my gt3 STOLEN: UPDATE FOUND TORCHED
#331
if you can scan a key remotely with a laptop or other scanning device, all one would need to do is park near the elevator in a parking garage. you could be sitting in the back on a van. when someone parks a GT3 and walks past your van and while waiting for the elevator, you use your laptop or scanning device to scan the key in their pocket. by the time they get on the elevator, you have their codes.
Got a link to an actual use case?
#332
#333
Not possible. To scan a key immoblizer would require being within an inch or closer of the key for awhile. Sure you can RF scan 'all day' for unlock codes from key FOBs but you are not receiving anything from the immobilizer. You really need to have access to the key the way a valet might...hmmm.
As a previous mechanical engineer, this mystery is intriguing....
#334
Thanks, I'm pretty smitten with it also.
I think lots of guys would like to get their gt3's in riviera.
https://rennlist.com/forums/showthre...ferrerid=68228
See post # 23 on page 2.
See what I mean?
Good luck and have some fun with the shopping.
Phil
#335
After the arrest of the dips%&t who has previous convictions for ARSON and is wanted in another state, I am AMAZED that there is still talk that the OP may have been involved.
So I present the following as a possible method for stealing the car WITHOUT the owner's consent.
A little background...Suncoast Porsche sells a replacement key head conversion kit. Basically a 996>>997 key conversion. If you look at the attached install guide, you will see the inside of a modern Porsche key. The black arrow in Figure 2 and Figure 4 point to the transponder 'pill'. This pill is part of the immobilizer system and is an electrical transponder contained in a glass pill. The transponder contains a code that is also programmed into the car's ECU at the factory. When the key is inserted in the ignition the transponder "magnetically couples" to the car and communicates its code. This code has to match the code programmed into the ECU. If it matches the car starts.
Now to the crime.....OP valets the car. The valet removes the transponder pill from the owner's key and sticks it in the car near the ignition key slot so that the owner's key will work normally. He also makes an immpression of the original key and then has a copy of the key cut. This new key will work because a working transponder pill is already in the car.
He gives the duplicate key to a dip**** colaborater, who simply drives off in car in 'less than 60 seconds'. Dip**** gets paranoid or scared when every other car at 3:30 AM has rollers and he is driving the only yellow Porsche in Clark County so he drives to desert and burns car.
At least its plausible.
But like I said in my previous post, this is almost like a puzzle we need to get solved!
#338
#339
At the time of my theft the .1 was going for 100 to 115 (extremely optioned car.)
Now you can find it out there for 85k (a stripper) and low 90s.
It should hopefully wrap up today.
#340
#341
In the last month, the prices of a 997.1 gt3 have recently dropped by about 10k. Mostly due to 2010's coming out.
#345
+1 BUT, OP says that he always had possession of all his keys. This leads me to believe that the "magnetic" code can probably be defeated by having a variable magnet that you adjust while turning the key at the same time (and it would unlock the steering column and start the car once the correct setting is found). But then again, this would also assume that the thief had gotten an imprint of the OP's keys to begin with. Of course, this wouldn't be too hard to do since all you need is a clay bar, fold it in half with the key sandwiched and you just made a mold.
All it takes is someone who knows how and wants the car bad enough.
Sincerely,
Macster.
