So what did you do to your 928 Today......
#7306
Both of the C-clips on the headlight lift mechanism were in place, but they were too easy to remove. Installed the locking clips and oiled the arm joints.
#7307
Vegas, Baby!
My LH, is in Oregon, at Ott's Performance. Figured I'd clean the grounds while I'm waiting on return mail.
There's a bunch of oil in the Valley under the intake. I think, maybe the pipe from the blower, has lifted the filler neck, or the hoses under there are mush. Gotta check that out ASAP.
It's always something!
#7308
[QUO
It's always something![/QUOTE]
Sound like my son. We just did the fuel lines, busy with the a/c, and I want to remove the front suspension to clean everything.
And then there are brakes and a fluid flush.
#7311
Getting the Velvet Hammer ready for 3rd Coast next month. Today, an oil & filter change using Mobil 1 15W-50 along with a differential fluid change using Redline 75W-90NS. Up next - a visit to Sean Ratts for an ATI harmonic damper install along with timing belt/H2O pump change, brake fluid and PSD flush.
#7312
Redcar928
Today I lifted the front end, adjusted the LHD wheel bearing and cleaned the wheel wells with hot water and a lot of dish soap. Wheel wells look so much better!
#7314
You can call me Otis
I beat the she-it out of a turbo diesel sleeper pickup truck stop light to ...., I know, I know, I didn't actually work on my car today, but I did drive it.
#7316
Oil Filler Neck Scrubber & Clutch Master Cylinder
Fixed leaking oil filler neck, so added Kuhn oil scrubber while at it.
Quick drop-in to see fit before proper install with gaskets and Hondabond.
Then the miserable clutch master cylinder replacement. New mc, blue hose and GB long hose to the slave cylinder.
I wonder if the deterioration at the blue hose fitting was the source of letting air into clutch hydraulics?
#7317
Think I'm in good hands with both Sean AND Roger working on it. 😀
#7318
Less Disco
One of the previous owners of my 88 S4 installed a bunch of stuff from Jager Engineering including the 928 LED Gauge Illumination Kit (78-88) which offers pretty nice illumination but the blue color the PO choose is very cool and disco colored and I wanted to revert my interior back to stock.
Here is a shot from the Jager site and mine side-by-side
The kit replaces the OEM prism wedges with special ones cut for a LED bulb. Depending on the color you want they just put in a different color LED. I tried to have Jager Eng sell me just the LED but they would not do that. I was looking at new kit for $90. I did some research for alternatives and found this replacement LED: Wired 12V DC LED Pack which seems to be nearly identical to the product used by Jager.
#7320
Washed' cleaned and ready for a 620k mile hop
Completed without incident, wife and dog delivered to West Palm Beach, not bad for a 30yr old car with 312k miles on the clock.
