Old 01-04-2017, 04:19 PM
  #6751
Hymodyne
Hymodyne's Avatar
Put tub and drive train up on rolling platforms for easier moving around the garage . removed fuel tank and hard lines.
James
Old 01-05-2017, 01:05 AM
  #6752
Mikebte
Mikebte's Avatar
Removed the Sun Roof switch and cleaned the contacts. Used the smallest file I could find.
Installed and the sun roof works.
Examining the PO wire job on rear wiper switch.
It's bad. Will replace or repair.
Removing top of sunroof trans to clean and lube.
Will replace my current trans with missing teeth.
Old 01-05-2017, 01:16 AM
  #6753
ddarnell
ddarnell's Avatar
Rebuilt the power steering pump......twice. If you let the vanes fall out you CAN reinstall them the wrong way. The important thing to remember is to make sure to wrench the pully (the one you bent the s@#t out of with the puller) down tight before checking for free movement. That way you get to bend the pulley twice and then once more when you realize (even though you knew it) the mounting bracket needs to go on before the pulley.
Old 01-06-2017, 10:22 PM
  #6754
Mikebte
Mikebte's Avatar
Removed old wiring and soldered inthe better part of the wire.
will work until I get new switch.
PO broke the tabes, cause I don't know why..
Connections repaired
POs handy work
Replaced fuel filter, looks as if I need to do a little fuel pump R&R. Replace crush sleeves.
Old 01-08-2017, 07:00 PM
  #6755
Hymodyne
Hymodyne's Avatar
Default door card refresh
made good progress on repairing both door cards. fiberboard had begun to come apart in places, and the PO chose the pocket area of both cards for an additional speaker. I closed up those holes, reinforced the attachment holes with fiberglass cloth and resin, and covered the exterior of both cards in 6 oz fiberglass cloth. Going to try my hand at dyeing the leather on the armrests and consoles.
James
Old 01-09-2017, 10:55 AM
  #6756
Adk46
Adk46's Avatar
Replaced starboard lower ball joint boot. My first time with a separator tool - BAM! I scribed around the eccentrics so I could them back where they were, so no realignment needed. In theory. Port side is next.
Old 01-09-2017, 03:06 PM
  #6757
hlee96
hlee96's Avatar
Picked up some 8"/9" forged 16" CS wheels locally from a 951 owner. Wheels are 928.362.117 and 928.362.119 with ET 60. Psyched!
Old 01-09-2017, 03:21 PM
  #6758
kmascotto
kmascotto's Avatar
hlee96, the fronts are 7 inch not 8 inch if they came from a 951.
Old 01-09-2017, 03:31 PM
  #6759
Livio928
Livio928's Avatar
Do the 951 rims have the 928.XXX.XX designation as well or could these be original Design 90 rims?
Old 01-09-2017, 03:38 PM
  #6760
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,760 Likes on 1,340 Posts
Real 8" CS wheels will have the embossed bits on them, like Hoi described. Sounds like he scored the real deal.
Part # 928 362 117, with the '17' looking like the mold was modified:
Offset: 8J x 16 ET 60, with the '60' modified likewise:
Old 01-09-2017, 04:01 PM
  #6761
kmascotto
kmascotto's Avatar
here is the 951 rims
951 362 115 30 - alloy wheel 7 J x 16 - ET 65 - FORGED silver
928 362 119 30 - alloy wheel 9 J x 16 - ET 60 - FORGED silver
1987 - 1988 928 S4 (Clubsport)
with option:
M393 - Club Sport wheel 16 inch
M637 - Club Sport CS
928 362 117 30 - alloy wheel 8 J x 16 - ET 60 - FORGED silver
1989 928 S4 (GT)
M639 - Version GT
928 362 157 30 - alloy wheel 8 J x 16 - ET 60 - FORGED silver
928 362 159 30 - alloy wheel 9 J x 16 - ET 60 - FORGED silver
Old 01-09-2017, 04:55 PM
  #6762
hlee96
hlee96's Avatar
Looks like I got lucky. Owner of 2 951 decided to sell his club sport wheels. Advertised as 944 turbo wheels in local craigslist here in suburban Philadelphia; however I thought they may be 928 CS when he sent me a pic with 928 parts number, even though he gave a 7-slot old 928 wheels parts number erroneously in his ad.
Here are the pics of the wheel numbers. He told me last week that he has four 9" wheels, but when I picked them up today, I was pleasantly surprised to learn that that are the real deal 8"/9" staggered forged club sports. 225/50 in front and 245/45 rears. Not in perfect shape but presentable.
Hoi
Old 01-09-2017, 05:28 PM
  #6763
kmascotto
kmascotto's Avatar
Got to love finds like that
Congrats!
Old 01-09-2017, 08:18 PM
  #6764
Imo000
Captain Obvious
Super User
Imo000's Avatar
Next time don't use a file or sandpaper. It creates grooves in the contact area, decreases surface area and creates arcing points (lots of them). Instead use 000 steel wool or cardboard,
Old 01-09-2017, 09:30 PM
  #6765
Hymodyne
Hymodyne's Avatar
Default door card and interior trim progress
Worked on cleaning all the old foam padding off one of the rear quarter trim pieces. My leather dye came and I started to treat interior pieces. The interior was tan/light tan, I'm going with light and dark grey.
The new foam for the rear quarter piece is a folded yoga mat, installed with contact cement.
James
Quick Reply: So what did you do to your 928 Today......
