Installed Rennline motor mounts. I chose the street rubber. Too rainy to take it out for a drive right now, but it should get better this afternoon.
Originally Posted by tegraphile
Let us know how the ride is. This is next on my list after I get the sport seats installed.
Got out for a ride today and definitely noticed a difference. I can feel the engine singing along like a sewing machine. I don't know but I am sure the mounts were original with 52k on the clock.
I picked up the 50W version and they are bright. They have an 80W version (an incandescent equivalent rating, I assume) if you want to try that.
Replacement isn't too tough, just takes time. Remove the light, undo the harness (there is a small tab that I stuck a flat blade driver into to get it to disengage), undo the 7 torx screws holding the tail light cover on, then carefully pull back the cover. Remove the 2 wires going to the bulb. The light itself is held in with 2 more torx screws. Install the new bulb, re-attach the connectors. Next step is a bit more tricky. The rubber gasket will be stuck on the housing most likely. To make sure it seats properly, carefully remove it (making sure not to tear it) and then place it into the groove of the cover. Then you can re-attach the cover and tighten down the screws.
