718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Engine Ticking Noise
Old 06-27-2022, 01:05 PM
  #181
Westcoast
Westcoast's Avatar
Received 4,693 Likes on 2,731 Posts
Originally Posted by brades
I wonder if the oil is the issue? I was topping my oil up with 5w40 C40 as I couldn't find the 0w40 C40. The ticking didn't seem too bad... but I've since found 0w40 C40 and added about half a quart and the ticking is more noticeable now. I can't see a half quart of oil changing it but who knows?
Oh yes, I like this, thicker oil... at least in 2020 5W-40 is a specified weight, I may need to try this!
Old 06-30-2022, 02:14 AM
  #182
alwayscruzin
2nd Gear
alwayscruzin's Avatar
Originally Posted by colnagoG60
Do you drive your car regularly, or let it sit for a few days at a time? I noticed issue on my 981 over a year ago...experienced the noise, and it then going away during drive after it sitting during the week, as I've been driving the car less and less during my ownership
I've been driving it just about every 2 out of 3 days since I got it, so regularly enough. Even so, today I did try out that trick you posted there, but unsurprisingly didn't seem to make a difference.
Still anxiously waiting for an update from SPYDERJAILA.
Old 06-30-2022, 07:30 AM
  #183
h_4711
h_4711's Avatar
There are several kinds of ticking to be differed :
(1) The very common idle speed ticking - that does not disappear but even increase when the engine is heated up - but sometimes decreases after some thousend miles and could become quieter with higher oil viscosity. There are numerous posts, soundfiles and videoclips about this ticking and its reasons.
(2) Ticking occuring after start of a cold engine, when the car was not used for some days. Principly this ticking is related to all engines with hydraulic lifters and is caused by a necessary drain of oil included in the lifters of the valves open during the time the engine was stopped. This effect is described in detail in
https://www.718forum.com/threads/dis...d-start.25277/ Post #18
The ticking is absolutely normal and should disappear after a short period of time just by driving.
To fill the lifters by revving at 3000 rpm, when the car is standing (like in the videoclip with the BMW), is a little bit silly : you waste gasoline and generate a useless enviromental pollution.
(3) Other Ticks : ticking of SPYDERJAILA's car matches neither (1) nor (2) : It is not audible at idle speed and it does not disappear with a warmed up engine. Moreover it has another frequency than the
idle speed ticking (1). We have to wait and see what happens with his car.
If you post a soundfile of your car I could analyze incidence and frequency of the ticking.
Richardkun (07-20-2022)
Old 06-30-2022, 07:41 AM
  #184
doug751
doug751's Avatar
Market is good for these cars. I suggest you sell and buy something that does not tick. Good luck.
Old 06-30-2022, 10:31 AM
  #185
colnagoG60
colnagoG60's Avatar
Received 1,275 Likes on 797 Posts
Roger that. However I'd wager that the response will be, "no problem found"...or, "loose header bolts", like I also had.
Old 06-30-2022, 11:12 AM
  #186
X2Board
X2Board's Avatar
Originally Posted by 348SStb
Original poster and commentators,
Is this the noise you are talking about?
https://www.dropbox.com/sh/47m7nxnsb...oY730bQHa?dl=0
Wow! That sounds a lot like my X5 Diesel.
Old 06-30-2022, 11:56 AM
  #187
brades
brades's Avatar
Here's a couple of audio clips of mine. It ticks at idle and then stops around 1100rpm and then starts ticking again louder at 1900 rpm.
*edit* converted to .mp3 files
https://drive.google.com/file/d/17eV...Eymlng12n/view
https://drive.google.com/file/d/17eT...fHVRTltOw/view
File Type: mp3
File Type: mp3
Old 06-30-2022, 12:17 PM
  #188
SpyderSenseOC
SpyderSenseOC's Avatar
Received 1,343 Likes on 805 Posts
https://drive.google.com/file/d/17dcbN0PzKVujhiEBECsFdi8DcJRMzFSO/view?usp=sharing
https://drive.google.com/file/d/17eSpcYeaZn7-CLuR-81ZPvBNwNgQuWr-/view?usp=sharing
My computer cannot access those videos.
Old 06-30-2022, 12:21 PM
  #189
brades
brades's Avatar
delete
Old 06-30-2022, 12:24 PM
  #190
brades
brades's Avatar
Try this https://drive.google.com/file/d/17eT...fHVRTltOw/view
Old 06-30-2022, 12:46 PM
  #191
brades
brades's Avatar
I sent the sound clips to Porsche Orlando and this is what they said
"I just had our Master tech listen and he told me the direct injectors can make that noise especially when the vehicle has not warmed up. Its nothing to worry about all normal."
Old 06-30-2022, 01:20 PM
  #192
UncleDude
UncleDude's Avatar
Received 5,429 Likes on 2,225 Posts
Mine still ticks like a ****, but it is not as prevalent warmed up. I especially notice this coming home after a drive versus when I leave.
Old 06-30-2022, 02:59 PM
  #193
h_4711
h_4711's Avatar
Is there anybody who can tell me, how the engines temperature could affect the loudness of ticking piezo injectors ?
Meanwhile I'm more bothered about these b***s*** statements than about the ticking itself.
Old 06-30-2022, 03:41 PM
  #194
SpyderSenseOC
My brand new Spyder makes the exact same noise. 150 miles on it. And I can make it come and go by giving the throttle some blips. It almost sounds exhaust related to me, like the flappers are rattling around.
Old 06-30-2022, 04:03 PM
  #195
brades
brades's Avatar
​​​​​​​Mine did it with the stock exhaust and with the Kline exhaust.
SpyderSenseOC (06-30-2022)
Quick Reply: Engine Ticking Noise
