Sponsored by: APR
Orthojoe's GT4 track thread and ramblings
Old 05-23-2016, 02:14 AM
  #451
Mech33
Mech33's Avatar
Originally Posted by mooty
you want STATIC balance not ROAD FORCE.
Why not road force balancing? I've had issues with wheel vibration when using simple static balancing only...
Old 05-23-2016, 06:42 PM
  #452
Drjimh
Drjimh's Avatar
Originally Posted by orthojoe
Had the front wheels re-balanced with the weights on the inner barrel and mounted all 4 wheels today.
***NOTE on OZ 19" FRONT wheels. Very little clearance from the caliper if you place the wheel weights on the outer edge of the barrel.
HOWEVER, if you place the weights on the inner edge of the barrel, once you load the car and start driving, you will hear a clicking sound. That is because the brake duct is hitting the wheel weights.
***You will need to trim the front brake ducts in order to make these wheels work. Not a big deal, but be aware
Ready for next weekend.
Joe,
I am looking for some Foster Parents. I was hoping you would consider adopting me. I keep my room clean, do my dishes, and do not make much noise. I can keep you seeing clearly so you drive faster and pick better lines. I am also willing to double as a garage assistant. If interested let me know!
Jim
P.S. I can also contribute to the garage stable!
Old 05-23-2016, 06:48 PM
  #453
mooty
GT3 player par excellence
mooty's Avatar
Received 5,634 Likes on 2,317 Posts
it often leads to weights on both edge of inside barrel and at 19" it's likely the wheel wt gets knocked off by the caliper if a piece of rubber off yoru tire gets wedged in there.
Old 05-23-2016, 09:37 PM
  #454
orthojoe
orthojoe's Avatar
Originally Posted by Drjimh
Joe,
Jim
Lol!
Old 05-24-2016, 07:40 PM
  #455
MarcD147
MarcD147's Avatar
Hoosiers ..... This weekend at WGI I saw a gentleman from Canada who was running a yellow GT4 with Hoosiers on 19" in bigger sizes than I thought possible. No rubbing. He was running 265 on front and 325 on rear. He supposedly is on RL. Hopefully he chimes in with what wheels he was running and other info as I forgot to ask. He was very fast...
Old 05-25-2016, 12:42 AM
  #456
mooty
mooty's Avatar
325 in the rear?
are you certain?
i am 265/295 hoosier on GT4
295 goes on 10.5 or 11" wheels so 325 would need 11.5 to 12" wheel. 11.5 wheels will not fit.
Old 05-25-2016, 01:39 AM
  #457
ShakeNBake
ShakeNBake's Avatar
325 is about 2" wider than 295. That would be sweet if they could fit.
Old 05-25-2016, 01:15 PM
  #458
MarcD147
MarcD147's Avatar
Very certain.... Of the 325 on 19
Don't know wheel width but he said no rubbing...
Old 05-25-2016, 05:28 PM
  #459
ChrisF
ChrisF's Avatar
That's crazy wide. Just add a 4.0L rebuild and you're near GT4 RS material
Old 05-25-2016, 06:20 PM
  #460
TRAKCAR
TRAKCAR's Avatar
Received 1,636 Likes on 759 Posts
RS sized rubber, bigger wing, 4.0....
Old 05-25-2016, 07:03 PM
  #461
MarcD147
MarcD147's Avatar
Driver was doing 2:10 in his first outing in car. He knew track well and is a red group driver.
I am white group and first time at the glen on stock settings with cup2 tires doing 2:23
Last day and a half was not dry but not sure I could have improved beyond a 2:20 in better weather
( rain and track wetness were great for improving skill and smoothness though)
Old 05-25-2016, 07:22 PM
  #462
ShakeNBake
ShakeNBake's Avatar
Was he in a clubsport? They have a different setup in the rear.
Old 05-25-2016, 08:11 PM
  #463
MarcD147
MarcD147's Avatar
Lol... No clubsport
driver name is Lacouture, Eric from Canada in case someone knows him and can ask him to chime in with details
I think he might have been running forgeline 19 wheels but am not sure about the brand
Old 05-25-2016, 08:21 PM
  #464
Bill Lehman
Bill Lehman's Avatar
I would expect a GT4 to be much faster then a 2:10 at WGI. I did 2:12 with a 2007 Cayman S using good suspension and R comps.
Old 05-25-2016, 08:42 PM
  #465
MarcD147
MarcD147's Avatar
I think it was his first session in the car on a track I didn't track his subsequent lap times and we had few dry sessions
Quick Reply: Orthojoe's GT4 track thread and ramblings
