Diesel Cayenne and VW emission issue
#1981
Originally Posted by visitador
Welcome to the club. I believe the VW Toureg 3.0 diesel has a goodwill program but not extended warranty. Porsche only has the extended warranty. I don't think Audi is providing anything to the 3.0 diesel owners.
[Edit: As an added note. Porsche dealers are not allowed, I believe, to sell service loaner CDs that they own. If they said it was a service loaner, then it is total misrepresentation by the salesperson]
#1983
Reuters reporting a deal has been reached. So much for no leaks.
http://www.autonews.com/article/2016...oreUserAgent=1
Looks like the newer cars will be a fix only.
#1985
Originally Posted by WAMIII
As a new member here - not clear on whether I need to be signed up wit law firm in order to be part of class action - Advice greatly appreciated
#1986
So, as 3.0 owners, unless new regulations are set by EPA/CARB, we do not need to do a fix and take any compensation. The used car market may differentiate between fixed and non-fixed cars. I bet the 3.0 non-fixed cars will command a higher resale value. That may be enough for some of us NOT to take whatever compensation is offered.
As an aside, I doubt the EPA under a Trump administration will be able to set any regulations requiring us to accept a fix.
#1987
Call Porsche Cars North America and tell them you own a Cayenne Diesel and you have not received any information from them. Give them your VIN and you should be ok from then on. That is what I did and now I get emails and regular mail etc. You may have to do it twice, but they will eventually get you noted as the owner of record.
#1988
And if the fix to the newer cars "kills" them, it'll open a whole new can of worms. As with everyone, I'm very eager to see how this fix is going to work.
#1989
Originally Posted by skiahh
Where, exactly, is the cutoff for "newer" cars?
Yup, the fix is the big unknown
#1990
That's what I think, too. But there was some discussion of some of the early CDs (13s and maybe some 14s) needing more than the newer ones to be fixed.
#1991
I'm not excited at the prospect of simply a software fix....
....unless it drives like the 2016 CD loaner I had. That thing was PEPPY!
#1992
The lead attorney says there is no deal, the report is not true.
http://www.usatoday.com/story/money/...alks/93896808/
#1993
As I said previously, we are being played by both the regulators and VW. Both sides use the media to float trial balloons. I am sure they read what we say here
#1994
Do you know the build date of your CD? I saw previously it is a 2013, but I'd love to know if it was built around the beginning of 10/2012.
What was the main symptom that led to the RMS replacement previously? Your story is sounding similar to stronbl's saga:
http://www.renntech.org/forums/topic...el-fluid-leak/
I saw a similar leak on mine (built within a week of stronbl's) as documented in that thread, but I'm about 32k now and it hasn't returned.
#1995
Regardless of if your state requires it or not, however, the first time you have to take it to the dealer after the fix is readily available you can bet on it being applied.
