N-Tune
#451
#454
Small Business Partner
No-change at the moment... I think I will test the 951 intake first.
#455
Ah, the eternal joys of living so far away from my suppliers
*twiddles thumbs*
Really looking forward to my MAF + Cam key.
I'll be getting a dyno after I finish my rebuild, then again with the MAF And offset key in. Should be interesting to see how close to original power I get after a rebuild, then how much more I gain after the chip and key.
*twiddles thumbs*
#456
*twiddles thumbs*
*twiddles thumbs*
#457
Hey this might be the exact thing I need for my build! Engine management is on the back end of my callaway turbo swap, but this seems like it would fit the bill! Instead of the 5th injector callaway ran, I am going to use larger injectors and a stand-alone management system with a MAF. That barn door is not staying! I am at the beginning of the build so working this out will come later, but we can converse and come up with a plan. Im looking at about 310-340hp range. I see you have it up to 200rwhp but have some options?
#460
Yep! After seeing, and feeling how much of an improvement advancing the cam made for my 944NA, I went out and advanced the cam in my 951 ~3° (I have a true adjustable cam-gear on the 951). The improvement was definitely noticeable - better power down-low, turbo spools quicker, and the car is just more friendly to drive.
#461
Wouldn't advancing the cam (normally) increase low torque but with the expense of reduced top end power? Noted it is better on the NA, but perhaps it reduces power on the 951 at peak rpm?
#463
Cool! Yep, good timing!
