Kline 718 GT4/Spyder exhaust
#616
#618
I have the 200 cell as well now (+ exhaust and oap all Kline inconel) for a few thousand miles and I am really starting to feel a difference. Noticeable improvement. Would be hard going back from a sound and power perspective. Highly recommended.
#619
I already installed the previous Kline valve controller so I'll wait until I get the new package with some additional instructions before deciding if I DIY or get some help. Along those lines...
I'm going to install the Kline setup myself...making it a family affair actually. I'm very far from a pro mechanic but as I said, I managed to do the controller install easily enough. I've seen a few exhaust install videos and the Febspeed video seems to be the most detailed, talking about torque specs, etc.
If you are aware of any other great exhaust install videos where they talk specifics, more than just show you a video montage, I would appreciate any links you have. I've googled and found what I can and it seems pretty straight forward. Any other tips for the Kline setup specifically would be appreciated. Given how popular this exhaust is, I'm surprised there isn't a video out there already. Thanks!
2XIPA (01-13-2022)
#620
Another question for anyone that has the Kline valve controller. How is it supposed to work?
I was expecting valves open all the time regardless of PSE button state when the Kline button is blue. Totally overriding PSE. If that is the case, mine isn’t working.
I was testing it out and my PSE button still opens the valves as expected. I can hear the valves open/close and I can hear the exhaust note change. The Kline button seems to do nothing at idle. It does not cause the valves to open or close when activated.
PSE off and the Kline button doesn’t seem to do anything to the valves or exhaust note. On or off is identical.
Perhaps PSE needs to be on AND the Kline button needs to be on for it to keep the valves open? I’m not sure I tested that state as well as I should have but I didn’t think I heard a big difference.
Any help to clarify how it should be working is appreciated. It could be user error on my side or I guess there is a chance mine just doesn’t work.
Thanks,
Jeff
Thanks,
Jeff
flynlo (01-14-2022)
#622
So, based on the review below, I am very interested in buying a Kline exhaust. I would like exactly what he says he got -- not super loud, but more harmonic/mixed sound. I already have the valve controller as he recommends. However, I had looked into doing OAP's before, and I was pretty committed to one with heat shielding like the OEM part. For people who have purchased the Kline, what are you doing (or not) about heat shielding on the OAP part? Has anyone wrapped it in exhaust tape? I read at one point that is more effective than something like a JetHot coating.
Any thoughts/rationalizations appreciated. I'd really like to buy this exhaust, but I'm gun-shy due to the lack of heat shielding.
#623
Basic Sponsor
Thank you!
SupremePOWER Inc
1562 Kimberly Ave - Fullerton CA 92831
Contact: sales@supremepower.com - Shop# (714)632-1951
World's Largest Retailer/Distributor of BBS Motorsport & Street Wheels from 2015-2023
Huge Inventory: BBS, Kline, Brembo, Soul, Recaro, KW, Akrapovic & 200+ brands. Installation available
** Retail & Wholesale ** Global Delivery ** We match/beat any authorized dealer's price **
SupremePower.com // SupremeForged.com // Follow SupremePower on IG
![](https://rennlist.com/forums/signaturepics/sigpic155552_2.gif)
SupremePOWER Inc
#624
Kline does offer optional heat shield. We have not sold it with it yet as they say it runs cooler than the stock w filter in place but if you wanted you could add the shield. Please PM or email sales@supremepower.com and we can help you out.
#625
Thanks,
Jeff
Thanks,
Jeff
#626
https://www.youtube.com/watch?v=dnab...IGErt&index=14
#627
Kit has stainless steel and OEM manifolds/headers. That is the route I went and I am 100% satisfied. It is perfect as it relates to sound quality and quantity. I will be honest as many others have said. I am not sure there is a need for a valve controller other than plugging the vacuum lines and leaving the valves open all the time. It is perfectly civilized during "normal" driving. And it still does provide some satisfaction even in those instances with a little growl and some burbles. But in no way loud. Once you hit the throttle, it is loud and sounds amazing. The beauty of it is that there is absolutely zero drone. Kline hit a home run with this system giving you what you want without drone. Most other combinations have drone...some of them a LOT. Luckily Kline decided to attack this as an entire system and not just piece by piece. I think that is where the advantage goes to Kline. I am under the impression that JCR has excellent sound with just the muffler section alone but also most complaints are that it is not loud enough. Anyway, I think I have posted on this and many other threads the same thing I am posting now. If I had to do it all over again I wouldn't change a thing(except maybe the VC). My tune might change about the VC if on a long trip....it is ever so slightly louder at highway speeds and any reduction in noise in these things is a plus on longer trips. These cars are inherently noisy(I am Spyder).
#628
I've been running the Kline Inconel exhaust w/o headers for about a week now on my CGTS4.0. For me, I still hear a bit of drone, about the same as stock but it doesn't seem to be as boomy. I haven't done the SS delete and I don't plan on doing it. It's not obnoxiously loud with the valves open cruising around town. I haven't really been able to get in the higher rpm range yet due to engine break-in but this new exhaust has caused me to go a bit past 4k rpm a few times... and it's friggin glorious. Downshifts sound so much better now as well... very exotic sounding. I'm very happy with it.
The following 2 users liked this post by brades:
Spyder Bite (01-14-2022),
UncleDude (01-14-2022)
#629
If you get the full system with headers the drone is entirely gone... but its louder.... Driving with the valves closed is much better below the 4k level when they open. Open 100% of the time with the 200 cell headers is just loud!
SupremePower (01-14-2022)
