Sponsored by: APR
GT4 G81 Transmission Failure
Old 02-05-2017, 12:34 AM
  #451
Buteo
Buteo's Avatar
The sharkwerks mod of 3rd/4th/5th really is becoming quite appealing.
Old 02-05-2017, 10:31 AM
  #452
tasman
tasman's Avatar
Sucks to hear. Maybe I should be snows on mine and go slide around in it.
Old 02-05-2017, 10:40 AM
  #453
Gofishracing
Gofishracing's Avatar
There is a fix but out of pocket. Still wondering if only a certain production date run. Best advise "Every GT4 owner needs track time to break third gear before the warranty expires."
Old 02-05-2017, 05:39 PM
  #454
4carl
4carl's Avatar
Received 1,186 Likes on 635 Posts
if it affected all gt4s you would think it would have turned up in testing . look at all the road tests that were done to hype the car and not one mention of a trans problem? a lot of the publications beat the sh-t out of the car! carl
Old 02-05-2017, 06:22 PM
  #455
Mech33
Mech33's Avatar
Supposedly the delay in getting new transmissions has been because Porsche identified the quality issue with the supplier and the new ones have the issue addressed.
Old 02-05-2017, 06:26 PM
  #456
trebien
trebien's Avatar
Not really... with the stock 2nd gear ratio still in place, the minimal 2-3 ratio spread is still problematic.
But then again, I know of a ring/pinion combo for the GT4 currently in testing that would make a gearset swap moot.
There is also a rear suspension setup in development looking VERY interesting for the rear camber issues, completely negating them.
I hope so.
If memory serves, it's an Audi box made by Getrag, and the electron-beam welding of the 3rd gear on it's shaft is the culprit - the weld fails, and the gear simply spins on the shaft. It's a rather easy fix to address, by using a better welding method, or re-design the interface to be keyed or splined - this was likely a cost-saving measure. The 3rd gear and it's shaft is not used for any other ratios... so it is its own standalone part, and could easily be remedied by designing/manufacturing a different 3rd gear/shaft drop-in replacement part.
For the data mongers, my car was manufactured in March 2016, has 10500 miles, and is stock with OEM everything and street tires.
I'll know more on Monday after dealers and PCNA open up for business, and will keep everyone up to date on progress.
Old 02-05-2017, 07:58 PM
  #457
doborder
doborder's Avatar
Another one blew... We were just talking about it this am and sure enough... 20 minutes later, I don't have third gear now... For those of you that have been waiting for your transmission, did they provide you with a loaner?
Old 02-05-2017, 09:01 PM
  #458
4carl
4carl's Avatar
sorry,@track? prod date?
Old 02-05-2017, 09:08 PM
  #459
Mech33
Mech33's Avatar
Yeah, not a GT4 though...
Old 02-05-2017, 09:39 PM
  #460
4carl
4carl's Avatar
what was it?
Old 02-05-2017, 09:46 PM
  #461
ExMB
ExMB's Avatar
Received 1,380 Likes on 839 Posts
No flame, but do you really think this would be publicized since Porsche was present at every one of those tests, supplied the cars as well as a support team with parts?
Old 02-05-2017, 09:52 PM
  #462
Mech33
Mech33's Avatar
what was it?
My dealer's loaner fleet is only Cayennes, Macans, and Panameras. I took a Cayenne.
Old 02-05-2017, 10:32 PM
  #463
4carl
4carl's Avatar
sorry i misunderstood i thought you meant the failure wasn't a GT4
Old 02-05-2017, 10:34 PM
  #464
4carl
4carl's Avatar
yes i do, all the press reported the corvette failure as LS with Chevy's factory support there. Also several press reports of intermediate shaft failures in the 996s during long term tests.
Old 02-05-2017, 11:58 PM
  #465
doborder
doborder's Avatar
4/2016 production
3rd gear
1000 track miles
Was just at the dealership dropping off my car
Saw two other GT4 awaiting transmission
Yikes... this may take a while
Quick Reply: GT4 G81 Transmission Failure
