cost to build spec 996
#241
The Penguin King
Fact #1: I need to buy a new steering wheel (current is getting a bit worn, and doesn't have a quick disconnect)
Fact #2: I need to get some form of race dash with telemetry, etc.
Is this two birds, one stone?
http://www.aim-sportline.com/eng/pro...heel/index.htm
#243
Do you guys recall if you had to drop the transmission to install your LSD ?
My Indy says grand has to be dropped : 14 hours for LSD installation
#245
I just put this one in my car and love it. The smaller size feels real good.
http://www.momousa.com/racing/steeri...ls/mod-30.html
#247
#248
My best guess for shop time to do it would be:
1.5 to remove trans
2.0 to fit LSD
1.5 to re-install trans
7 hours max. I can't see 14.....
#249
Wow, that looks like $10k to me!
I have a 320mm OMP wheel on the car now that I like, if nothing else I might just buy another one of those and have a quick disconnect fitted to it.
#250
#251
Anyone know the pricing on the AIM 350 wheel with the telemetry etc ? Web site does not provide. I'm wondering the same as Laurie regarding aging eye view as mine are older than his...by a bunch :>(
#252
#253
OK kids I'm starting to gut the interior on my 996. what needs to stay? i.e. door release levers? handles? center console? etc?
if I remove the wiring for the factory seatbelts will I have an eternal "fasten seat belt" light on the dash?
If I'm switching all the glass to lexan do I need to keep the window seals?
etc. any and all advice welcome.
Thanks in advance!
Thanks in advance!
#254
Thanks in advance!![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Thanks in advance!
#255
You do have to drop the trans to install the LSD (the first time for sure). It needs to be fitted (shimmed) into the stock trans correctly.
1.5 to remove trans
2.0 to fit LSD
1.5 to remove trans
2.0 to fit LSD
