Has anyone found an exhaust solution they absolutely love?
#541
Did you install your SOUL OAP's and valved exhaust yourself, or have a shop do the work? I've watched a few videos on the SOUL install and other than the studs it doesn't sound terribly difficult. Famous last words...I know...
Same question regarding your Cargraphic exhaust valve controller...did you install it?
EDITED: I don't see a SOUL ceramic coated option for the 718 Spyder...just the basic SS OAP option. Am I missing something??
https://www.instagram.com/slickxac/
jimdillard (02-08-2022)
#542
#543
Acquired my 2021 PDK GT4 with 2k miles on it, added SOUL OAP, and now at 10k miles, it’s beyond glorious how it sounds, about 3k rpm it starts to howl and shifting about 5-6k rpm, it makes an awesome growl/pop sound, hard to describe sound, and I swear the sound it makes has gotten better and better the longer I drive it. Don’t need anything else.
ps, I did add titanium heat wrap
#545
https://911maniac.com/kline/
Jeff
The following 2 users liked this post by Jeff Jones:
jimdillard (02-08-2022),
Soul Performance (02-08-2022)
#546
I did a pretty detailed write-up about installing my Kline exhaust if you want a good sense of what is involved. Soul should be very similar.
Jeff
Jeff
The following 2 users liked this post by tdlondon:
Jeff Jones (02-08-2022),
#547
Thanks very much for both of your responses above. Greatly appreciated! Short of a lift...I'm well equipped with about 50 years worth of tools and at least fairly mechanically inclined. Did you separate the OEM OAP's and OEM exhaust during removal...or is it possible to remove them still attached as one unit once the OEM OAP's are separated from the headers? My only concern is separating the OEM OAP and OEM exhaust because of the OEM OAP stud removal issue. That can sometimes get dicy. I'm aware of the "double nut" stud removal technique...BUT...
#548
Very cool walkthrough! I did mine alone. It's possible but taking the rear box out and the kline thing in are the toughest part. I also support it with something on a jack tray and hold it sort of in place with the 2 hangers and the nuts with a few hand turns. Then clear to find the right angle to align to the OAP. BUt definitely much easier with 2-3 ppl. You mention being careful with the ceramic rotors while removing/installing the wheels, a good tip is using a wheel hanger pin set / pilot pin. Costs $20 on Amazon. You screw them on the wheel hub after removing 2 lug nuts and slide the wheels on them far enough to clear the rotors.
#549
Jeff
Jeff
The following 2 users liked this post by jimdillard:
vrae2009 (02-08-2022)
#550
Basic Sponsor
Jeff
Jeff
Dave @ SOUL
SOUL PERFORMANCE PRODUCTS
Quality Exhaust Solutions, Fair Pricing, and Outstanding Service
John Gaydos- Owner, Performance Specialist
Cell - (484) 883-6197
johng@soulpp.com
Jon Wheel - Marketing Manager
jwheel@soulpp.com
![](https://rennlist.com/forums/signaturepics/sigpic191275_4.gif)
johng@soulpp.com
jwheel@soulpp.com
#551
#552
Thanks for the kind words on the write-up, we had a blast working on this as a family. I hope it helps someone else going down the DIY route.
#553
#554
I don't remember any issues between the muffler and the opf but I had 50% of the studs come out of the cat to opf connection. It freaked me out at first and slowed me down but in the end, it all went back together pretty easily. I hope I managed to secure the studs well enough but that is pretty easy to check on anytime the wheels are off.
#555
Thank you Jeff Jones and Westcoast. Wishful thinking on my part! Again, I appreciate all your help. So...I'm wondering if maybe this isn't a great excuse to convince my wife we need to get a lift system installed in our garage. I mean how else could you possibly remove an exhaust system without a lift system. It just can't be done. That's my story and I'm sticking with it!
The following 3 users liked this post by jimdillard:
