Old 11-19-2016, 04:47 PM
  #7786
H.F.B.
H.F.B.'s Avatar
Default Vinyl wrapped and installed throttle response cam
Vinyl wrapped and installed only944 throttle response cam.
Worthwhile upgrade!
Throttle response is now linear! Hey, first drive out of my garage as usual resulted in some wheelspin.
Old 11-20-2016, 01:29 PM
  #7787
hrivnakd
hrivnakd's Avatar
Default Transaxle fluid change - 1990 - 944 S2
Can you tell I don't want to put this away for the winter Changed the sparkplugs - NGK BR9EIX (noticed a few mL of oil in one of the plug wells) and discovered that it's possible to change out the transaxle fluid without jacking the car up. The trick is to remove the 2 nuts holding the muffler so it flexes toward the driver side rear wheel, then you can get your hands in to remove the hex nuts on the transaxle with a crescent wrench around a 17mm hex bit.. see the picture below of the old (very smelly) oil that came out, and only about 1L which is probably why I could hear scraping once in a while in low gear. I used a plastic hand pump to refill 2.5 L or so. Went for a quick drive and the scraping is gone..
Old 11-21-2016, 08:34 PM
  #7788
curtisr
curtisr's Avatar
Originally Posted by hrivnakd
discovered that it's possible to change out the transaxle fluid without jacking the car up...I could hear scraping once in a while in low gear. I used a plastic hand pump to refill 2.5 L or so. Went for a quick drive and the scraping is gone..
CTC/Motomaster to the rescue!
Old 11-23-2016, 08:01 AM
  #7789
nine7one
nine7one's Avatar
Default pulled out the battery
My944 S2 has been turning over a bit slow. Since it's going to bed in it's garage pretty soon I decided to replace the battery. I don't understand why keeping a battery on a tender and light use of the car in general eats batteries. Oh, and holy crap, I haven't bought a battery in a few years, I think 3. When did they double in price?
Old 11-23-2016, 08:37 AM
  #7790
curtisr
curtisr's Avatar
I've often thought that this must be why Porsche offered (included?) a kill-switch in earlier models. And if you didn't have one, it seems as though some have felt the need to add such a device. Anyways, be glad you don't own a 928...
Old 11-24-2016, 05:40 AM
  #7791
Gregs04.5
Gregs04.5's Avatar
I believe we can thank our Federal Gov. for that, The EPA to be exact. The EPA caused the shutdown of the last lead smelter in the US, now all ore must be processed off US soil.
While the EPA did not march in and shut down operations, they did impose strict and VERY expensive pollution regulations, and the company said screw it and closed the doors.
Old 11-24-2016, 09:39 AM
  #7792
V2Rocket
V2Rocket's Avatar
where are you buying batteries?
i've bought 3 since 2006 and they've all been ~120 each.
(first one was killed in a crash in 2010, 2nd one lasted 2010-2015 and now on #3)
Old 11-24-2016, 10:37 PM
  #7793
pfarah7
pfarah7's Avatar
Had the local P-shop replace the motor mounts; what a difference! No vibration and actually shifts better.
Old 11-24-2016, 11:12 PM
  #7794
AgLiftPilot
AgLiftPilot's Avatar
Joining this thread in the middle of a late, frantic build of a new 924S racecar I am building. Goal is to have it on track at Road Atlanta next week end.
Today:
Installed Hawk track brake pads and stainless steel brake lines, filled reservoir and bled brake and clutch system after a new brake booster/master, and clutch master/slave. Now I'm fabricating a Mocal external oil cooler mounted in front of the radiator. Next is making the oil cooler lines with AN -12 fittings from the cooler to the 951 console.
Yesterday:
Installed brake booster and master.
In last 2 weeks:
Removed restrictor from fuel filler neck, cleaned early struts and had powder coated, installed bilstein HD strut inserts, Ground Control top mount camber plates with cross brace, installed 86 spindles without speedo hole, new brake rotors on all 4 corners, new reinforced front steel A arms with poly bushings, new ball joints with oversized hardware, filled coolant system and fixed leaks, installed weltmeister bushings in torsion tube, installed 30mm torsion bars,modified and painted spring plates for removable torsion bars through body hole, drilled torsion bar hole in body, installed delrin bushings in rear aluminum banana arms, installed torsion tube assembly, installed bilstein shocks, installed new fuel tank sock/filter/hose, new Rennbay engine bay fuel hose, fabricated new oversized battery cables, installed stock radiator fans, installed rear sway bar, installed Y pipe exhaust
Still left to do:
Finish external oil cooler, track down coolant leak (likely upper water neck), install cat back exhaust, install CV axles, fill transaxle oil, install front sway bar, test run, install seats, install harness bar, install harnesses, mount tires on wider 7" wheels, alignment, roll fenders for wider wheels, fix door handles with repair kit
Old 11-25-2016, 07:23 AM
  #7795
Voith
Voith's Avatar
Got something a bit unconventional today.
Chargecooler off of 4L supercharged Jag.
Now I need to pair it with this:
Old 11-26-2016, 07:52 PM
  #7796
racerbvd
racerbvd's Avatar
Pulled the track rubber off the "S", test fitted the 9x15, will need spacers.
Old 11-27-2016, 05:14 AM
  #7797
morghen
morghen's Avatar
Oh, confident in those welds. Any details about how it was welded?
Old 11-27-2016, 11:07 AM
  #7798
V2Rocket
V2Rocket's Avatar
will definitely be interested in how this goes.
if you are taking it somewhere to have a shop mate the parts together...in all seriousness, ask if there'd be any discount to do two of them like that...
Old 11-27-2016, 11:49 AM
  #7799
Voith
Voith's Avatar
I'll piece it together myself but leave welding to professionals. Welding of aluminum is 40€/hour so not expensive.
Today I filled it with wet paper (to protect it from aluminum dust) and cut off jag manifold. This is how it looks now.
Old 11-27-2016, 12:33 PM
  #7800
Tiger03447
Tiger03447's Avatar
How does the chargecooler work? It appears to be a water/air intercooler, but not sure at this point. Please enlighten. Thanks.
