View Poll Results: Poll: Have you had bore scoring on your 997.1 or 997.2 engine?
Yes, 997.1 (05-08 MY)
143
14.50%
Yes, 997.2 (09-12 MY)
18
1.83%
No, 997.1 (05-08 MY)
524
53.14%
No, 997.2 (09-12 MY)
301
30.53%
Voters: 986. You may not vote on this poll
Poll: Scored cylinder failure for your 997, Y or N? tell us (yr, 997.1 or 997.2)
Old 12-21-2019, 09:36 AM
  #256
Charles Navarro
Charles Navarro's Avatar
Received 1,113 Likes on 583 Posts
Originally Posted by gary11
How can you scope the bore with piston at TDC?
Old 12-21-2019, 08:41 PM
  #257
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
I developed the bore scoping procedure through the sump due to constant mis- diagnoses from shops and delaers only testing the cylinders through the spark plug hole. Almost all bore scoring starts at the bottom of cylinders, and with the piston at BDC to allow the spark plug hole inspection, the piston ends up covering up the damaged area. The tech then tells the owner that no bore scoring is detected.
Then the symptoms continue, and I end up performing a sump inspection, and find the issue in 30 minutes.
This is a classic.. Any bore scope inspection must end with a sump inspection, IF a spark plug hole inspection shows no issues. There’s no other way to judge the entire travel of the cylinder wear surface.
Old 01-29-2020, 11:47 AM
  #258
T4S
T4S's Avatar
Terrible thread bump to make. My 997.2 9A1 is scored at 75k miles. Fortunately I am covered by Fidelity. I'll get into details soon but I've got a timely question to ask:
Should I replace the injectors? I'm thinking yes. What does that consist of when doing in complete.? Price ballpark I could expect to pay?
Have a new Porsche long block on the way. Would've gone with flat6 had I been caught with my pants down and in control of the situation. TIA
Old 01-29-2020, 12:04 PM
  #259
Charles Navarro
I wasn't aware Porsche had any longblocks. Complete engines haven't been available for quite sometime, unless something has changed. As with the M96, they offer shortblocks and the shop would have to complete the engine to a longblock. There is a factory tool to remove the injectors, however sometimes the injectors do not want to come out. I would indeed put new ones if they are re-using the heads and I would also have the heads rebuilt, as every 9A1 head we've ever seen has had worn out guides.
These cars are now hitting 10 years of age and this was about the same time that we started seeing an influx of cylinder failures with the M96 engines, for what it is worth.
Old 01-29-2020, 12:08 PM
  #260
Flat6 Innovations
Former Vendor
Would have been happy to help, had you been able to wait for us...
Who knows if they have changed anything with the bores on these latest engines. If it happens to you again, then we'll know.
Did cylinder 1 feature the bore scoring?
Old 01-29-2020, 12:10 PM
  #261
T4S
T4S's Avatar
Good information, thanks Charles. For what its worth I tried to angle a 4.0 nickies sleeve through you. I looked at my shop quote again says long block 91A00901RX --- you have me wondering
Old 01-29-2020, 12:13 PM
  #262
T4S
T4S's Avatar
Who knows if they have changed anything with the biomes on these latest engines. If it happens to you again, then we'll know.
YEP 1.
Biomes? Can you please briefly explain? This car may have had a replacement already at 6,875 the data was on porsche database
Old 01-29-2020, 12:18 PM
  #263
Prairiedawg
Prairiedawg's Avatar
Received 1,010 Likes on 542 Posts
What year is the car?
  #264
Charles Navarro
That is indeed a shortblock:
https://parts.byersporsche.com/p/Por...1100901RX.html
Old 01-29-2020, 12:34 PM
  #265
Flat6 Innovations
Former Vendor
YEP 1.
That was auto- correct getting me.
Old 01-29-2020, 12:36 PM
  #266
T4S
T4S's Avatar
2009
Mystery solved.
Was told heads were fine but I'll ask about the guides. I'd say this was found at early stage but do want to be encompassing on proper fix.
Old 01-29-2020, 12:51 PM
  #267
Flat6 Innovations
Former Vendor
2009
Mystery solved.
They likely don't know what to look for with the cylinder heads when it comes to wear.
Old 01-29-2020, 01:05 PM
  #268
Carreralicious
Carreralicious's Avatar
Do you work with Fidelity warranty now? I had read before that you only work with LaSalle. Honest question, as I have Fidelity as well, and was curious if I ever have this problem (hope not).
Old 01-29-2020, 01:24 PM
  #269
Flat6 Innovations
Former Vendor
Hell no!
I'd rather bash my head into the wall as to try and work with an engine claim with anyone other than LaSalle.
The last time I accepted an aftermarket warranty other than LaSalle was 2009. I turn away work every week if a warranty company is in the mix. I won't even talk about it.
Old 01-29-2020, 01:29 PM
  #270
Carreralicious
Hell no!
Ok, thanks for clarifying. I just mentioned that cause the guy with the engine problem here (T4S)...he mentioned he had a Fidelity warranty.
Quick Reply: Poll: Scored cylinder failure for your 997, Y or N? tell us (yr, 997.1 or 997.2)
