What Did You Do To (or With) Your Cayenne Today ?
Old 10-26-2020 | 10:52 PM
  #781
jeff spahn's Avatar
jeff spahn
Originally Posted by Petza914
Jeff, Nice. So how tough was it? Did you use the banjo fittings that came with the kit or different ones (silver)?
Pete
I got the banjo fittings from a local hose shop. Took the catch can down and they found a fitting. Then used an adapter from the catch can hose to 3/4" hose, then from 3/4" hose to the 1" molded hose I got at Advance Auto Parts. I just went behind the counter to their hose stores until I found a hose with a few bends in it I thought would work. I took off the elbow from the 3 way PCV valve, stuck the 1" hose on there and clamped it to the valve cover and the rest of the 3way PCV valve. Made a mount from the top of the catch can to one of the beauty cover mounts. Probably should paint it or something but right now it's in test mode. Gonna see how much oil it catches, or if I even have it hooked up the right way or backwards.
Old 10-27-2020 | 11:40 AM
  #782
jacqueusi's Avatar
jacqueusi
I'm interested in a set of guide pins please.
Old 10-30-2020 | 10:45 PM
  #783
19psi's Avatar
19psi
Installed 4 new hatch lift struts today. I figure they're all junk with a 3 to 4 year life span, and since I had an Amazon gift card, I bought the cheapest generic Chinese set I could find.
Total cost was $64 delivered through Prime. Main were $45 and glass were $15. Install was WAY easier than I thought it would be, so if I have to do them again in a year or two, it's no big deal.
The Stabilus that came out were about 1 year old when I bought the Cayenne, so I have nothing to compare with when new.
These things are quite strong, takes two hands to close. Is this normal for brand new struts?
No more hatch hitting me on the head, but now it sort of wants to take my head off.
Old 10-31-2020 | 12:53 AM
  #784
Petza914's Avatar
Petza914
https://www.youtube.com/watch?v=npFzUu6svgI
That's awesome, and dangerous. Mine only wants to take my head off on the way down, but since they still lift the door haven't tacked this one yet.
Since I'll keep my cars forever, I'll buy mine from FCP Euro so they buy every set after that for me.
Old 11-13-2020 | 02:29 PM
  #785
Navaros911's Avatar
Navaros911
That's not normal for the OE stuff to do. The Chinese ones, well, this is better than the other way around
In my experience, which was not on a Cayenne, is that these don't last as long and go from super aggressive opening, to slow opening and being noisy relatively quickly.
It seems to me like these knock off ones failed quality testing, or had not quality testing at all. I stopped buying them because their performance is not consistent.
Since they are on, use them and they will probably be fine for a while.
Old 11-13-2020 | 03:49 PM
  #786
Travis's Avatar
Travis
While loading up the hatch, I look up and what do I see? The dang headliner has begun to droop! Argh. So today was researching all the fun this little DIY will entail.
More to come...
Say, "Ahh Crap!"
Old 11-13-2020 | 03:51 PM
  #787
Charles Yost's Avatar
Charles Yost
I replace mine with OEM from Pelican Parts three years ago and no issues! Hope they last another 3 years, The car is an '06 CTT.
Old 11-13-2020 | 06:49 PM
  #788
Petza914's Avatar
Petza914
More to come...
Say, "Ahh Crap!"
Well, that stinks. Though everyone warns people about the Pano roof in the 957, I'm thinking that might actually prevent the headliner from ever falling, as there's virtually no headliner except just a small perimeter area.
frederickcook87 (07-09-2022)
Old 11-15-2020 | 04:00 PM
  #789
Jonobigblind's Avatar
Jonobigblind
As I’ve got an MOT due on Thursday I decided to fix an intermittent fault on a rear parking sensor. £13 part from the online auction place and a couple of YouTube instructional videos made for a good Sunday morning activity.
As I was flying solo I thought the chairs would offer good support (which they did). All seemed to go rather well which was a first for me...
Bonus was losing about three tonnes of crud from inside the bumper which must be good for another 0.2 seconds off the 0-60 time!
Old 11-15-2020 | 07:42 PM
  #790
Glaze88's Avatar
Glaze88
New Lowering Links fitted and some Vacuum Lines replaced
TRINITONY (11-15-2020)
Old 11-21-2020 | 09:50 PM
  #791
Wisconsin Joe's Avatar
Wisconsin Joe
Had a significant coolant leak, coming from just behind & inside the passenger front wheel.
Right underneath the coolant expansion tank.
Not a difficult job, the Pelican write up was clear and easy to understand.
New one went right in, and now no leaks.
Old 11-22-2020 | 12:51 PM
  #792
95_993's Avatar
95_993
While I was under the 955 changing the my oil, I took a quick peek at the serpentine belt. Looked pretty sketchy so jumped in and swapped it out. That thing is huge and really snakes around.
Old 12-02-2020 | 11:21 PM
  #793
TRINITONY's Avatar
TRINITONY
Change the O-rings on the vacuum pump today. This is a bit more painful than switching out the HPFP. I left some of my DNA on the firewall...lol
the lil vacuum line was stuck on there pretty good, so just left it attached.
old rings on left, new on right...
Old 12-02-2020 | 11:30 PM
  #794
Petza914's Avatar
Petza914
Nice job. That belt wasn't good. Good oil choice as well.
Old 12-03-2020 | 12:22 AM
  #795
Glaze88's Avatar
Glaze88
Got a little exhaust work done on the CTT. Not sure how to upload videos but it sounds amazing!
phL (03-30-2021)
Quick Reply: What Did You Do To (or With) Your Cayenne Today ?
