What did you do to your 997 today?
#7246
Done installing coilovers for 2 days😂 I've done some DIY stuff on my 86 911 and 74 2002 but mostly bumpers, dashboards and oil changes. First time to DIY the 997 and decided to try the coilovers. 2 shops quoted me $895 and $1000 to install so that is about the amount I saved but the experience was PRICELESS
#7249
Beautiful ride. Hard to find color combo. How do you like the Tubi? Had it on my -09 C4S and loved it. Don't really need the on/off PSE button with the Tubi since it's almost stock quiet up to about $3K rpm. Above that, entirely different.
#7251
In truth, these were done a few weeks ago, but today is a good day to post these mods:
New Aerokit Front Bumper & Lip
Soul Performance Valved Exhaust, with Carbon Fiber tailpipes
Blackview 900 Front & Rear Dashcam cloud-based system
#7252
+1 aluminum magnetic oil drain plug is 19 ft. lbs. In fact, since the oil pan is aluminum, I doubt the factory spec for even the original drain plug is 37 ft. lbs. but maybe.
#7253
With your camera system, you may want to to defeat the overlay of the speed onto the video recordings (you can probably still display it on the screen) as that could work against you in an accident, which is probably the reason you installed the cameras in the first place.
#7255
The Blackview was physically difficult to install, but doable. Any hardwiring into the fuse box is always problematic for my 6'1" frame. 2 days + some cursing + Bourbon + Advil + 2 trips to the Verizon store for a HotSpot device. More Bourbon after that.
Honestly, it wasn't too bad. The App set up and configuration was not easy either. The 4K image resolution from the front cam is excellent and I can watch events around the car from my phone whenever it's parked. There are so many cams available now, it's hard to choose! I'm just a little more relaxed after parking my DD.
#7256
I installed my BlackVue 900 a couple months ago and it was not too bad. Figuring where to tie into the fuse panel took the most time as I wanted it to look nice. There are two big players in the dashcam market, BlackVue and Thinkware. Get the high end model of either one and you are good. BlackVue is the only 4K model currently on the market. I can take a picture of how I tied it into the fuse panel if that would be helpful.
#7257
#7258
Hawk Performance Ceramic and brake dust
#7259
Small thing but ordered key fob protection casing in red resin carbon. Primarily because it looked like candy but so for protection as I just have new key fobs and don't want them worn or buttons come loose again.
