Old 10-11-2017, 10:25 PM
  #7306
Captain_Slow
Captain_Slow's Avatar
Both of the C-clips on the headlight lift mechanism were in place, but they were too easy to remove. Installed the locking clips and oiled the arm joints.
Old 10-11-2017, 10:44 PM
  #7307
polecat702
Vegas, Baby!
polecat702's Avatar
My LH, is in Oregon, at Ott's Performance. Figured I'd clean the grounds while I'm waiting on return mail.
There's a bunch of oil in the Valley under the intake. I think, maybe the pipe from the blower, has lifted the filler neck, or the hoses under there are mush. Gotta check that out ASAP.
It's always something!
Old 10-14-2017, 02:08 AM
  #7308
Sagres74
Sagres74's Avatar
Love it!
Originally Posted by sbirring1
Wife is out tonight so been busy running random parts through "our" parts washer....
Old 10-14-2017, 08:40 AM
  #7309
545svk
545svk's Avatar
[QUO
It's always something![/QUOTE]
Sound like my son. We just did the fuel lines, busy with the a/c, and I want to remove the front suspension to clean everything.
And then there are brakes and a fluid flush.
Old 10-14-2017, 06:31 PM
  #7310
Jehu Gearloose
Jehu Gearloose's Avatar
Default Moving day
Get to drive a rear-engine Porsche for the first time.
Maybe I'll finally see what all the fuss is about.
Old 10-16-2017, 12:35 AM
  #7311
JWise
JWise's Avatar
Getting the Velvet Hammer ready for 3rd Coast next month. Today, an oil & filter change using Mobil 1 15W-50 along with a differential fluid change using Redline 75W-90NS. Up next - a visit to Sean Ratts for an ATI harmonic damper install along with timing belt/H2O pump change, brake fluid and PSD flush.
Old 10-16-2017, 07:18 AM
  #7312
Redcar928
6th Gear
Redcar928's Avatar
Default Redcar928
Today I lifted the front end, adjusted the LHD wheel bearing and cleaned the wheel wells with hot water and a lot of dish soap. Wheel wells look so much better!
Old 10-16-2017, 08:22 PM
  #7313
GeorgeM
GeorgeM's Avatar
Default Replaced this thing.
No idea how this thing could crack. Fortunately, it's a separate part. Who'd a thunk?
Old 10-16-2017, 09:31 PM
  #7314
Range Rover
Range Rover's Avatar
I assume that people think it's a button and try to push on it. Some probably get frustrated and push really hard.
Old 10-17-2017, 02:06 AM
  #7315
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
I beat the she-it out of a turbo diesel sleeper pickup truck stop light to ...., I know, I know, I didn't actually work on my car today, but I did drive it.
Old 10-17-2017, 04:41 PM
  #7316
jtrygstad
jtrygstad's Avatar
Default Oil Filler Neck Scrubber & Clutch Master Cylinder
Fixed leaking oil filler neck, so added Kuhn oil scrubber while at it.
Quick drop-in to see fit before proper install with gaskets and Hondabond.
Then the miserable clutch master cylinder replacement. New mc, blue hose and GB long hose to the slave cylinder.
I wonder if the deterioration at the blue hose fitting was the source of letting air into clutch hydraulics?
Old 10-23-2017, 01:19 PM
  #7317
JWise
JWise's Avatar
Think I'm in good hands with both Sean AND Roger working on it. 😀
Old 11-06-2017, 02:03 AM
  #7318
Michael Benno
Michael Benno's Avatar
Default Less Disco
One of the previous owners of my 88 S4 installed a bunch of stuff from Jager Engineering including the 928 LED Gauge Illumination Kit (78-88) which offers pretty nice illumination but the blue color the PO choose is very cool and disco colored and I wanted to revert my interior back to stock.
Here is a shot from the Jager site and mine side-by-side
The kit replaces the OEM prism wedges with special ones cut for a LED bulb. Depending on the color you want they just put in a different color LED. I tried to have Jager Eng sell me just the LED but they would not do that. I was looking at new kit for $90. I did some research for alternatives and found this replacement LED: Wired 12V DC LED Pack which seems to be nearly identical to the product used by Jager.
Old 11-12-2017, 02:55 PM
  #7319
Mikebte
Mikebte's Avatar
Cleaned up my paint a little. Still a lot of work needing done. Love it when the water beds off with fresh wax.
Old 11-21-2017, 11:20 AM
  #7320
Whitesands
Whitesands's Avatar
Default Washed' cleaned and ready for a 620k mile hop
Completed without incident, wife and dog delivered to West Palm Beach, not bad for a 30yr old car with 312k miles on the clock.
Quick Reply: So what did you do to your 928 Today......
