Note to Porsche classic - 997 PCCM plus request
#2371
hi John, are you still offering these? I’m a bit intimidated to try this on my own and would love to purchase from you, if possible.
I’m new to rennlist and unable to message you directly until I have some more contributions.
Thanks!
Thanks!
#2373
nine9seven (06-15-2024)
#2375
#2377
Same, new member and appears I am unable to DM. Would like a double cable to keep the charging intact on the front of the PCCM+ if you have any left..... whoops. Forgot to quote the initial message.
#2378
#2379
Wish there was someone/company would do this for the PCCM+ camera wire, like mail them in ours and they would pin the wire to the pigtail. Yes, I have read the endless threads and everyone seems to rig up their own fix. It's the only thing I would change about the PCCM, the wireless Apple Car Play would be nice too... Haha. But can live without. But the Rear Cam is a basic nowadays.
#2380
The camera trigger wire is what I'm looking for as well. A high end stereo place said they would do it for $1300. That's as much as I paid for the PCCM. I don't drive the Cayman every day but it would be really useful to have a reverse camera for those times when I do. Seems like something around a couple 100 bucks or so would be fair.
AztroRover (06-16-2024)
#2381
So to anyone with the single antenna only setup, it is best practice to not use the included cable (with two connectors on it) for the FM antenna? That is how I originally did it (using the adapter) and I was scanning through old posts before putting everything back together, so I can still undo it and connect it directly if that is best. I will say, the only thing I like about using the various adapter cables is the extra length that you gain but it sounds as if there will be worse audio reception. Thanks!
I installed the bypass cable in the foot well. Would you suggest I remove the bypass and plug the cables back the way they were?
#2382
Johns double cable works great! Hooked a wireless CarPlay unit to it in the glovebox and can still charge using the front if I ever want to. Did not do the back up camera...... but likely will tackle it at some point, just too hot in Texas currently.
I have no volume issues (Bose). It gets as loud if not louder perhaps than the original PCM. I did crank the volume on the PCM 2.1 before I turned the car off. Also, my Bose system did have an extra item in the passenger footwell I had to remove in order to get to the FM control module and bypass. I tried not bypassing and the FM signal was crap.
#2383
SiriusXM question....I can't seem to get the station graphic or album cover display on my screen like you would see in a typical SiriusXM in a factory radio. Is everything else the same with the PCCM Plus? I referring to a display similar the one attached? Is this even an option on this system?
![](https://pisces.bbystatic.com/image2/BestBuy_US/images/products/6488/6488588_sd.jpg)
#2384
I installed my Pccm+ into my Bose cd24 987 and all worked great. Then I decided to install a backup camera and things took a bad turn. I couldn’t get the camera working after connecting to green trigger wire so i pulled out my voltmeter to confirm 12v when in reverse (it did in fact register).
But in the process, when connecting voltmeter to green and the main black, there was a quick hiccup in the car’s electrical. When I turned the car back on pccm worked fine but no audio. I didn’t think I crossed wires but maybe I did?
I checked the fuses and none are blown. When I reinstall the cd24, it works fine with audio so amp is ok. I also used the voltmeter to check all of wires between the pccm and the most box.
Did I blow my most box? My pccm? Anything else to look at to troubleshoot? Any help is appreciated!!!
