C40 Oil Discussion
#541
Regardless of the oil type discussion,you are still getting recycled oil from a barrel,that uses a gasoline pump style nozzle. Always a better experience at a local Porsche passionate indy or doing it yourself...
Paiceyfan (05-24-2022)
#542
Thanks Halfmonkey...useful information...my nearest dealer is 80 miles away, but if I am passing in the future, worth noting...
Oh, by the way...when I picked up the car, I asked for a quart to take with me and they charged me for it...no kidding...
#543
Giving away free oil probably isn't standard procedure no matter how inexpensive a quart is compared to everything else Porsche so I wouldn't use my scenario as standard operating procedure but adding a little bit of oil if you get in the red I believe is something most if not all dealers are willing to do as a courtesy. At least this is what Porsche Monterey said to me and I believe my local servicing dealer said too if I ever needed a little bit of oil.
#544
#546
Originally Posted by Bill Mitchell
I'm sorry, I don't get your point. Some dealers, usually larger ones, have bulk oil tanks that dispense the oil through a special nozzle that counts the quantity as it flows through. But the oil is not "recycled " as you state. It is delivered by a bulk oil truck into their storage tank. They get the oil they order. Now if you're saying it will be A40 and not C40, that is possible since C40 is still a small part of the mix for most dealers. However, if they are responsible they will either use quart bottles of the correct grade, or get another tank and pump system for the C40 (if it's available in bulk, might not be yet). But recycled? Nope. BTW, I was an oil/gasoline/fuels distributor for almost 40 years.
#547
I'm not saying there aren't unscrupulous oil change places, but they are much fewer than in the past. And as for a Porsche dealer doing this, I highly doubt it, they have too much at stake to risk putting substandard oil in customer cars they are responsible for. Recycled oil is almost a thing of the past now too. Sure, do your due diligence wherever you get your oil changed, just as where you have any work done on your car, I think most of us are pretty careful about that, but beyond getting the wrong grade my biggest worry would be the lowest paid, newest employee in the shop doing the oil change and not tightening the drain plug. That's one reason I've always done my own changes. But even that is unlikely since a dealer being responsible for shoddy work would be subject to multiple, mega-buckks lawsuits.
#548
Well,you can bet all your money that " the new guy " is doing the oil change in your expensive Porsche. They are called " lube techs " and they work in the " express lane ". That's all they do : oil changes and rotating tires. All dealers have them,including Porsche. Everyone has to start somewhere,I'm not here to bash them,but bear in mind that they do exist. And btw,it's not only about not tightening your drain plug,but about over filling/under filling(these cars don't have a dipstick and they do not show the oil level until fully warmed up). Sure,you can use the PIWIS 2 to read the oil level information off the oil level sensor,but I highly doubt a lube tech is going to do that. Also,some of these cars have 2 or multiple drain plugs,do they drain them all? Do they replace the washers? Do they torque them properly?
So my whole point is : people have been talking for pages and pages about C40/A40 spec,about oil brands etc...and in the end most will go to the dealer and pay ridiculous amounts of money for subpar service...not even knowing that the oil being put in their car comes from a drum barrel. And yes,the dealer might even give you a nice bottle of Mobil 1,I have even seen something as ridiculous as giving it to you in a special oil quart Mobil 1 pouch...
#549
^^^ At my Porsche dealer the servicing tech is the same guy that changes the oil in my car, a Gold Miester Porsche certified technician, maybe you need to find a better dealer?
#550
#551
Keep in mind, at least at my dealer when requesting a certified gold technician, you'll be charged more for labor rates.
#552
Haven't seen this posted yet. Straight from the horses mouth.
#553
@2XIPA Thanks for sharing, was this a brochure you got from the dealer? I would like to get a complete copy of it.
Regarding the 718, it is interesting to see the MY2019/MY2020 viscosity recommendations and the MY2021 and on separated out!
#554
