997 GT2/GT3 Forum 2005-2012
Destructive Torsional Harmonics or How to keep your cam bolts from backing out...
Old 06-05-2015, 03:36 AM
  #166
Ur20v
Ur20v's Avatar
As here.
One five stud patern beter than twins due to odd number... You just need to measure your PCD
Old 06-08-2015, 11:38 AM
  #167
Tacet-Conundrum
Tacet-Conundrum's Avatar
Nevermind
Old 06-08-2015, 10:16 PM
  #168
modoz61
modoz61's Avatar
Originally Posted by Ur20v
As here.
Thanks James
Engine coming our as I type and everything going to be done properly this time
Old 06-17-2015, 07:46 PM
  #169
Ritter v4.0
Ritter v4.0's Avatar
How is it going post-installation with those who have the damper now?
Old 06-17-2015, 08:30 PM
  #170
Ur20v
Ur20v's Avatar
I have been running a damper for a while now. I did a VA test on a dyno but the data was currupt- I was getting interference from some where and as it was a freebie on the dyno I ran out of time to diagnose. The data seemed to show an improvement but the signal noise made it hard to interperate with any conviction.
One side effect is my fire extinguisher which is hard mounted to the roll bar is now silent- the trigger used to rattle and vibrate at certain speeds.
No negative effects noted.
Happy with the peice of mind ready its ready for my 4L+ build.
Old 06-17-2015, 08:52 PM
  #171
usctrojanGT3
usctrojanGT3's Avatar
Received 3,984 Likes on 2,269 Posts
Happy with the peice of mind rand its ready for my 4+ build.
Did you also replace the actuators? I have the damper sitting in my garage but my car still is under factory warranty until Sept.
Old 06-17-2015, 09:08 PM
  #172
Ur20v
Ur20v's Avatar
I am .1 3.6 so they don't suffer the same problems as 3.8's or 4.0's.
I did it becasue I was interested in the science of harmonics and my company does VA (vibration analysis) in the Oil and Gas industry. Also when I do my build I didn't want to suffer oil pump failures etc.
Ranger/Champion had a few issues which were resolved by adding the ATI damper from Jamie. There are others running big builds now using this safety measure as well so hopefully they will chime in.
Mike was going to fit his ATI damper (ex-Jamie) to hi 3.8 .2 until the accuator bolts backed out a couple of weeks ago so unfortuntetly he missed the boat by trying to get to the end of the seasion to fit the damper. Like coolant pipe pinning/welding if you wait its a ticking time bomb.
My advice buy and fit James ATI damper ASAP to your 3.8's and 4.0.
Old 06-18-2015, 11:39 AM
  #173
Ritter v4.0
Thanks for the feedback. I have this on order and plan to fit it before our next event.
Old 07-20-2015, 11:26 PM
  #174
hotwired
hotwired's Avatar
Any more feedback from people who have had the damper installed?
I've talked to several experienced Porsche mechanics regarding the issue with the cam bolts...all of them confirm that this is a common enough problem and that the damper may help. But they also have their own theories and are not sure a damper is a 100% complete solution.
Old 07-20-2015, 11:39 PM
  #175
ILLCOMM
ILLCOMM's Avatar
I am trying to follow the risk level across various GT1-engined cars.
I have a 08 GT2, is this something I must consider? Sounds like the 3.6L might not be affected...
If I ever upgraded to a LWFW, would my risk profile increase?
Old 07-21-2015, 12:30 AM
  #176
ILLCOMM
ILLCOMM's Avatar
Also, despite repeated promises there was never any hard data shared about the impact the damper has on vibrations/harmonics.
Old 07-21-2015, 03:11 AM
  #177
Jamie_GT3
Jamie_GT3's Avatar
Lots of theories out there, I know with certainty mine is working as most other stroked builds have had to do something to combat the harmonics. Mine has no issues, RS Ranger has had no issues after install and had failures before it.
The Damper is not a magic bullet, it reduces the driving forces helping the cam bolts to back out. A replacement to the latest revision of the cam actuators, tighten the bolts with red loctite and install a damper.
3.6L cars don't have as much problem even with LWFW...
Still working on it and will continue to work with those that have received free or reduced priced dampers in exchange for data.
Old 07-27-2015, 02:10 AM
  #178
Ritter v4.0
Default Installed
Now installed
Old 07-28-2015, 06:48 AM
  #179
Ur20v
Ur20v's Avatar
There's a nut missing there....
Old 07-28-2015, 11:53 AM
  #180
Ritter v4.0
Well spotted. Also missing 4 wheels and up on the lift.
A lot of nuts and bolts keep backing out so we are replacing them systematically with better locking ones.
Quick Reply: Destructive Torsional Harmonics or How to keep your cam bolts from backing out...
