Transfer case
#857
#858
I took my 2015 Cayenne S in for an oil leak that my Indy found during an oil change. Since it’s in, I figured I’d mention some other stuff that I think could be the TC:
A lot of clicking noises when my window is down, slowly accelerating through a drive through. It only makes the sound when I accelerate.
A whirling sound under acceleration when cold.
Very occasional “bump” when backing out of garage.
Occasional lag or hesitation, sometimes with a “bump” when I decelerate around 3 gear and then quickly accelerate again. Sport mode makes it very jerky and harsh.
They started asking me questions that sound a lot like they suspect a bad TC.
Oh yeah, occasionally when I’m idling, the idle will go up to 900rpm and I’ll have to push down harder on my brakes to keep from moving.
Got a loaner Macan 2020 and I’m at work waiting for an update still. I miss my car already!
Sound like TC issues? Normal driving (just putting around) it’s smooth enough. Getting on it, it can get jerky.
Edit: Add me to the list. Dealer confirmed a bad TC. Swapping under CPO warranty. Shew!
It was the ticking and rough shifting that got them to poke around further.
#861
Just purchased 2015 Cayenne S with 55 k miles. Had been feeling bumpy on acceleration, like accelerating on a rough road or bad tires, replaced transfer case fluid yesterday with
Todd
Annapolis MD
RAVENOL J1C1125 Transfer Case Fluid TF-0870 - Full Synthetic (1 Liter)
And and felt an immediate improvement. Planning to replace it again in 6 months and then at every other oil change, annually. Was very easy to do, especially with the Ravenol container and it's beautiful pour spout. Re-used original plugs with one wrap of pink heavy duty Teflon tape. I did use a little high temp thread sealer in addition on the lower drain plug as I didn't trust sealer alone since it's nearly impossible to remove all the oil from the female threaded hole of the TC.Todd
Annapolis MD
itgrunt (07-29-2022)
#862
My 2015 Cayenne S was feeling bumpy on acceleration but just changed fluid with Ravenol and there was an immediate improvement.
Todd
Annapolis MD
#863
Received 1,149 Likes
The test Porsche tells them to use is to disconnect the power feeding the stepper-motor on the transfer case and go drive it. If the symptoms don't change - it's not the transfer case. If they do change - it's transfer case time.
#864
Just did the TC fluid swap on my 2016 CD with 51k miles. Holy crap. Nasty, brown, burnt smelling oil came out, clean, clear, somewhat not so smelly fluid went in. I reused the fill and drain bolts with some thread sealer, but when I go to do this in another 50k, not only will the TC get its fluid changed but the front and rear diffs as well.
Can't believe Porsche would go as long as they recommend on a fluid change interval and wonder why they're having issues with TC's...
#865
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
2013 Cayenne Base Model with 79k miles was experiencing stumbling upon acceleration. Most notably going uphill. Problem got progressively worse.
Replaced the transfer case fluid with the Ravenol J1C1125 from Amazon. Take note as the label now shows "Transfer Fluid DTF-1" as opposed to "TF-0870" but the part number J1C1125 matches.
In any case, my problem has been resolved with the fluid change! Wanted to thank this forum and members for all the information provided here!
The following 2 users liked this post by jferguson6:
dollarlongnecks (01-23-2020),
#866
Todd
Annapolis MD
#867
Hi guys,
I need some advice from you guys about how to deal with this situation. I just got a used 2013 Cayenne Turbo 65,000miles a few months ago with 36 months extended warranty. A few weeks ago, the car "jolting" going from 3rd to 4th gear, the dealership replaced the new Transfer case, the shaft, and the rear differential. But the "jolting" is still not completely fixed, it's just improving and becomes less noticeable. Now the dealership is suggesting to replace the transmission. But the thing is the extended warranty might not cover 100% of it. So what would be my best bet? I know I can try to replace the fluid for the fix. But is this a real fix?
#868
It's unlikely changing the fluid will help at 65,000 miles unless the car was badly abused. It would be worth checking the transmission oil level since low fluid can cause those types of symptoms. Why wouldn't the extended warranty cover it? And who is the warranty from? People might want to avoid that warranty company.
#869
Hello all, posting again to report that after 27,000 Porsche just confirmed I will be needing my second transfer case. The original TC has 73K on it. The replaced TC was part number 958-341-011 but seems that number has been discontinued. Since I am just over 100k, my dealer said Porsche usually wont help, but since I am a good customer they agreed to fix my Cayenne a second time as long as I pay labor. My question is, does anyone know what the new part number is and have they finally figured out a permanent fix? Also, how many miles are people up to with changing the TC fluid regularly? I am trying to decide if I want to keep or bail on my Cayenne after the second repair is done. Frustrating, because other then the TC, my 2012 Cayenne S really does it all from trailering to the track, to daily driving. Suggestions? Thank you in advance :-)
#870
Todd
Annapolis MD
