Wilson's thread
Old 08-31-2015, 05:15 PM
  #331
Noahs944
Noahs944's Avatar
Used wobble extension to get to the back lower bolt.
Old 09-01-2015, 12:17 PM
  #332
Noahs944
Noahs944's Avatar
I could use some help here for my 88 2.5 n/a vacuum routing please.
On the Jboot "Y" pipe & elbow pipe. What hoses go to them?
Old 09-01-2015, 12:42 PM
  #333
V2Rocket
Rainman
V2Rocket's Avatar
elbow pipe connects the AOS hose to the J boot on the left side of the throttle body
"Y" plugs into the bottom of the J boot after the AFM, one leg goes to the idle air valve under the intake manifold, the other leg goes to the "Y" venturi pipe the brake booster hose connects to
Old 09-01-2015, 02:06 PM
  #334
Noahs944
Noahs944's Avatar
THAT HELPS my brother! Mucho gracias.
Studying exhaust scavenging crank case systems & air oil separator systems. Better for the engine (and "free" power). http://www.motoiq.com/MagazineArticl...a-edition.aspx
Old 09-01-2015, 08:23 PM
  #335
Noahs944
Noahs944's Avatar
Decided to JUST MAKE DAMN SURE the factory crank case like is CLEAR. It is & I can see clearly that it is not squished like it was before. Also ran the idle air solenoid properly this time.
I have learned to respect the air management system.
So far today:
-Installed brand new timing belt, set the timing
-sorted the vacuum lines
-installed the timing cover I bought from Van the man Svenson
-Distributor & wires are in place
Left to do:
-AFM/air box install
-fabricate an anchor point for the alternator belt tensioner (I just noticed the oem one in no more since I deleted the lower balance shaft)
-tighten & torque lugnuts/check air pressure
-add some extra mounts to the exhaust
THEN WILSON WILL BE BACK ON THE ROAD.
Old 09-01-2015, 08:34 PM
  #336
V2Rocket
Rainman
V2Rocket's Avatar
What size are your rectangular headlights?
Old 09-01-2015, 09:35 PM
  #337
Noahs944
Noahs944's Avatar
4x6" I think.
Old 09-02-2015, 12:13 AM
  #338
Noahs944
Noahs944's Avatar
Well the under side has never been so clean:
Here's the custom belt tensioner, simply swung the rod the opposite direction & noticed a robust chassis mount. Took a chunk of steel, drilled a couple of holes after bending it the torch & a hammer. shortened the rod length maybe 6 rotations. Solid.
After patting myself on the back for doing an honest days work I realized I forgot to install the stainless timing belt skid plate thing. Darn.
Old 09-02-2015, 10:17 AM
  #339
V2Rocket
Rainman
V2Rocket's Avatar
no no no!
not unless you have solid metal motor mounts.
the engine moves around a lot and the tensioner needs to be attached to the engine assembly somewhere...mounted to the chassis with non-solid mounts, the first good torque will break something!
easier/better would be to make a strong tab stick down from your lower front-balance-shaft-delete plate for the tensioner rod to be positioned like originally.
Old 09-02-2015, 10:39 AM
  #340
Per vers
Per vers's Avatar
Maybe something like this
Old 09-02-2015, 11:02 AM
  #341
V2Rocket
Rainman
V2Rocket's Avatar
^^^^^^ PERFECT
though perhaps a bit overkill...that is some thick metal !
Old 09-02-2015, 11:24 AM
  #342
Noahs944
Noahs944's Avatar
Thank you guys. You know I thought of that and my mind drifted. Wasted an hour last night. GOOD CATCH V2. Thanks for the photos Per.
-Skid plate now installed under the cover.
-heat shields on near motor mount & cooler.
-schemed exhaust mounts.
Re-engineering the belt tensioner. Should have made it engine mounted not chassis mounted. Duh!
Old 09-02-2015, 01:07 PM
  #343
Noahs944
Noahs944's Avatar
DONE!
Old 09-02-2015, 01:16 PM
  #344
V2Rocket
Rainman
V2Rocket's Avatar
Old 09-02-2015, 02:57 PM
  #345
Per vers
Per vers's Avatar
Hello Spencer and Noah.
The bracket is made of 10 mm. alu. And have a weight of 100 gram.
One of the best thing with the balance shaft delete, is that you can make a cam belt change in 20 minutes ;-)
Quick Reply: Wilson's thread
