GT4 RS Driving Impressions
#706
No.
Changing ride heights doesn’t change F/R static weight distribution, but it changes L/R static weight distribution at each axle, because a car has four wheels, not three. When you corner balance, you are effectively making sure L/R distribution is equal.
Changing rake has effects on the dynamic load distribution, and therefore the handling, not the static weight distribution between axles.
#707
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,366 Likes
The static weight distribution between the F and R axles is determined by location of the CG of the car (viewed in plan) relative to the axle locations. That is not affected by the rake. This is simple statics.
#708
No, it won’t change static weight at the rear axle. But it will change the aero effects and handling of the car.
#709
No. The quote you gave pertains to lateral load, not gravitational weight.
I love this forum. If you don't know something or get it sightly wrong, someone else can set the record straight, and we all learn more from each other.
I have a table from Porsche Motorsports that shows all the affects of changing ride heights. I will post later when I am at home.
#711
As promised, here are some monographs from Porsche Motorsports for the 718 GT4 Clubsport. The Clubsport rides lower than the street 4 RS, but these numbers should be relatively comparable between the cars to give you an idea of what is happening.
Affect of front shim in camber
Affect of shim on rear camber.
Affect varying rake on overall downforce and front to rear ratio of downforce.
So on the GT4 RS, raising the rear by 5mm increases total downforce by 1.1% x 488 pounds or 5.4 pounds and a 10mm raise increases it by 9.3 pounds. The interesting part is that the 5mm increase in rake then sends 1.6% more of that 493 pounds or 8 pounds to the front. With a 10mm raise in rake 3.8% more of 493 pounds or 19 pounds goes to the front. To put that into perspective, the spoiler extensions and canards from Silver Rocket add about 23 pounds of front end downforce. So you can see that adding a lot of rake can have significant affects on the front downforce and the overall balance of the car. If you will notice, Manthey adds a lot of rake to the GT4 and 4RS as compared to the generally understeering OEM setup in order to help the front end work better .
#712
Always a comparison.....cant you just enjoy the 4RS without bad mouthing the 992 gt3. They are both unique experiences in a perfect world own both. They each. have their strengths and weakness no one car is perfect.
#713
#714
His opinion is the 4RS is more fun to drive, deal with it :-), he is not bad mouthing anything just voicing an opinion. People do get touchy.
Same reason I own one and I have 4 Porkers but I don't want a 992 GT3, that does not make it a bad car, I just don't want one either, the thread is called driving impressions of the 4RS, so the best car to compare it with is a 992 GT3 or the 991.2 RS as they are all about the same money atm.
The following 3 users liked this post by 168glhs1986:
#716
#717
TOporschefan (04-27-2024)
#718
The 992GT3 especially a Manual is so different to a 4RS in the way they drive that it makes no sense to compare them using the same parameters. Ideally you would have both in the garage and just drive the one depending on what mood you're in on that particular day. A 992GT3 Touring Manual makes a perfect pairing with a 4RS imo.
#719
I've done a lot of car comparisons. That can be useful to understand the differences and similarities of cars. But ultimately, I've moved towards the view that car comparison can be counterproductive, because it can make one approach a car very analytically and reductionistically. Instead, I find it better to just drive and experience a car in the moment, trying to holistically appreciate the unique recipe which makes the car what it is. If I'm eating steak in a restaurant, I savor and enjoy the steak as I'm eating it, and don't find myself comparing it to lobster or salmon.
#720
I have 4 atm but all different. I daily a GTS, I have a 997 for slower fun and it's just cool, I have my Spyder for sunny days(so it never gets used) and the 4RS for track and blats. A touring don't fit anywhere, it's also **** at touring , I would take my GTS ! very over rated cars esp as you pay more than a GT3 for one ! imho.
