718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Cargraphic valve control unit
Old 10-07-2021 | 07:06 PM
  #226
lowbee's Avatar
lowbee
Originally Posted by N11g
......As there are no Cargraphic dealers in Canada, I ordered directly from them (needed less than a week to get it).......
Sports Car Boutique in Toronto carries Cargraphic's product but not sure why they are not listed as dealer...
https://www.sportscarboutique.com/co...dor_cargraphic
full disclosure: I have no affiliation with either Cargraphic or Sports Car Boutique but I plan to contact Sports Car Boutique if I am ever in the market for Cargraphic products
Old 10-07-2021 | 07:11 PM
  #227
Westcoast's Avatar
Westcoast
Installed a 2-mode valve control today. The unit, which has 2 holes on the sides (where I zip tied the box to the bracket). I used a small homedepot bracket and one bolt/nut > the bracket & ziptie can hardly be seen. Everything is inside the engine compartment.
So far, I am happy with the mod. By the way, as I was told, the flow optimized OAP gives 2 dB over stock, while the filter deleted one adds 4 dB.
Interesting, let us know how the remote fairs with the controller inside of the engine compartment, I programmed the Homelink buttons to the CG controller, and with the antenna in the trunk it sometimes does not pick up the signal, fortunately the fob-remote always works.
Paulywanacracker (10-07-2021)
Old 10-07-2021 | 09:24 PM
  #228
N11g's Avatar
N11g
Westcoast, 2 of the 3 Homelink buttons are for the 2 garage doors already, so I use the remotes.
So far it has been consistent (20 or so times) ... well, until the battery is no longer sufficient
Old 10-08-2021 | 02:25 PM
  #229
kitwetzler's Avatar
kitwetzler
My controller is also in the trunk, and I have to hold the homeland a good few seconds for it to register most of the time. I'm curious about the engine compartment too - I was worried it would get too hot, but I'm sure pinching the wires in the engine compartment seal isn't any better for it
Old 10-08-2021 | 02:26 PM
  #230
kitwetzler's Avatar
kitwetzler
Did you find switched power in the engine bay?
Old 10-08-2021 | 02:41 PM
  #231
Westcoast's Avatar
Westcoast
The 2-mode CG controller does not need a separate power lead.
I have checked, and after 8 months there is no issue with the wires being feed out through the cover, in fact the seal it self (in between each fastener) allows plenty of room for the cable to come through without any real pressure on it.
Old 11-22-2021 | 02:10 AM
  #232
wanderingshi's Avatar
wanderingshi
Does using the cargraphic control unit void your warranty? How do you guys deal with that? Were you able to get your dealer to install it?
Old 11-22-2021 | 04:11 AM
  #233
RoadrunnerGTS's Avatar
RoadrunnerGTS
Any aftermarket add-on 'can' void warranty
Old 11-22-2021 | 10:32 AM
  #234
Croc999's Avatar
Croc999
Hope for the best, prepare for the worst...
Old 11-22-2021 | 11:59 AM
  #235
Westcoast's Avatar
Westcoast
The 2-mode unit which is 'Auto': normal PSE operation and 'Sport' which is valves always open should be pretty harmless, keeping the valves open won't hurt the engine. If the VC breaks simply remove it and the problem is solved.
As for installation, you would have to ask your dealer specifically, most of us approach this as a DIY mod.
Spyder718 (11-22-2021)
Old 11-22-2021 | 12:17 PM
  #236
Croc999's Avatar
Croc999
no splitting/cutting wires are required - so it's a reversible mod.
maybe not super easily because it takes ~1 hour, but not too terrible.
Old 01-02-2022 | 02:52 PM
  #237
lowbee's Avatar
lowbee
If you have figured this out, please share as I intend to install a 3-mode inside the engine bay. TIA
Old 01-03-2022 | 09:02 PM
  #238
*991*'s Avatar
*991*
Anyone know if any vendors have any deals on the 2 wire Cargraphic controller? I saw flat six has it for $495 free shipping. Any better prices these days??
Cargraphic Valve Control Unit (718 GT4) - Flat 6 Motorsports
https://flat6motorsports.com
Old 01-03-2022 | 09:07 PM
  #239
SupremePower's Avatar
SupremePower
Basic Sponsor
Cargraphic Valve Control Unit (718 GT4) - Flat 6 Motorsports[size=16px]
[/size]
We sell the Cargraphic 2way Valve Controller for $440.00 shipped.
Please email sales@supremepower.com to get set up. Always in stock.
Old 01-04-2022 | 09:14 AM
  #240
Flat6Motorsports's Avatar
Flat6Motorsports
Basic Sponsor
We've got some 2 mode units in-stock and have more inventory arriving next week with 2 and 3 mode units.
Flat 6 Motorsports
Porsche Aftermarket Specialists
www.flat6motorsports.com
Instagram / Facebook / YouTube
Quick Reply: Cargraphic valve control unit
