Sponsored by: APR
Orthojoe's GT4 track thread and ramblings
Old 07-23-2016, 05:19 PM
  #721
orthojoe
orthojoe's Avatar
Originally Posted by Eric5280
Yes, the system makes minor inputs for stability even though you may not feel them.
Agree. I do wonder if this has anything to do with torque vectoring, in which case esc off wouldn't cancel this either
Old 07-23-2016, 05:23 PM
  #722
Eric5280
Eric5280's Avatar
When I run with esc off, there is no brake input shown on data aside from my foot. I thought it did cancel, but maybe it is one layer deeper.
Old 07-23-2016, 05:30 PM
  #723
orthojoe
orthojoe's Avatar
I'm pretty sure torque vector is always on regardless
Old 07-23-2016, 05:43 PM
  #724
Eric5280
Eric5280's Avatar
You may be right. I know this is the 718, but should be the same. From this, it sounds like the PTV helps on turn in at slower speeds, but not higher, nor acceleration.
"The optionally available PTV for the new 718 Cayman significantly increases agility and steering precision at low and medium vehicle speeds. At high speeds and under acceleration out of corners, the mechanically controlled rear differential lock also provides greater driving stability and traction. Watch this video to understand how this system works."
Old 07-23-2016, 07:14 PM
  #725
Alan C.
Alan C.'s Avatar
Received 1,051 Likes on 540 Posts
Default Orthojoe's GT4 track thread and ramblings
My guess is there would be some price to pay in rear rotor wear with everything on. A little pricey with PCCBs but cheaper than hitting a wall.
Old 07-23-2016, 08:31 PM
  #726
orthojoe
orthojoe's Avatar
At least on my GT3 and GT4, the rear pads wear at a rate 2-3 times slower. The rear rotors on the GT3 still look like new after 30 track days.
Old 07-23-2016, 09:00 PM
  #727
Alan C.
Alan C.'s Avatar
I had the same experience with my GT3. Not enough time on the GT4 to make a judgement.
Thanks for the input.
Old 07-23-2016, 09:27 PM
  #728
orthojoe
orthojoe's Avatar
True, but given that both cars have torque vectoring, and my friends' Cayman GTS with torque vectoring didn't have any abnormal rear rotor/pad wear, I predict it will be the same.
You never know, though. My buddy's 997TTS eats rear brakes and rotors like mad.
Old 07-23-2016, 09:31 PM
  #729
NMM991
NMM991's Avatar
I always run my GT3 with TC and ESC on and will do so with the GT4 when it arrives. In my case, I been into the nannies a few times when I needed them and they really do work -- good to hear that they may even get you through a track with coolant on it.
I asked the lead instructor at the Porsche Driving School this winter during a Master Course at Barber what his recommendation was -- his answer was interesting, "with prior systems (996 and 997s) we always turned them off because we could go faster, but with the 991 cars we leave them on because they don't slow us down."
I think the only times I've felt the nannies slow me down was when I needed to be slowed down! Once I turned them off on an AutoX in heavy rain and went off the course, fortunately at a slow speed where there was plenty of grass.
Old 07-23-2016, 09:33 PM
  #730
myBailey07
myBailey07's Avatar
True, but given that both cars have torque vectoring, and my friends' Cayman GTS with torque vectoring didn't have any abnormal rear rotor/pad wear, I predict it will be the same. You never know, though. My buddy's 997TTS eats rear brakes and rotors like mad.
FYI, I just finished my 2nd set of PFC 11's in front and 1st rear set, for almost a perfect 1:2 ratio. Most of that with dsc on and at COTA, which is very hard on brakes.
Old 07-23-2016, 09:39 PM
  #731
orthojoe
orthojoe's Avatar
Sounds right!
Old 07-24-2016, 02:49 PM
  #732
orthojoe
orthojoe's Avatar
Took the wheels off and took a look at tread wear. There is still outer edge wear and tapering of the middle tread, even with DSC. Perhaps not as bad, but still there and not enough to cure the problem. I had the tires flipped inside to outside in the hopes of getting more life out of them. After this set, I think I'll have to try stiffer springs to get the even wear I'm looking for.
Old 07-24-2016, 03:19 PM
  #733
Yargk
Yargk's Avatar
Thanks for the data. I think I'll still do a few track days on the stock springs, but this information is a another little nudge to switch to swift after my first set of front tires.
Old 07-24-2016, 04:45 PM
  #734
Eric5280
Eric5280's Avatar
Agree on springs, I keep saying I won't mod the car, then I mod it. DSC added stability but not enough to even wear. Btw, what aero settings are you using? I have full and never tried anything but.
Old 07-24-2016, 05:06 PM
  #735
ExMB
ExMB's Avatar
Received 1,366 Likes on 831 Posts
OK, we know the tires are cheaper than the OEMS. But what about the heat cycles. Is it worth it to spend $1000s on mods if the tires HC out first regardless of the wear pattern?
Quick Reply: Orthojoe's GT4 track thread and ramblings
