What did you do to your 997 today?
Old 12-15-2018, 08:18 PM
  #7696
Seanlabonte
Platinum Dealer
Seanlabonte's Avatar
Originally Posted by GoldenGorilla
I went skiing.
So bad ***
Seanlabonte is offline
Old 12-16-2018, 12:53 AM
  #7697
sandwedge
sandwedge's Avatar
Received 1,040 Likes on 735 Posts
Originally Posted by Vincent713
The black C4 looks nice but do they all sit that high off the ground?
Every non-S 997 I've seen sit mighty tall off the ground. Look at the two pictures below of a base 997 and a Prius. The Prius has quiet a bit less wheel gap than the 997 and I doubt the Prius is lowered.
sandwedge is offline
Old 12-16-2018, 02:33 AM
  #7698
Vincent713
Vincent713's Avatar
Yeah that cabriolet 997 looks like a 4 X 4. Definitely needs to be lowered for a better stance.
Vincent713 is offline
Old 12-16-2018, 03:03 PM
  #7699
chekraze
chekraze's Avatar
How much should the Gundo hack cost?
chekraze is offline
Old 12-16-2018, 05:16 PM
  #7700
Iceter
Iceter's Avatar
Mostly depends on whether you remove the mufflers and take them to an exhaust shop or you pay a shop to remove and reinstall them as part of the job.
If if you remove them yourself, any competent shop should be able to do it for $100 or less.
Iceter is offline
Old 12-17-2018, 06:02 PM
  #7701
ATSR
ATSR's Avatar
Installed black headlight trim. Super happy with the result!
ATSR is offline
Old 12-17-2018, 09:24 PM
  #7702
EMC2
EMC2's Avatar
Nice! Looks really clean.
EMC2 is offline
Old 12-17-2018, 10:13 PM
  #7703
ATSR
ATSR's Avatar
Thanks!
ATSR is offline
Old 12-18-2018, 12:40 AM
  #7704
kellen
kellen's Avatar
No pics yet but from my 997.1 S to my 997.2 4S I swapped over my red seat belts, front extended dash leather, X97 shift **** and E brake, basalt black center console, Das shield for the hood.
This week will be a good delivery and install day. Have some suncoast parts including full LED interior, LED rear license plate lights, leather key surround, iPod connection, rear PORSCHE similar to 991 and the first aid kid. Switch for trunk broken and will be swapped.
Next may work with classic 9 or exclusive option for center console, overhead light assembly, steering column surround, fuse box.
Purchased these for my nieces, whose father is borrowing my older car until my brother picks it up in 2 weeks:
kellen is online now
Old 12-23-2018, 07:26 PM
  #7705
ecostellodo
ecostellodo's Avatar
Slave cylinder failed today :-(
Will likely get a new clutch as well. I have 117,xxx on the original clutch. Hope I don't need a new flywheel.
ecostellodo is offline
Old 12-23-2018, 07:53 PM
  #7706
Holly
Holly's Avatar
117K miles on original clutch? Oh my is that a record?
Holly is offline
Old 12-23-2018, 09:59 PM
  #7707
HenryPcar
HenryPcar's Avatar
I had mine slave replaced as part of the clutch job. Yes, that slave cylinder is prone to leak and crack because its made of xxxx, which they have a fancy name for it, but I call it plastic.
HenryPcar is offline
Old 12-23-2018, 10:27 PM
  #7708
zdeckich
zdeckich's Avatar
Got rid of the stock tips
zdeckich is offline
Old 12-24-2018, 02:53 AM
  #7709
Vincent713
Vincent713's Avatar
Love those dual tips, looks so much better than stock.
Old 12-24-2018, 04:30 AM
  #7710
alex911s
Man of Many Porsches
alex911s's Avatar
Fixed LCD pixel issue and Climate control blemish...lol
alex911s is offline
Quick Reply: What did you do to your 997 today?
