Panamera 2010-Current
Received my new PIWIS III
Old 07-15-2023, 09:39 PM
  #1501
SpeedCircuit
Basic Sponsor
SpeedCircuit's Avatar
Hey gang,
I have a Chinese PIWIS III running 39.7 and 39.8 (selectable at boot).
I don't have the option in the instrument cluster to rescale the boost gauge or the coolant temp sensor. It appears that I can only access certain TPMS variables under the instrument cluster.
I've read that software v38.2 has engineering mode which has more options. Is that my best bet?
Old 07-15-2023, 09:55 PM
  #1502
siberian
siberian's Avatar
Received 2,241 Likes on 1,339 Posts
You should upgrade to something newer, latest version AFAIK is 41.8. And yes, E Mode is where you want to be just DO NOT select P, stay with V or E.
siberian
Old 07-16-2023, 07:07 AM
  #1503
JJT
JJT's Avatar
How is it done so that the Cayenne can start without stepping on the brake?
Old 07-16-2023, 12:01 PM
  #1504
siberian
siberian's Avatar
The same way remote starts are.
siberian
Old 07-16-2023, 01:44 PM
  #1505
JJT
JJT's Avatar
I can't find the coding in the piwis
Old 07-18-2023, 09:12 PM
  #1506
sf_car_guy
sf_car_guy's Avatar
I'm interested in building my own PIWIS 3 setup. This thread has been very helpful. I guess I need to PM @rnlst_log?
Old 07-18-2023, 09:19 PM
  #1507
siberian
siberian's Avatar
Was that a question?
siberian
Old 07-18-2023, 09:29 PM
  #1508
sf_car_guy
sf_car_guy's Avatar
siberian
As I understand, I need more posts to unlock PM privileges. Forgive me.
Old 07-18-2023, 09:41 PM
  #1509
siberian
siberian's Avatar
Just unlock PM's in your profile
siberian
Old 07-18-2023, 11:36 PM
  #1510
SpeedCircuit
Basic Sponsor
Which software version are you running?
Old 07-19-2023, 07:46 AM
  #1511
filth
filth's Avatar
Hi guys, could someone tell me if this is a credible source for piwis3?
https://www.obdii.shop/goods-156-Por...ogramming.html
are there other (cheaper options)? im only looking to be able to deactivate the valve control in my 718 GTS4.0
Old 07-19-2023, 12:08 PM
  #1512
siberian
siberian's Avatar
Given that's all you want to do, go to the forum's Regional Section, find the one you live in and request help from a member who already has PIWIS. Personally I would own my own copy and for that contact @rnlst_log . Lastly make sure the VAS version works with the PIWIS one. For 40.8.xxx it needs to be 1.6.6.0; accept no substitute. Nice to see that v 41.0 supports DoIP.
siberian
Old 07-23-2023, 12:32 AM
  #1513
edsonreds
edsonreds's Avatar
Originally Posted by Vegas1
Hello Lucifer
did you manage to make it work ?
Do you have any guide how to write the Acronis file to the SSD ? I have an HP laptop with PCIE ssd not sata ... i got a usb conection for PCIE SSD in order to write the software but how do you use the free version of Acronis ? I am not a programer .... DIY help ??
I doanloaded the 38 VERSION but If you have a link for 40+ i will apriciate that
4. any link for keygen ?
5. vas 6154 with firmware 1.6.6 i ordered it is coming ...
Thank you in Advance
1. Once you have the *.tib file you can mount the recovery file in an USD, SSD SATA or SSD M2. There is an option in Acronis Pro. Youtube is an excellent source. You have to purchase Acronis to do this. No need to be programmer.
2. There is a torrent file for 4.410 version around. But the *.tib Lucifer mentions brings 4.400, which could be more than enough for a beginner. Besides, the torrent file with 4.4100 version does not include the Wiring Diagrams.
3. No link for keygen generator. I managed to extract it from mounting the 4.41 version using VMWare. This is not easy and I would not be able to guide on this. But this is the only way to get the key generator.
4. Once you get the generator, it is another history to proper use it. If up unitl now seems a nightmare, I would suggest buying the USD 500 plus user friendly solutions.
5. Getting the VCI dongle to work on the version I got.... I will make a follow up if I managed to do it. I am just a curious guy... so I would suggest being resourceful, comfortable with handling BIOS setups and distmantling laptops... it is not an easy feat... but doable.
Good luck with the journey.
Old 07-23-2023, 04:54 AM
  #1514
Vegas1
Vegas1's Avatar
I managed to install it and make it work
My question is do i need to do all of these to put it to engineere mode ? can developer mode do coding ?
This Offset is hard
1. Find the file: D:\PiwisApps\PIDT\PIDT\Pidt\plugins\de.dsa.pidt.datatype.jar and copy it to your desktop to save it to change.
2. Open it with WinRAR and then search in the WinRAR windows the file: \en\dsa\pidt\datatypes\utils\Helper$1.class and drag it to your desktop, after copying it delete it from the archive and leave the WinRAR window open.
3. Open Helper$1.class on your desktop with Winhex and go to Offset 7: 34 -> 32 Offset IB3: 9A -> A7
4. In the still open WinRAR window, withdraw the saved file and click OK. Now close WinRAR.
5. Copy and overwrite the new de.dsa.pidt.datatype.jar file you just created in D:\PiwisApps\PIDT\PIDT\Pidt\plugins.
6. Copy the aftersales.sig file to your desktop and rename it to development.sig Copy this file back to the
Folder.
Aftersale.sig is located located in D:\PiwisApps\PIDT\PIDT\Pidt\workspace and in D:\PiwisApps\PIDT\PIDT_MIG\Pidt\workspace
7. Do exactly the same Method as above with the folder D:\PiwisApps\PIDT\PIDT_MIG\Pidt\plugins\de.dsa.pidt.datatype.jar
To transform it in developer: Settings > Diagnostic Configuration > 981-991 > Mode > Operating Mode E= development, P=Production, V= Aftersales (Regular
PIWIS 3) Other model lines > Mode > Operating mode E= Development, P= Production, V= Aftersales (Regular PIWIS 3)
downshifted (04-20-2024)
Old 07-27-2023, 06:01 AM
  #1515
Marcus13190
Marcus13190's Avatar
You can have develpment mode on all Porsche ?
Quick Reply: Received my new PIWIS III
