ASK THE COACH
#1591
Basic Site Sponsor
Basic Site Sponsor
Received 3,193 Likes
Bob, much of what I teach in webinars and seminars on WHAT TO DO with the data covers this.
1) There is NO car that cannot be driven faster by someone else... The only difference is the knowledge, planning, confidence, comfort and execution of the driver behind the wheel.
2) The fact is that there is data that "looks right" (visually and that hits performance benchmarks), making it all the more clear where unleveraged opportunities exist.
THEN, you have to form a very defined, small-in-scale, highly targeted exercise to fix ONE area or deficit.
A typical data-driven methodology would be to attack throttle and brake executions first (long g, tps and bps timing and amplitude), then generate mid corner numbers (lat g and comb g), then target transitions out (latg to tps using comb g), then LASTLY, transitions in (lat g to long g using comb g, or friction circle).
No one drives the perfect lap, but they can usually do one thing well, one place in the session... Measure it, FIND it and repeat it, transfer it to raise your whole performance level!
3) This is math. Look at Segers and Fey's books (as well as Krumm's new one) and they will give BENCHMARKS that you MUST know to begin TARGETED improvement. Then, measure again.
For example, on DOT-R tires, you should be able to generate between 90-95% of total sustained lateral grip possible in braking. On slicks, a little more.
With steering and throttle sensors, we can put measures to what have been subjective analysis. "Steering speed," "Brake aggression," a million different things that we KNOW what they SHOULD be.
There is a particular minimum time it should take to execute a shift. Measure the time and distance forward thrust is negated during that shift to mine for opportunities.
This is too massive a question to answer here (because I can think of more than a THOUSAND ways to measure YOUR performance against a KNOWN ideal AND against captured moments of your particularly good execution), but there will be tidbits that will resonate with you when more people reply.
I'm going to the beach... Introduce me to your wife sometime...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#1592
Bob, I will add that watching video and looking at data tells me a lot about the car's performance envelope, as well as that of a driver. Too much to get into here, as I am traveling at the moment, but suffice it to say that in addition to what Peter says above, I will also look for telltale signs of uunderdriving (and overdriving) in brake zones, which are often visible in the data if you know what to look for. I will also look at video for missing apexes by overcharging corner entry, and excess oversteer at corner exit by being too aggressive. And there are a lot of other clues a trained eye can see.
#1593
Basic Site Sponsor
Basic Site Sponsor
Bob, et al, it all boils down to WHEN people push to try to improve, they inevitably do it in the WRONG place. With data (and video, of course, as VR points out), you can measure WHERE you are doing WHAT and then make an intelligent decision on what to do NEXT.
Sorry for the caps, I get really excited about this stuff!
The key is that the best pro drivers execute fundamental skills, BEST. The data of the best drivers looks remarkably similar. There is no "silver bullet" in this game.
Most club drivers don't do any one thing particularly well, so simple refocusing on a few things at a time, in a few places on track, can often yield big benefits. Even excellent club-level drivers (and pros) can benefit from another eye, another perspective, particularly aided by the data and "intelligent" (data overlaid onto) video.
Be glad to talk in detail off list, especially how you can mine your own data for clues to improve. Without any more risk...
#1594
Rennlist Hoonigan
which cost no drachmas
I think it's also important to point out that there is no one specific method that works to make everyone improve. You have to see their data and video, then you can make a decision on what areas will make the biggest improvement, then work from there.
Just like Peter said, there are certain shapes of the graphs that are more optimal than others. You can look for those shapes and then pick the spots to work on. I'm amazed that Buddy Fey's book is still so good even after technology has changed so much. Jorge Seger's book revision is excellent too.
In the next couple of weeks I'll have something for data folks that will be really exciting. I can't announce it yet as I'm still finishing up the details. It will be something to not be missed.
#1595
Data and mental image
I have over this past year been using data to learn more and have attended Peter's webinars along with reading more and more. One area I had learned the value of from previous sports career is mental imagery Ross B talks about this as well. Learning to look at your data vs what good data should look like then imagining in detail how to "draw" the squiggly lines you want to see. It takes a very committed process and the willingness to most likely be slower for a bit while learning. Imagine what Tiger Woods went through when his coach asked him to change his swing to be better in the long run. For my self this is challenging as I only get two days at track every 7weeks from March-October so when there I find myself just chasing my buddies vs a set plan of practice. Last week we had very wet conditions that reduced everyone's speed so it was great for just practicing specific tasks thanks to all for their contributions here I continue to learn more and more
#1596
Basic Site Sponsor
Basic Site Sponsor
Job security.
#1597
Basic Sponsor
Thanks guys!
Now, if I can ever get our car back together, I cans start accumulating some data and start learning something!
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
#1599
Basic Site Sponsor
Basic Site Sponsor
Sorry, Tom!
"Driving on the Edge: The Art and Science of Race Driving"- Michael Krumm
#1600
Rennlist Hoonigan
This is a really solid book. It has a good mix of the basics and advanced material, along with some insight that only comes from a top level driver. The book is also beautifully printed and bound.
#1601
#1602
+100 for this book. I have it and found it really illuminating and useful.
Also Ross Bentley's most recent book:
#1603
Currently reading Ultimate Speed Secrets, practicing on iRacing, training hard and looking forward to WGI!!! If everything goes fine here at the office, VR will once again coach me!
c.
c.
#1604
Last year we gained 4 seconds. We were 0.7 seconds off pole and fastest race lap time.
This year, we have to gain 2 to 2.5 seconds. 2:16:00 would be great. I know I can do it, I know how to do it. Just need some help to get there.
Ross Bentley says that it's a mental game. This is where I need to work harder... My mind is playing tricks on me.
Mental laps, mental laps, mental laps...
c.
c.
