Sponsored by: APR
Upcoming Cayman GT4
Old 02-05-2015, 10:27 AM
  #376
nxfedlt1
nxfedlt1's Avatar
Is PTS available now? I'm 7th on the list with the Ft Worth dealer.
Old 02-05-2015, 10:47 AM
  #377
4forme
4forme's Avatar
18" and 19" wheels will clear the 380mm steel rotors. 410mm PCCB's will require 20".
Originally Posted by drwuss
What about smaller than 20 inch dubs on this thing? 2k for tires is a lot of coin…
Old 02-05-2015, 10:51 AM
  #378
drwuss
drwuss's Avatar
Thank you for this information! Although now I want one even more...
Old 02-05-2015, 10:53 AM
  #379
Dr.Bill
Dr.Bill's Avatar
That will depend on the suspension geometry as well. With the 991 GT3, 18" wheels will not work. And it takes some manipulation to get 19" wheels to work.
I really hope 18" wheels will fit the GT4. I don't get the fascination with 20" wheels. Are they building a show car, or a track car?
Old 02-05-2015, 10:59 AM
  #380
drwuss
drwuss's Avatar
Dependence on te 20" wheel is enough to keep me out. How do we figure this out?
I also would like to know if there is a function that would keep my ham handed *** from grabbing second gear after winding out third.
Old 02-05-2015, 11:11 AM
  #381
sasportas
sasportas's Avatar
18 inch wheels only offer tires that are nearly 2 inches shorter than the 27.3 inch tall 20 inch tires.
19 inch wheels get you closer to the 27 inch height but in tires that are too wide for the front (265's).
Anybody figured this tire situation out yet? Otherwise we may be stuck with 20 inch sport cups.
Old 02-05-2015, 11:34 AM
  #382
Phokaioglaukos
Phokaioglaukos's Avatar
Are shorter tires an issue if they are shorter all the way around? ABS should be able to cope as long as there is not a height mismatch front to rear.
It may look funny, though.
Old 02-05-2015, 01:06 PM
  #383
audipwr1
audipwr1's Avatar
Not in the first production run
Old 02-05-2015, 01:30 PM
  #384
Craig67
Craig67's Avatar
Club Blau looked incredible in Daytona.
Originally Posted by Z356
My favorites? Of the approved PTS for the 991/981 model, I would consider the following non-metallic solid colors:
In the Blues:
'Riviera'
'Mexico'
'Voodoo'
'Aetna'
'Gulf'
'Maritime'
In the Yellows:
'Signal'
I am not partial to metallics in PTS. As you can see, I tend to prefer the historic/vintage colors...although some in my list (like Voodoo, Riviera and Maritime) are not that 'old' in historical terms at Porsche!
Good luck to you, Green Lantern & others in your quest for a gt4 in PTS. I approve & support your efforts 100%! Keep us posted if you get the opportunity to do it!
Notice that 'Acid Blue', color code 354, was being tested by PAG as of 9/2014. That color, or a shade or two from it according to Pete Stout, turned out to be the 'Club Blau' selected for the PCA's 60th Anniversary Edition! And as I said before, it would not surprise to see 'Acid Blue'/code 354 on the approved PTS list sometime in MY2016!
Saludos,
Eduardo
Carmel
Old 02-05-2015, 01:48 PM
  #385
4forme
4forme's Avatar
Good point. I meant to originally say 18" May work and 19" will work but either will clear 380mm rotors. The 991 GT3 manipulation is simply bending a bracket by hand slightly to clear.
That will depend on the suspension geometry as well. With the 991 GT3, 18" wheels will not work. And it takes some manipulation to get 19" wheels to work. I really hope 18" wheels will fit the GT4. I don't get the fascination with 20" wheels. Are they building a show car, or a track car?
Old 02-05-2015, 01:57 PM
  #386
STALKER99
STALKER99's Avatar
Anyone know how much PTS will be roughly?
Im think Voodoo Blue, Fashion/Dolphin Grey, but I think the GT4 will look stunning in Grey Black.
Anyone else know or are familiar with the PTS grey/white colours because when you google fashion or dolphin grey they all similar.
  #387
PointBy
PointBy's Avatar
Dependence on the 20" wheel is enough to keep me out. How do we figure this out?
Rule of thumb on the wheel to brake ratio: wheels typically need to be four inches larger than the brake disc. Since the GT4 is running big calipers on 15" discs, a minimum of 19" wheel must be used. It's not just for looks.
Just looking at the images on line, the stock calipers barely clear the 20's. Finding a 19 to clear would be difficult, IMHO.
Old 02-05-2015, 02:08 PM
  #388
orthojoe
orthojoe's Avatar
18" wheels will clear the brakes, but the problem on the 991GT3 is the lower control arm bolt. It rides VERY close to the barrel of the 20" wheels. You can run 19" wheels if you flip and modify the bolt so it doesn't rub. 18" won't work with the 991 GT3 rear suspension. It will be interesting to see if 18" will work on the GT4. I wouldn't rule it out. We just need to see once cars are delivered.
Old 02-05-2015, 02:24 PM
  #389
tcsracing1
tcsracing1's Avatar
Originally Posted by cgt04115
There wont be a spyder replacement....... Maybe some GT3 bits on a Boxster but a Spyder really is unique unto itself and always will be.
agreed. I want one for my collection.
Old 02-05-2015, 02:26 PM
  #390
tcsracing1
tcsracing1's Avatar
Sweet - I'll grab another one! The Cayman R was the most fun car I've ever owned!!
Cayman R is a great little porsche. I would not look away from buying one especially if the prices get lower.
Quick Reply: Upcoming Cayman GT4
