Best Track Times in a GT4
#691
Actually, according to the data, 10-15 was no different, but I picked up a tenth at most of the other corners. At this point, it not about a single corner. It's about tweaking out and getting every single corner right. You screw up one corner, and the lap is done. This is why the 5 mile is really tough. I can't imagine how hard it is to nail every turn at the ring.
#694
Originally Posted by Yargk
Nice work joe, 1:59.4 is flying at thill!
new laptime for me
5/14 Sonoma 1:51.83 RE-71R
#695
Harry's lap timer with external gps unit. Interestingly, with external gps, I matched the organizer's transponder down to the hundredth of a second. Could be just coincidence though.
#696
Thanks! Proof is a good idea (although I was just going by the 1st post in the thread that mentioned only proof for lap time leaders )
Yes, I too have found gps times nearly identical to transponder. I'll bet if the start/stop markers were exactly the same they would be identical
#699
MSR Cresson today 1.7 again today.
I ran a 1:20.1.
Tires: RE71's size 255/35/19 and 305/30/19 on 19x9's and 19x11.5's
Suspension: BBi sport cup suspension, swift springs, TPC offset toe links
Alignment: F: -3.0 camber with 9 degrees caster and 1/8th toe out; R: -2.6 camber with 1/16th toe in
- Chris.
I ran a 1:20.1.
- Chris.
#700
I ran a 1:20.1.
- Chris.
I ran a 1:20.1.
- Chris.
#701
I have my Aim solo data I can download from the car. My Aim camera system is having a problem. It is operational and seems to be recording. When I take the disc home and pop it into my laptop there is nothing on it. I re-formatted the card Friday when I ran and same result.
It it has only worked once for me. I'm not sure what I am doing wrong....
On a side note - the two changes to the car were the addition of my new wheels with fresh RE71's in the 255/305 combo and the TPC toe links. The toe links have made a dramatic change to the car as it doesn't get loose and unstable under heavy braking. I can stuff the car a lot deeper and harder now.
The downside to the TPC links is that I lost inboard clearance and had to run a 5mm spacer. We are going to modify the links as I plan to run a 265/315 R7 combo on the car at COTA in June.
I would have gone under 1:20 easily with the car but I only ran 5 laps to scrub in the new tires for Road Atlanta this coming weekend.
Chris.
Chris.
#702
Chris.
Chris.
#703
MSR time is flying. WOW. What kind of memory card are you using? Maybe it is corrupted and damaged or does it have sliding "write protection" on? Im just throwing some ideas out there. Try using high quality and fast memory card. I use Sandisk Extreme Plus on smartycam and it seems to work fine.
I had reformatted that card in the hope that I could save it. Looks like that was a no-go.
Looking forward to laying down some times at Road Atlanta next weekend! Car is seriously fast now.
Chris.
#704
Originally Posted by Hams955
I swapped out the disc that came with the smarty cam for one that was 128GB. I think what may have happened was the last time I used it someone removed the disc while the camera was powered up. It may have been recording at the time it was removed. I know I have read a warning that you can brick the disc if you do that.
Chris.
Chris.
