amplifier modules
-rebuilt alternator
-refurbished starter
-silicone oil pan gasket
-Volvo motor mounts
I am hoping that covers it for the engine. I have done/am doing a bunch more work on the front suspension, steering, drive line, all brakes, and fuel system on the Red Witch.
Sooner or later, I will be done.
I have done:
-new oil pump
Am doing:
-GB fuel lines
-rebuilt MAF
-new CPS
-rebuilt alternator
-Volvo motor mounts
Alright, if I am doing this, I am doing this right.
I have understood from Rennlist that the head gaskets are a weak point in all 928 engines, 16 and 32V. Rare is the 928 that had proper, regular coolant changes.
So, there are two camps: those who HAVE replaced the head gaskets, and those who ARE going to replace the head gaskets. I had hoped to be in the latter category for awhile. I was going to try to wait until a supposed better time. Hence, now I am in the former category.
Here is my plan:
-pull the engine
-pull the heads
-remove all core and threaded plugs from the heads
-deliver the heads to my machinist for disassembly and close inspection
I will expect/want the following to happen
clean and weld pitting in head decks
weld and resurface head decks
replace valve guides
proper valve job
reassembly of heads with new valve stem seals
Note: the head work will happen in stages as I have money available. It is what it is.
-thoroughly inspect all 20 head studs for corrosion or damage. If one is bad, they are all bad and must be replaced.
-remove piston/rod assemblies
-remove pistons from rods, clean pistons CAREFULLY
-use boxes of single edged razor blades to clean crankcase deck and cylinder bore surfaces
-thoroughly clean inside and outside of engine
-deburr oil return galleries down the crankcase and girdle
-reassemble pistons to rods with new pin clips
-reinstall piston/rods to block with new rings
-reinstall completed heads
-pick up where I left off with cams, chains, tensioners, timing belt, etc...
I am thinking I will NOT install the accessories or intake parts until after the engine is mounted back into the engine bay. I think it will be easier that way. I think.
Since I am going all in, I am going to rebuild the torque tube and replace the torque converter bearings and input seal.
Please follow this thread for that info:
https://rennlist.com/forums/928-foru...ion-wyait.html
If you remember, I have a front torque tube bearing that has migrated. Perfect time to deal with that with the engine out...
Plenty more to follow! I EXPECT your opinions, advice, ideas, insults, etc...as I do this project. I have researched it, but am making this up as I go.
Here is my plan:
-pull the engine
-pull the heads
proper valve job
I have started this off by reading Hans' thread on engine stand adapters for the 928:
https://rennlist.com/forums/928-foru...-adapters.html
I went with his suggestion of the Jeg's rebranded Sunnex engine stand. I ordered it, a drip pan, and a thick poly engine bag.
I spent today cleaning up my workshop. I moved alot of large items and projects to my storage bay in town. The 72 Honda CT70 with the Lifan 124 will have to wait a little longer...
I want to have plenty of room to work on the engine around the stand. As well, I want plenty of shelf space to store parts as they come off.
My next step is to release the front pinch clamp assembly from the drive shaft and flexplate, then start loosening the bellhousing bolts one by one. I want to break them loose, then snug them back up. Less stress when I go to actually pull the engine.
I hope to see the engine stand sometime this week. Unfortunately, I have some work and other commitments this week. So, no real work until next week.
We shall go from there...
Damn, son - you are becoming the Doug Bray of the 928 community.
Time to start your own discussion forum!
On second thought, even Bray wasn't this huge of a post *****.
Jackhole.
Jackhole.
Ouch. Dammit boy. I am assuming I am to take that as an insult?
If you are referring to the sh*tload of linked threads, I was asked to consolidate alot of them. Make it easier to follow. I thought it was a good idea.
scoper (10-06-2020)
Hi, Jeremy, Seth. My name is Scott. I too am a WYAIT-aholic.
What started out as an intake refresh now has the sump, air con and the entire front suspension removed for painting, powder coating and 'zincing'.
For someone who's as concerned with descriptive post titles, Randy, it's surprising you're upset as you are about someone linking to where updates to open-ended threads are going to be updated. It makes the data integrity so much stronger for future searchers.
I guess you might be upset that you won't be able to chastise someone for necroposting in 3 or 4 years when they bring up those threads and ask if there were any updates...
