Sponsored By:
Sponsored By:
9Y0 common problems and failures
Old Feb 14, 2025 | 01:58 PM
  #76
XLR82XS's Avatar
XLR82XS
2021 GTS ~7K miles. 1 month before warranty expiration popped an engine light. During and oil change I saw a VERY tiny drop of oil on the head of an oil pan bolt.
- Faulty thermostat
- Leaking oil cooler
Dealer had to remove from bumper and radiator to access t-stat. (fender trims had to be replaced) Turbo removal to access oil cooler. The oil leak was large enough to run down the engine and collect at the oil pan.
Typical VW/Audi. I wish Porsche would make their own V8s again. Anyone else see these issues?
Old Feb 14, 2025 | 03:17 PM
  #77
chassis's Avatar
chassis
Thermostat (and water pump and coolant shutoff valve) are somewhat common.
V8 requires front end disassembly for front-of-engine component replacement. V6 does not.
Oil cooler leak is uncommon so far. What was the CEL for? Did you read codes or did the dealer tell you which code it was? Did you have low coolant or low oil level?
I don't want any of the previous Porsche V8s. Exploding intake manifolds and a host of other problems.
Old Feb 15, 2025 | 09:26 AM
  #78
XLR82XS's Avatar
XLR82XS
Engine light was for thermostat. Coolant and oil levels at spec. I had great luck with the the V8 in a 2013 Cayenne S and my 928 GTS 5.4L is holding/running well.
Old Feb 19, 2025 | 06:12 PM
  #79
DrJupeman's Avatar
DrJupeman
Wow, I'm on 208k+ miles on my V8 2009 Turbo S.
Old Feb 26, 2025 | 06:44 AM
  #80
lucian95's Avatar
lucian95
I just came across the following on Youtube (see below), listing some issues (major/minor) with Cayenne Turbo 2019-2023 generation. While most of the potential issues he touches upon are known, the small issue with belt tensioner comes up after he discusses water pump (at 5:00 min mark). Has anyone on this forum experienced issues with a belt tensioner and is this another potential item one should proactively address. The guy suggests after 6yrs or 60k miles might be a good time for replacement. Is this a big job and what are the symptoms?
Old Feb 27, 2025 | 01:04 PM
  #81
RDPorsche58's Avatar
RDPorsche58
Default Soft close doors
2024 Cayenne Base with 7500 miles. The soft close function works intermittently on both driver/passenger rear doors. They work properly maybe 20-40% of the time. I can hear the soft close motor actuate to close the door but the door does not completely seal shut. Initially brought it to the dealer where they kept the car for 17 days. They had to replace the actuator, soft close motor and reprogram/initialize the doors. They advised everything was fixed and the doors were functioning 100% correctly. Brought the car home only to find that both rear doors are malfunctioning intermittently again. It’s scheduled to go back to the dealer tomorrow for diagnosis.
Prior to the 2024, had a 2020 coupe with soft close that functioned correctly 100% of the time. Have also owned numerous vehicles with soft close doors that were problem free so I’m curious to see if others here have encountered this? I’ve seen posts where cold weather may have played a part but we’re in Southern California where this shouldn’t be an issue.
Old Feb 27, 2025 | 01:11 PM
  #82
chassis's Avatar
chassis
Soft close doors take some learning to “do it right”. Slowly bring the door to the latch, and softly let the latch make the first click. The motor does the rest of the work.
Letting the door go with a “soft slam” or anything remotely like it results in inconsistent operation in my experience.
Old Feb 27, 2025 | 01:18 PM
  #83
RDPorsche58
I agree, that is the proper way to utilize the soft close function and it is the method that I use to replicate the issue. The front doors latch correctly 100% of the time. The rears, not so much.
Old Feb 27, 2025 | 01:29 PM
  #84
function12's Avatar
function12
We had issues with our 2019 too. Dealer could never fix it.
Old Feb 27, 2025 | 03:01 PM
  #85
chassis's Avatar
chassis
My left rear soft close door gets wonky in cold weather. Driver’s door works 100% of the time assuming the technique is done correctly. Right side doors - dunno because I don’t use them and my passengers don’t know how/unwilling to use the soft close feature!
In the rare occasions I use the right side doors, the soft close feature works.
Old Feb 27, 2025 | 03:25 PM
  #86
aututto's Avatar
aututto
Threw in the towel with our 2019 base this week, worst car I've ever owned unfortunately. Which hurts to say as our 958 diesel was the BEST car I've ever owned. I'm afraid there is too much audi in these new cayennes, the mechanical and cosmetic failures seem to never end with it
Old Feb 27, 2025 | 05:54 PM
  #87
XLR82XS's Avatar
XLR82XS
Exactly. A shame....
Old Feb 27, 2025 | 06:08 PM
  #88
retom's Avatar
retom
There was and is a lot of Audi in all generations of the Cayenne. Because it is a car based on the platform of the Audi Q7 4L and 4M.
Old Feb 27, 2025 | 06:41 PM
  #89
chassis's Avatar
chassis
Better said, Volkswagen. 955/957/958/9Y0=Touareg
Old Feb 28, 2025 | 01:56 AM
  #90
RDPorsche58
Quite disheartening to say the least. The 2024 9Y0.2 is a fantastic upgrade, but to have an extra cost option not operate 100% as designed sours the ownership experience. Besides a rear hatch rattle that was easily fixed by the dealer, our prior 2020 e-hybrid coupe was rock solid with zero issues for 36k miles AND the soft close doors never missed a beat. It goes back to the dealer tomorrow so I’ll report back…
