Orthojoe's GT4 track thread and ramblings
#991
NM... see your sig. I am 2 sec. faster in the GT4 than my Modded IX which had an FP Green, Cams, E85 and other supporting mods.
#994
Totally stock engine and turbo (except for exhaust, manual boost control - set according to fuel map, baffled oil pan and better head studs) - makes conservative and reliable 335 hp and 345 ft-lbs at wheels (both numbers over 400 at flywheel) when running E85 fuel map, considerably less on 91 octane gas.
#995
One of the mods not mentioned is I had the ECU that controls the center diff re-programmed for track use on the Tarmac setting (left Gravel and Snow alone) and I have a Wavetrack front LSD. These cars have all 3 kinds of LSD's at once (front torque-biasing, center electronically controlled, and rear mechanical clutch-type).
Jack's Transmission there in CO built my Transmission/Transfer Case with the Wavetrac LSD as well. Lasted me one full season before the engine finally quit.
Decided to part it out and sell it... Got a X GSR and it wasn't the same.
#996
Makes total sense... Mine only started falling apart once i went bigger on power.
#999
#1000
the stiffer springs are like having PASM on all the time, you will get used to it after awhile.
#1003
I had an S2000 for about a year. A lot of fun on a short track. And they are incredibly cheap to run. The whole car is cheaper than a set of PCCBs.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#1004
Originally Posted by Shockwave
Your welcome to drive mine anytime!!
Its such a fun car and consumables are peanuts compared to the GT4.
