Orthojoe's GT4 track thread and ramblings
#1156
Confirming that you run the same size tires F/R??
Tires:
Bridgestone RE71R tires
20" 245/295 on OEM wheels
19" 245/285 on OZ 19x8.5 and 19x11 wheels
Target pressures 33-34psi hot on all 4 tires.
Tires:
#1157
Sorry....I misread it. I am so used to the 3 numbers for the tire size (245/35/19, for example) I missed what you wrote based on how it looked.
I have been using Hoosiers....I am interested in trying the RE71Rs. I need to look up the ODs....assuming that I need to adjust my ride height.
#1160
Some fun video to share that my buddy shot from behind while observing us at a private track day with open passing. A 'race' between my buddy in this 350R vs my GT4. The GT4 has the edge, but I'm no racer. I was trying to figure out a way to pass him. He made 2 big mistakes that I couldn't capitalize on. Definitely made things interesting!
1:44 lost a drag race
6:02 a nice surprise
8:52 couldn't close the deal
#1162
Great stuff.
You have perfected the sound recording on all your cars.
Sounds so good.
Only thing needed is the feed from your car when the
excitement happens - need to hear that laugh that I know
is happening
Sounds so good.
is happening
#1163
...and thanks for the time stamp highlights.
#1164
Originally Posted by GeoJoe
Open passing looks like so much fun! Do you know if the Mustang was running with traction control on or off? What about you? Seems like he was getting loose a lot more than you.
#1165
Has anyone had any failed wheel bearings? All FOUR of mine have gone bad and need to be replaced already. GT3 did over 60 track days with no wheel bearing issues, but the rears were replaced under track maintenance guidelines. I'm really starting to wonder about the durability of the GT4. My buddy's boxster spyder had 3 times the amount of track time my GT4 does and the wheel bearings never went bad.
#1166
Starting to wonder!
At least there's something you are slow at![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
The car is as durable as a bic lighter.
#1168
Disappointing.
Man, my GT3 has been solid as a rock.
#1170
Originally Posted by MarcD147
What where the symptoms?
