Sponsored by: APR
strut tower failure
Old 08-01-2019, 08:34 PM
  #1126
911tac
911tac's Avatar
Originally Posted by trkshoe
Manthay is full of **** if they're saying they haven't seen a failure... I know of one of their cars that failed at the 24.
Really "Manthay" not Manthey? Really "full of ****"? Wow, just Wow.
Old 08-01-2019, 09:14 PM
  #1127
ducktails
ducktails's Avatar
I noticed that the "database" sticky seems to have petered out a bit (or there haven't been any new failures reported through RL)?
Adding to that data-set seems to be the best way to figure out how prevalent the issue really is and whether there's a pattern. I don't trust anecdotes.
I do wonder how many of these failures go unreported because people are worried about resale on repaired cars and they are unscrupulously hiding the repair from Carfax and online searches?
Maybe some way for anonymous submission to encourage data collection for the common good?
Old 08-01-2019, 10:16 PM
  #1128
aualexa2
aualexa2's Avatar
I'm keeping it all anonymous unless the reporting user gives permission to list their name.
The database has definitely been quiet. I PM'ed those who reported failures and have not heard back from some of them. If/when more strut failures occur, I'll update the list.
Best,
Alex
Old 08-03-2019, 06:20 PM
  #1129
Maxi_z
Maxi_z's Avatar
Originally Posted by ExMB
Not doubting that you heard that but Manthey is also 51% Porsche owned. With that in mind its easy not to let info out if they don't want to.
The quality of work of Manthey is out of question they are the team building the best racing porsche cars and even the work they do on street cars is excellent.
But yes they are partially owned by Porsche and I really think they will follow the company official position especially with normal road cars customers.
I asked them one if they would recommend a different engine oil than the oem M1 for track use and they politely replied that they would not recommend changing the oem oil and no other reason for it....
I also asked them (and other German porsche specialists) about the coolant hose couplers failures on 997 gt3 (well documented on rennlist) and they would really reply in a not detailed way as if they almost did not understood what problem I was talking about.
Same think for the strut parts (also from different German porsche specialists) you got replies as ....it just happened on some early cup cars...
Old 08-04-2019, 12:18 PM
  #1130
SGOGT4
SGOGT4's Avatar
Originally Posted by d00d
Those plates aren't designed to prevent the failure, although they may prevent the hood from being damaged.
Their purpose is to link to the Clubsport's additional frame struts, to more solidly locate the strut towers relative to the tub.
Anyone of pics to compare the club sport and street car applications?
Old 08-07-2019, 03:16 PM
  #1131
ZG911
ZG911's Avatar
Has this issue been fixed on the 718 GT4?
Old 08-07-2019, 03:32 PM
  #1132
Joe Weinstein
Joe Weinstein's Avatar
If there is any relevant difference in the new GT4, it would likely not be mentioned by Porsche, lest they be seen as admitting an issue. We would only know by taking a magnet to the part in the new car, or a caliper to see that the part was twice as thick etc...
Old 08-07-2019, 09:42 PM
  #1133
Jim137a
Jim137a's Avatar
Saw this post over in the GT3 Forum. Read post # 94
https://rennlist.com/forums/991-gt3-...failure-7.html
Old 08-07-2019, 11:46 PM
  #1134
jmartpr
jmartpr's Avatar
Received 1,483 Likes on 922 Posts
There was a stop sale / recall for all 718s but it was not related to the strut tower failure......
Old 08-08-2019, 12:13 AM
  #1135
Michaelpickett
Cruisin'
Michaelpickett's Avatar
Sorry my mistake on the re call
Old 09-26-2019, 11:46 AM
  #1136
imstimpy
imstimpy's Avatar
I didn't see mention of this but PCA officially recognizes it as a problem:
Originally Posted by PCA
Aluminum Shock Tower Rule Allowance
Effective June 7th
Starting with the 981 and 991 models, Porsche has used a cast aluminum front shock tower. Excessive loading of the front suspension can cause the aluminum to fracture. These and subsequent models with the aluminum front shock towers in a Stock or Improved class may make the following modification: Install the Porsche front strut plate reinforcements right 991-504-284-8A and left 981-504-283-8A, or an aftermarket equivalent such as the SP Motorsports strut tower support bracket kit, together with such fasteners and spacers as needed. These plates bolt onto the top of the shock tower and connect to the shock tower in two additional places
Source: https://pcaclubracing.org/rules/
Old 09-27-2019, 02:48 AM
  #1137
Viperguy324
Viperguy324's Avatar
To echo similar comments... Raeder Motorsports (Manthey) services my GT4, and I always walk across the street to look at the damaged cars... I have never once seen a failed strut tower that was not a quarter frontal hit. I have seen a dual failure on a 991 GT3... but again, I looked under the car and red and white paint was everywhere.
Old 09-27-2019, 10:59 AM
  #1138
matttheboatman
matttheboatman's Avatar
I have an Idea...and question for the material engineers out there: Would applying a hard epoxy coating not add a significant amount of tensile strength the strut tower part? Failures seam to occur from taring. In boats, we find the epoxy coating is often stronger than the substrate material it is covering.
Loctite Henkel epoxy coatings are used in machines subject to harsh environments... https://www.e-mj.com/features/protec...amic-coatings/
Old 09-27-2019, 01:11 PM
  #1139
okie981
okie981's Avatar
Location: On a pygmy pony over by the dental floss bush
If the surface being bonded to was properly prepared using probably the outside surface of shock tower, but inside would work also, adding a polyester resin (epoxy) with some glass-fiber or carbon-fiber filler would certainly add some strength to the area where fractures usually occur.
Old 09-27-2019, 02:02 PM
  #1140
GoKart Mozart
GoKart Mozart's Avatar
When I changed my brake pads a couple of wheels ago, I thought to myself, there is about 1.5" of threads left, below the adjustment on the coil over strut. Why not have a really stiff "helper" spring there? One that wont' do anything until the suspension bottoms out, but can absorb enough to prevent the shock tower from cracking? I think it is safe to say that the ones that fail do so when the suspension bottoms out, or do they not?
Quick Reply: strut tower failure
