TranzIt BLU HF Install in a 997.1TT - PCM 2.1
#61
can someone who has this installed run a test for me?
Pair your iPhone with the Tranzit blu, but don't stream anything. Turn the volume up and listen for static/white noise that increases in volume for a few second and then resets to the lowest initial volume?
Trying to understand if I'm the only person having this issue (its very audible during phone calls when no voice in transmitting).
Thanks!
Thanks!
#62
I haven't had this issue either. What kind of phone are you using? Is the Bluetooth volume on the phone turned up all the way? I do get white noise if mine is not because I have to turn the radio up really loud to hear whatever is coming thru the phone. But with the phone's Bluetooth volume maxxed out the radio volume is at a more normal level and I don't notice this issue.
#63
I just suck it up--it was less than $100. I didn't expect perfection. I am actually quite happy with the product given the price and ease of installation.
#64
Thanks all for th
Thanks all for the feedback. It's livable - just trying to validate my install. I sent an email to tech support at iSimple and got no reply - not entirely surprising.
I'm using an iPhone.
#66
I've no idea whether it was the right thing to do or not really, but I wired it to the steering column. AFAIK it just has to go to ground somewhere.
Pics on this thread show where I put it (same place): https://rennlist.com/forums/997-foru...o-a-997-a.html
#69
Could maybe someone confirm that this Amazon link is for the correct antenna cable (2007 C2)?
I am not sure I understand the (for me) subtle differences between the different cable types.
Thanks very much!
Thanks very much!
#70
I recently installed this on my '07 C4S (PCM 2.1) and used the following adapter which I ordered from Amazon, worked perfectly:
Metra 40EU30 2002-Up VW/BMW/European Vehicle Antenna Adapter Cable Kit-Add CD with FM Modulator:
Note the tranzit blu unit has antenna in/out cables hanging from it already so you don't need a "y" cable.
Regards,
Sean
Amazon.com : Metra 40EU30 2002-Up VW/BMW/European Vehicle Antenna Adapter Cable Kit-Add CD with FM Modulator : Vehicle Audio Video Accessories And Parts : Car Electronics
Regards,
Sean
#71
Metra 40EU30 2002-Up VW/BMW/European Vehicle Antenna Adapter Cable Kit-Add CD with FM Modulator: Amazon.com : Metra 40EU30 2002-Up VW/BMW/European Vehicle Antenna Adapter Cable Kit-Add CD with FM Modulator : Vehicle Audio Video Accessories And Parts : Car Electronics
Regards,
Sean
Regards,
Sean
#72
I cannot manage to remove the radio from my 997.1 so have to sell mine, unused.
30% off new price, shipped USPS to Conus.
Comes with antenna socket adapter cables, boxed, instructions, new.
Please PM me if interested.
SOLD - thank you.
SOLD - thank you.
#73
Yes the directions on page 1 of this thread are right on. Except I have a Cab with Bose which is unique, the sub on Cabs are up front on the right side instead of the back, was simple to remove though; first pull trim piece off, unscrew bolt, shift carpet panel back and out, then another screw.
Regards,
Sean
Regards,
Sean
