Sponsored by: APR
GT4 - Unlocking the Power Potential!
Old 02-27-2016, 02:18 PM
  #421
gac1077
gac1077's Avatar
Originally Posted by Ryun43
They are so close to Jacksonville. I may just have to drop it off for a nice stage 3 ....so tasty
I'm also in Jacksonville, I'll definitely be stoping by once the GT4 gets here in June. Congrats on the GTS.
Old 02-28-2016, 10:56 PM
  #422
Jgarvish
Jgarvish's Avatar
Subscribed.
Old 02-28-2016, 11:41 PM
  #423
CAlexio
CAlexio's Avatar
Received 1,974 Likes on 917 Posts
I hope the tb and plenum give some top end without the 4.0 which I'm not ready to do... The top end on the gt4 is truly lacking
Old 02-29-2016, 07:11 AM
  #424
n3rd
n3rd's Avatar
Patiently waiting for more updates...
Old 02-29-2016, 12:03 PM
  #425
BGB Motorsports
Basic Sponsor
BGB Motorsports's Avatar
First and foremost, thanks for all of the kind words and wishes to get well. I am on the mend. I'm still pinging and knocking but i'm getting there!
Originally Posted by Jimmy-D
John, can you review what has been done to it from scratch. I know you have different stages but would like a rehash of this one. My ears are perked
Yes sir! I have actually completed the detailed offerings for my Stage I, II and III packages and will post them in this thread later today. Just as a quick summary, the car sits now as follows and I would call it a Stage II BUT without an LSD or cat-back mufflers:
STAGE I ITEMS:
- K&N Filters
- 82mm Throttle Body (NO IPD AS IT WON"T MATE TO X51 MANIFOLD)
- Cargraphic "Race" Manifolds without CATS
STAGE II ITEMS:
- 991 GTS/X51 Power Kit (Manifold, Cams & Heads)
- 12lb Aasco Flywheel & Sprung Hub Clutch Disc mated to OE Self Adjusting Pressure Plate
- ECU Re-Flash
Since you guys are close you need to come and visit the shop and we can go for a ride. Just bring bail money.
Thanks. 1 week from today i will be on the dyno with the car. I drove it over the weekend but I've got faults for no cats and the mixture not being right but that's because it hasn't been tuned. I am parking the car now until we make a proper file for it next week. I do not want to dyno it because i know what the curve will look like and it won't be perfect and with the amount of people watching, first impressions are everything with my baby. The power is definitely there and the sound, from inside OR out is better than anything any of us have ever heard. It's rather awesome with the race manifolds mated to the PSE. As long as i keep the button off and as long as i don't go WOT, it's actually not that bad. If you so much as wood the gas pedal though, the car goes from moderate to ungodly loud.
The plenum and TB will add top end, the flywheel helps things get spun up quicker in the lower gears and the race manifolds allow the thing to breathe up top like it was meant to breathe. The rationale at this point behind adding the 4.0L is to obtain the additional 20hp and 20lb/ft of torque. 20 lb/ft on this car would be awesome. It's not soft at all down below but torque is everything in this game.
BGB Motorsports Group
Old 02-29-2016, 03:36 PM
  #426
Ochocoronas
Ochocoronas's Avatar
Count me in... Jacksonville to BGB.
Old 03-01-2016, 04:56 AM
  #427
turbofreeFLAT6
turbofreeFLAT6's Avatar
So long as extra torque is added to the top end. There's enough down low, for excitement it needs a power curve that ramps up at the top instead of tapering off, not a general increase of the whole curve.
Old 03-01-2016, 07:51 AM
  #428
BGB Motorsports
Basic Sponsor
the reason behind going with the X51 was just this; the big intake manifold and ported heads have no taper up top like the stock car. In fact, I've noticed that when I drive the car the little orange dot defies the stock power curve on the power/torque graph on the cluster and sits way above everything and doesn't fall off.
Old 03-01-2016, 09:45 AM
  #429
GAZZ
GAZZ's Avatar
Good old head port and polish. That is like Engine mods 101. Older than me...
Old 03-01-2016, 02:06 PM
  #430
HiWind
HiWind's Avatar
Originally Posted by BGB Motorsports;13064722In fact, I've noticed that when I drive the car [B
the little orange dot defies the stock power curve [/B]on the power/torque graph on the cluster and sits way above everything and doesn't fall off.
ha! I hadn't thought of that! How does the orange dot get generated - some kind of speed vs weight calc? So I should be able to see similar if I add octane boost? Interesting! And reasonably scientific - although one can't really capture the dot vs chart before after ... unless maybe GoPro?! This is developing fast.
Old 03-01-2016, 02:18 PM
  #431
turbofreeFLAT6
Yes, the GT4 should be great with the X51, John.
Any chance of a warranty like AC Schnitzer is offering on its M4 ACS4 conversion? To quote Evo, 'Liberating the additional power and torque is achieved through a separate "piggyback" ECU in series with the original unit. By doing it this way AC Schnitzer is confident enough to offer a standard two-year/60,000km (37,000-mile) warranty on all drivetrain components alongside the original manufacturer warranty, extendable to three years at extra cost.'
Obviously you're doing more than a remap but there are two downsides as with any mods: voiding the factory warranty and an investment that might not be reflected - perhaps even the opposite - come resale. A warranty would solve the first problem and might even give the cred to fix the second one.
Is there a way of getting the conversion done in France?
Old 03-01-2016, 09:28 PM
  #432
s2ktaxi
s2ktaxi's Avatar
So, I'll ask the obvious question - is there a dyno with just the X51 and intake manifold update?
Old 03-02-2016, 12:40 AM
  #433
user1029
user1029's Avatar
I agree that a warranty would make it so much more palatable from a long term standpoint both on the 4.0L conversion and X51 heads
answer to your question: Name:  FqwZoiZ.png
Old 03-02-2016, 12:49 AM
  #434
Joe Weinstein
Joe Weinstein's Avatar
*I'd* want more power down low-to-mid. I'd so much hope a tune could get rid of that
dip in torque we see in the graph between 2500 rpm and 4500 rpm.
Old 03-02-2016, 02:03 AM
  #435
CAlexio
CAlexio's Avatar
The headers will take care of this dip, which has a nadir at 3600rpm.. Lots of graphs from the different manufacturers show this... Not to mention, those of us who have installed headers will attest.
Quick Reply: GT4 - Unlocking the Power Potential!
