Sponsored By:
Sponsored By:
9Y0 common problems and failures
Old May 8, 2025 | 02:05 PM
  #121
TGKelly's Avatar
TGKelly
Does anyone know what the codes P1D7400 and P1D7500 are? My 2025 Cayenne S mentioned above (cylinder misfiring and battery issues on 800 mile new car) is still in shop and not sure what is planned to give me comfort that car is reliable in light of starting/battery issues. These two codes came from service tech and are in addition to the various P0300, P0302 and P304 codes I saw on my OBD scan. Any thoughts appreciated!
Old May 8, 2025 | 02:34 PM
  #122
ThomasWShea's Avatar
ThomasWShea
I just tried searching porsche obd P7500 and porsche obd P7400...stuff comes up, but I am unsure if P7500 is the same as P1D7500.
Old May 8, 2025 | 04:00 PM
  #123
chassis's Avatar
chassis
Misfire can happen from many causes small and large.
Loose or paint-covered ground point, loose ignition coil connector or burned and broken valve, bad hpfp etc etc. Need an exhaustive diagnosis.
Old May 8, 2025 | 07:28 PM
  #124
retom's Avatar
retom
If I remember correctly, these are codes from the ECU and are related to misfires. These 2 codes appear in combination of P0300, P0301, P0302, P0303, P0304 and CEL.
Old May 8, 2025 | 08:29 PM
  #125
ThomasWShea
is it true that the last digit is the cylinder number?
Old May 9, 2025 | 12:41 PM
  #126
TGKelly's Avatar
TGKelly
Thanks everyone for info! Dealer says all codes erased and cannot find reason for the misfires or the battery discharge fully next morning. They want me to drive to see if it happens again. It is a little over a month old! I said unfair for me to cross my fingers and hope it doesn’t happen again! Discovered P1D7400 and P1D7500 relate to possible cat damage due to frequent misfires. They said it only happened once. But I started, it labored for a few min and then I shutoff and restarted to same problem. Did this sequence maybe 5 times before it corrected. So imho it was misfiring for at least 15 min. At 500-700 RPMs, misfires occurred about 8-11 thousand times. Speaking with GenMgr Monday to discuss where we go from here. They don’t want to diagnose without more!?
Old May 9, 2025 | 12:51 PM
  #127
chassis's Avatar
chassis
They are gladhanding you and you need to play their game.
It’s a new car so warranty will cover the cost if any. Time and inconvenience will be incurred so practice your best patience skills.
Old May 9, 2025 | 02:13 PM
  #128
ThomasWShea
@TGKelly and get an antigravity sc-10 charger. rule out battery. why would you not do that?
if your vehicle had a misfire condition that is ongoing it will reoccur.
also, buy good gas, that can’t hurt. i buy gas from a cool locally owned station where they work on tons of older porsches and classic cars. they are very clean and picky. they say hi when you come and they sell 92 octane ethanol free gas. does it pencil cost wise as far as mileage, no. but, i have talked to them - they maintain their pumps and are very quality conscious. and it seems like i do get an extra mile per gallon w ethanol free. you don’t have to buy ethanol free. shell is what i go for out of i am out of area. no costco, nothing wrong w costco, it just bugs me that they only sell 91 - they claim it tests higher, but if that was true all the time it would be labeled higher.
Old May 9, 2025 | 02:24 PM
  #129
TGKelly's Avatar
TGKelly
A BIG thank you for everyone that has helped with my 25 Cayenne S issues! Really appreciated! Will keep you apprised of status as we move forward.
Old May 9, 2025 | 07:14 PM
  #130
retom's Avatar
retom
Good luck!
Old May 17, 2025 | 10:08 PM
  #131
chassis's Avatar
chassis
Updated list:
  • .1 lurching, surging or lurging when downshifting - believed to be related to the dual mass torque converter damper and lockup clutch release programming. Most noticeable with light braking 3–>2 downshift. After entering 2nd gear the lockup clutch releases and engine inertia creates a torque surge. Lockup clutch status can be seen live with an OBD device. https://rennlist.com/forums/cayenne-...own-shift.html
  • controllable water pump shroud seal failure - causes collateral damage to the vacuum system - can affect V6 and V8 engines. Can occur with no CEL and no overheating. Can be observed by low coolant level in the reservoir and dried coolant on any component for example coolant shutoff valve or vacuum solenoids. Also experienced on Audi RS5 and Macan installations. https://rennlist.com/forums/cayenne-...how-often.html
  • oil vapor separators - regular maintenance item on all modern German direct injection engines - can cause excessive crankcase vacuum or pressure which can fail seals and gaskets - can affect V6 and V8 engines. DIYable. https://rennlist.com/forums/cayenne-...r-failure.html
  • PSCB noise complaints when new and apparently an emerging issue with “bumps” on the rotors as they age. Porsche no longer offers PSCB so it suggests they are aware of the problems. No solution to noise, warranty rotor replacement with “bumps” might be possible depending on the dealer and your persistence. https://rennlist.com/forums/cayenne-...nne-turbo.html
  • early .1 PCM5 screen goes black without warning. Eventually it reboots itself and returns to normal function.
Old Jun 3, 2025 | 07:47 AM
  #132
Cayenneto911's Avatar
Cayenneto911
@TGKelly My 2024 Base with 7800 miles was misfiring. I posted my experience in another thread but am reposting it here in case it can assist you. I was experiencing misfires on cold starts. When I took the car in the first time they took the coil from the cylinder that misfired and moved it to another cylinder. After that cylinder misfired they determined I had a bad coil and replaced it. I took the car home and continued to have cold start misfires. When I brought it back the consulted with Porsche NA and replaced all the fuel injectors. I have had the car back for one week and so far so good. Good Luck.
Old Jun 3, 2025 | 10:35 AM
  #133
TGKelly's Avatar
TGKelly
Default Need Help 2025 Cayenne S Coupe Not Starting UPDATE
Thanks again to everyone for advice and info! Dealer said Porsche would not authorize additional diagnostic work and wanted me to just drive it and see. I politely gave dealer a list of other Cayenne S models available in the area as well as GTS models that I would accept on trade. I simply argued the car failed to start 33 days into ownership so I was “revoking my acceptance” of it under Uniform Commercial Code. Dealer is great… few days later agreed to allow $ for $ trade into new one. I upgraded to GTS (paid diff) and love it so far. Unfair of Porsche to expect new owner to “test drive” new car to see if it fails to start again! Either find and fix root cause of problem (restoring confidence) or take back… seems right thing to do.
Old Jun 3, 2025 | 09:25 PM
  #134
ThomasWShea
Which exhaust does your GTS have?
Old Jun 3, 2025 | 09:58 PM
  #135
TGKelly's Avatar
TGKelly
I have the standard exhaust, not sport. I needed to have one with a hitch so couldn’t do the sport exhaust. Still sounds awesome!
