Cautionary Tale of Oil Leak (timing cover)
w2ge (01-01-2022)
engin_ear (04-23-2024)
#214
I believe a few people have posted in the macanforum of positive results getting this issue resolved at
various Porsche dealers - either covered post-warranty or a small percentage of the cost borne by the
owner.
Check "over there"...
owner.
VikDiddy (07-17-2020)
#216
Macan GTS 24000kms 4 years old
Macan GTS done 24,000 kms 4 years old and under extended warranty and about to have engine dropped in order to have timing chain cover oil leak dealt with! Wasn’t picked up a year ago when extended warranty pre check undertaken
#217
Had this done on my 2017 Turbo with 25k miles. They did not drop the engine and instead took the front end off. Covered by warranty, otherwise the charge would have been about $9k.
#218
It took me four dealer visits to two different dealers, showing pictures of oil on my garage floor, before the could "find" the leak, so I understand the issue of dealer trust.
#219
Was the work done by a Porsche dealership? When I had this done on my 2017 GTS the SA advised that they need to pull the engine, send pictures to PCNA showing VIN's of vehicle and engine, to prove that they had indeed followed the proper procedure.Perhaps PCNA has a trust issue with dealers? Sounds like they may have modified their accepted procedure for repair, which indicates to me they are seeing enough of these failures to invest in figuring out an optimum repair procedure.
Yes, the work was done at a Porsche dealer. The paper work lists the engine coming out, so I was surprised where the service advisor said they did it without taking the engine out.
#221
I'm in my third month of owning a CPO 2017 S, bought with only 17k miles. I've put on less than 1500 miles since purchase. Couple of days ago I discovered oil drip on the floor coming through the vent in belly cover. Looking through that vent I can see oil on the alternator and elsewhere, so it's pretty evident my car has the problem. Car is still under original warranty so I'll be taking it to the dealership for repair. I have to believe this leak would've been seen during the CPO workup. The oil filter housing is dry, so that's not the source.
Oil stain/drip at right front vent of lower belly cover. I can see oil seepage looking through the vent.
Last edited by swingwing; 08-17-2020 at 09:59 AM. Reason: Added sentence and picture.
#222
#223
Our 2017 Macan GTS had its oil changed at an inde shop and they told me my timing chain cover was leaking oil. Ugh.
Booked a service appointment at my Porsche dealer and they confirmed the diagnosis. Macan is in their hands for the next week (or more). Thank goodness for the warranty!
Loaner is a brand new base Panamera. Interesting cush-mobile with an overly complicated system of controls...menus upon menus. I can see why Porsche has slipped in the “initial quality” rankings. The new PCM has been made too convoluted and complex for most folks, I’d bet.
#224
Official Wednesday AM Red Bull F1 test driver
Can't believe the CPO inspection didn't find that. Unfortunately I think the CPO is really hit and miss at various dealers... they must have wanted it out the door and hopefully moving to a new state!
#225
I am planning to take the belly pan off to see what kind of oil drip evidence is left over, and try to clean it if attending tech didn't. These covers are not hard plastic however, and are rather absorbent. Anyone have any tips on cleaning them?
