718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Exhaust flap switch
Old 05-02-2020, 04:55 PM
  #76
DocMo
DocMo's Avatar
Originally Posted by JCR-Porsche
The tips don’t need to be physically together to achieve this. Just the correct amount of merge in the right place
We already have Multiple versions available to order
https://www.jcr-developments.com/por...-spyder-gts4.0
JC
I wonder if you take the valves out of the JCR exhaust what would be the impact on sound? Many of us would always have the valves open...why not get rid of them like center bypass systems on GT3 and GT3 RS?
Old 05-04-2020, 07:33 PM
  #77
jvmax
jvmax's Avatar
ok, disconnected the vacuum lines over the weekend, valves open all the time. Definitely louded than stock under 4k rpm and can hear the downshift blips now.
Track_maniac (05-04-2020)
Old 05-05-2020, 12:09 AM
  #78
spyderphile
spyderphile's Avatar
That is, down shift blip sound from under 4k? And, no sound over 4k (as reported by GAZZ)? That is, no change over 4k pre-mod? Thanks.
Old 05-05-2020, 05:37 AM
  #79
JCR-Porsche
Basic Sponsor
JCR-Porsche's Avatar
Valves are open anyway over 3800rpm with the PSE button pressed
They’re open at idle then close pretty much as soon as the clutch is up until 3800rpm where they remain open
With the PSE button ‘off’ the valves stay closed until 5000rpm depending on throttle input
Either way regardless of the PSE button position the valves are open at WOT over 5000rpm
Any reports of the valves cycling or being partially open isn’t true. The Valve logic is the same as it’s been for many years
JC
WE'RE NO LONGER ACTIVE ON THE RENNLIST FORUMS - FOR ALL ENQUIRIES PLEASE CONTACT US VIA THE JCR WEBSITE BELOW
/ / JCR PORSCHE \ \ \
contact@jcr-developments.com
Facebook | Instagram | Youtube
The following 3 users liked this post by JCR-Porsche:
erik_plus8 (05-07-2020), Jim Rockford (05-05-2020), wizee (06-27-2020)
Old 05-05-2020, 01:29 PM
  #80
Westcoast
Westcoast's Avatar
Received 4,711 Likes on 2,741 Posts
JC
This is good information know about these valves and how they operate, so is it correct to assume that you designed your exhaust to work in conjunction with the factory programming here?
I think the answer is yes considering what you wrote in the 'Another Exhaust sound data point' thread: https://rennlist.com/forums/718-gt4-...l#post16601159
Old 05-05-2020, 01:46 PM
  #81
jvmax
jvmax's Avatar
JC
by disconnecting the vacuum lines, the valve are always open, so the sound missing once clutch is up to 3800rpm is now there, as well as, the auto blip has much more sound now
Old 05-06-2020, 10:07 PM
  #82
spyderphile
JC
Good explanation; thanks. And, glad to know valves stay open over 3800! WOT all the way!
Old 05-07-2020, 05:11 PM
  #83
_nosubstitute_
_nosubstitute_'s Avatar
now it's all open, do you feel you could be happy just as is vs. having to mod it more?
Old 05-07-2020, 08:13 PM
  #84
jvmax
jvmax's Avatar
yes, I am happy with the sound now.
The following 2 users liked this post by jvmax:
Westcoast (05-08-2020), ZA GT4 (05-07-2020)
Old 05-08-2020, 03:01 PM
  #85
Rennolazine
Rennolazine's Avatar
So the OP's valve mods look like they connect to electronic valve actuators. The US guy unplugged vacuum hoses from vacuum actuated valves (like 718 and 991 porsches). Looks like there might be some differences?
Old 05-08-2020, 05:05 PM
  #86
works_team
works_team's Avatar
I’ve just ordered the Cargraphic stuff as I wanted to keep the ability to put the exhaust back to normal easily. I will report once installed (post-confinement...)
Old 05-21-2020, 08:04 PM
  #87
Mojonito
Mojonito's Avatar
  • There is this company also
https://valvetronic.com/products/por...lve-controller
Old 05-21-2020, 08:20 PM
  #88
4MIDABLE
4MIDABLE's Avatar
Originally Posted by Mojonito
How is this different that the PSE console button? Does it override the valve logic? Meaning when activated, the valves will stay open no matter the tachometer reading (between idle and 3,800rpm)?? If yes, does this render the PSE console button redundant?
Old 05-21-2020, 08:55 PM
  #89
Mojonito
Mojonito's Avatar
I believe when it’s activated it opens the valves at all speeds. When it is off the pse button and valves work as Porsche intended.
Rennolazine (05-21-2020)
Old 05-23-2020, 02:26 AM
  #90
metalone
metalone's Avatar
Originally Posted by Peter_GT4
Not the way to go in my opinion. Disconnect the hoses (I could do it easily by hand with moderate force). Insert grub screw in M6 size and thread it in
with a t-handle allen wrench. Use pliers to hold the hose while doing this. The grub screw should be inserted about 20mm into the hose, so you can
completely re-attach it on the exhaust valve. Same procedure on the other side.
Benefits: Invisible, no open ends to be sealed, cheap and quick. Also easy to undo by screwing the grub back out anytime
Peter
Wow, I found this a really good idea, if actually work as smooth & clean as it sounds.. here are the first questions that comes into my mind:
  1. Is there any length recommended for the grub screws?
  2. Is there any risk of the grubs to get "sucked-in" and causing a big issue?, what would be the worst case scenario?
  3. On what car has the M6 size actually been tested? 981 GT4?, 718 GT4? other?, are all hoses the same size?
  4. Can the screw damage the hose? how many screwing would the hose take before start wearing inside? (not relevant?)
Cheers
Quick Reply: Exhaust flap switch
