997 GT2/GT3 Forum 2005-2012
Shaping up a new-to-me 07 GT3
Old 03-12-2020, 01:01 PM
  #1156
Tom@TPC Racing
Premium Sponsor
Tom@TPC Racing's Avatar
Default Point of No Return
Here we go, the point of no return. I started 6pm and finished at 3am without taking a break. Hours was consumed by peeling off and scraping off residual adhesive under the carpeting. Even with strong adhesive remover chemical plenty of elbow grease was required while inhaling the nasty stuff.
That stuff not only smell bad, it melts the skin right off...
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
Old 03-12-2020, 01:47 PM
  #1157
jonwb
jonwb's Avatar
He's back!!
Old 03-12-2020, 02:31 PM
  #1158
Tom@TPC Racing
Premium Sponsor
Originally Posted by jonwb
He's back!!
Ha! Did a 991 GT3 "Clubsport" build over the Winter and that had me considered selling the 997 for a 991 but after some thought...997 GT3 4.0 "Clubsport" for the win!
991 GT3 build was a lot of fun though. Here's build thread- https://rennlist.com/forums/991-gt3-...pc-racing.html
Old 03-12-2020, 02:39 PM
  #1159
bmwtye
bmwtye's Avatar
If you havent done them yet, you should also do radiator exit screens.
With the air exits right in front of the front tire, the large vent hole leaves the radiator unprotected against rubber and debris. So I felt this was a must to have a screen in this location. Capital City Motorsports makes a high quality exit screen that was designed for this location. It is made with 3/16 stainless steel frame and 1/2 inch welded stainless screen. Being this screen is in an area that will be exposed to elements, I had the screen coated for extra protection and to blend in with the fender liners.
Old 03-12-2020, 02:51 PM
  #1160
Tom@TPC Racing
Premium Sponsor
Yep! The exit screens is item #5 on my to do list this month. Can't be carrying the extra weight from rocks and rubber! LOL
Old 03-12-2020, 04:32 PM
  #1161
Tom@TPC Racing
Premium Sponsor
Here's the weight reduction-
Engine bulkhead carpet, 5.75 lbs
Rear carpeting and C-pillar plastic trim, 21.75 lbs
Main floor carpet, 12.20 lbs
Center console, A-B-pillar plastic trim, and floor mats, 20.90 lbs
Windshield washer bottle & pump delete, 12.30 lbs when the bottle is full, so let's just call it 5 lbs. I didn't intend on doing this but the Low Fluid message kept appearing and I cannot remember the last time I actually used the windshield washer in 3+ years so out it went.
Total: 65.60 lbs.
I am excited about the weight loss, but will have to add some weight back on with the roll cage.
Old 03-12-2020, 07:45 PM
  #1162
Tom@TPC Racing
Premium Sponsor
Oh I forgot about this piece. Another 1.6 lb for a total of 67.2 lbs !
Old 03-17-2020, 11:23 AM
  #1163
Tom@TPC Racing
Premium Sponsor
The sheet metal brackets on the A-pillar are next to go. They are for holding the plastic trim.
The brackets are riveted on. Thankfully was able to drill out the rivets using an angle drill without removing the windshield.
More glue removal.
The brackets and the AM/FM antennas are worth 1.5 lb. so the total weight reduction is 68.7 lb.
And "if" I run a time trial without the passenger seat that weights 33.6 lb, that'll be a total of 102.3 lb reduction!
Old 03-17-2020, 11:33 AM
  #1164
rbahr
rbahr's Avatar
Full cage? Do you have a trailer :-) ?
looks good
Ray
Old 03-17-2020, 11:35 AM
  #1165
powdrhound
powdrhound's Avatar
Received 1,888 Likes on 1,102 Posts
Nice weight loss! I considered doing this a few years back but ended up simply shaving the heavy foam insulation from the carpets itself leaving just a few small areas around the perimeter so that the carpets still seat properly. The foam insulation is very heavy while the actual carpeting is very light. I dropped close to 25 lbs by doing this and leaving all else the same. The only reason I have not stripped everything form the interior is that on a car other than white the paint is not even and does not look well requiring the interior to be sprayed to make it look nice.
Old 03-17-2020, 12:14 PM
  #1166
Tom@TPC Racing
Premium Sponsor
looks good
Ray
Planning on installing a bolt-in 6 point. Yes I have a trailer, but I drive from my house to the shop frequently in the warmer months.
Thanks!
Old 03-17-2020, 12:19 PM
  #1167
Tom@TPC Racing
Premium Sponsor
Thanks! I thought about shaving the foam off as well, and then keeping the only the top layer. Also considered using lightweight carpet that audio shops use on subwoofer boxes. I ultimately like the bare metal Cup car look.
911Jetta (03-18-2020)
Old 03-17-2020, 03:10 PM
  #1168
DJN
DJN's Avatar
Nice job Tom.....HARD CORE! I like it!
The only thing I see is that lovely carbon fiber e-brake, that is too much bling, better ship that to me!
I am keeping my GT3 stealth with full interior, as it is a DD, and a track weapon!
Old 03-18-2020, 09:55 AM
  #1169
Tom@TPC Racing
Premium Sponsor
Thanks!
Sorry, I'm keeping the CF parking handle...in case I want to drift.
Old 03-18-2020, 11:42 AM
  #1170
DJN
DJN's Avatar
Originally Posted by Tom-TPC Racing
Thanks!
Ha! Damn it! I figured you would find a practical use for it! Enjoy!
Quick Reply: Shaping up a new-to-me 07 GT3
