SPEC 996 "New PCA Class for 2011"
#121
Those LSD versions have the early LSD, which is much better than the 997 version. It's got better ramp angles, and they were still using reground gears in the center section. It's a much higher quality unit than what Porsche is offering now.
It's still got issues with the friction discs and needs to be have those replaced, but when the whole gearbox costs about the same as one of our billet LSDs does, even if you've got to tweak the LSD unit a little bit, it's a steal.
As you well know Matt I have your GT unit in mine and will be switching it over to the new box when it inevitably fails.
But for those thinking abut a new box, these prices are less than half what a stealership charges for the exact same trannies.....
#122
SSF's pricing for the C2 w/LSD is $2,700. Super deal....
#123
Looks like great fun. When I raced a 996 I broke a two ball joint bolts on the rear control arm. The bolt would break where it gets really narrow right below the threads. Its a real bad part to have break at speed. Think instant rear steering. I switched to GT3 rear control arms and it solved the problem. It looks like the rules require the weak factory part. Am I the only one that had this problem?
#124
What a ride!
The rules both Spec & Stock allow the GT3 street trailing control arm upgrade.
#125
Guys - Got a reply and the specs from Walt as I am looking into same (thinking I am 2 yrs out, or so). So, IMS upgrades to LN Engineering/Raby specs not allowed?? Is there a specific reason? I am thinking that if I buy one of these, I'd DE it for 2 yrs as I turned it into a spec car. Don't upgrade or revise the IMS bearing?? Really? Not to say they all grenade, but why not avoid the potential drama.... Pls advise. TIA!
#126
Ironman 140.6
#127
PS: How the hell would anyone ever know if you've replaced your IMS bearing?
#128
Well that's just silly. I'm sure Walt hasn't been briefed on what exactly is a IMS bearing. I'm one of the 4 original 996 Spec builds and we did the LN - IMS upgrade. I just had cocktails tonight with Bruce B. and Manny A. Wish I had read this first....
For the reasons Ray S noted, there would not seem to be any 'spec' reason to exclude.
Unless of course, the potential for grenading and its subsequent carnage is to be part of the series as an acceptable racing risk. mglobe is partly behind all this ...
Seriously, tho, a formal clarification/confirmation wld be nice.
Emails are below if interested :
CJ
Here are the SP996 rules.
You will note that they do not specify intermediate shaft modifications as being allowed. The guys behind this all own 996s, so I am supposing that such modifications are not essential to having a durable race motor.
Walt
To: walterfricke
Subject: Spec 996 Rules
Date: Sat, 20 Nov 2010 18:41:35 -0500
Dear Walt:
Can you please forward a copy of the same to me? Saw this: https://rennlist.com/forums/8034361-post9.html . My PCA Membership # is 2007081441. Are the IMS bearing upgrades (LN Engineering/Raby) within spec? TIA.
#129
The Penguin King
It's an oversight. We need to get an IMS update in the rules without question. I hate to encourage going outside the rules but I doubt that a scrut would want to drop your transmission to check and see if you have a stock IMS
#130
Is anyone here debating an e-gas vs non e-gas setup. I think the '99 is the only non-egas motor, maybe early 2000 too. After that it went all e-gas. The only benefit I can think of is the ability to trail brake on the non-gas setup.
#131
The Penguin King
FWIW 2000 Is egas, but it does not cut the gas on braking. I left foot brake fairly often in mine and never ever have the gas cut out on me.
#133
LMFAO!
E-gas cars will cut out under LFB, but only after about a second or so....with some variation. Having driven Globe's car (and it is pretty sweet), I think his has a variation on the high end, meaning it allows well over a second of LFB with no cut out.
Professional Racing and Driving Coach
#134
LMFAO!
