Show your 997 Upgraded Steering Wheel
Old 09-24-2023, 11:08 PM
  #226
jalvani
jalvani's Avatar
Originally Posted by 9elvn
Had exclusive options wrap my Protipo and momo plastic hub cover plus the shifter shaft
Woooow. I never even thought of leather wrapping the hub boot. I might have to do that on my ‘88.
Old 09-26-2023, 11:06 AM
  #227
9elvn
9elvn's Avatar
really upgrades the momo wheel to match the rest of the interior in my opinion. Having such a large piece of plastic on the column bothered me so this was a great solution was a bit pricey but when you look at the work and craftsmanship you’ll understand. 99% of ppl will never notice it but I love it
Old 09-26-2023, 01:22 PM
  #228
kellen
kellen's Avatar
991.2 heated carbon fiber multifunction on my 997.2. Prior had multifunction. Required new airbag, clock spring and controller. Total about $2000, $400 steering wheel, $500 airbag (leather), $120 clockspring, $400 controller. $300 coding, $350 gprs adapter. I did the install.
The following 3 users liked this post by kellen:
JAM2 (10-20-2023), joes c4 cab (09-28-2023), VT Blue (10-16-2023)
Old 09-27-2023, 02:50 PM
  #229
THE Z MAN
THE Z MAN's Avatar
Originally Posted by IrishLegend
That's what I want.
Is this wheel smaller than the oem 997.2?
I measured my 997.2 at about 375mm diameter.
Would like a smaller steering wheel. Somewhere around 355mm if porsche makes one.
thanks
Old 09-27-2023, 02:51 PM
  #230
THE Z MAN
THE Z MAN's Avatar
Originally Posted by Recruiter_Bruno
Just love the Macan wheel.
Swapped it out to Alcantara and also went with OEM matt black surround
did yours have the the multifunction wheel before?
Old 09-27-2023, 03:29 PM
  #231
ATX_Native
ATX_Native's Avatar
991.2 GT Heated MF Wheel
Deleted MF and painted the black blanks to a color matching the cluster trim rings (Nissan KR2 Gray).
Also de-blinged the airbag trim ring.
The following 4 users liked this post by ATX_Native:
JAAM (10-17-2023), nydog (10-04-2023), tegraphile (12-13-2023), VT Blue (10-16-2023)
Old 09-27-2023, 06:35 PM
  #232
jalvani
jalvani's Avatar
@ATX_Native Massive upgrade. I'm debating doing the same. The picture makes the 991.2 wheel look a little smaller than the 997. Is it?
Also, were you able to maintain the heating function?
Old 09-27-2023, 06:39 PM
  #233
ATX_Native
ATX_Native's Avatar
Its a GT Wheel so smaller diameter than a normal 991.2 wheel.
You can add or transfer heater function by buying a GPS Adapter Module… https://gpsadapter.us/
Also can add Multifunction if you want that.
The steering wheel heat button is built in to the backside of the steering wheel.
I never added it because I’m in Texas.
Old 09-27-2023, 06:56 PM
  #234
997.1C2S
997.1C2S's Avatar
DIY alcantara and painted trim. EBay chinesium fit is excellent
Old 09-27-2023, 07:29 PM
  #235
slicky rick
slicky rick's Avatar
Looking at these posts, I'm so glad that I did this mod 2010, when the price for a brand new steering wheel with paddles was only around $900
Old 09-27-2023, 10:49 PM
  #236
azaytsev
azaytsev's Avatar
frederickcook87 (10-21-2023)
Old 09-28-2023, 01:33 PM
  #237
Ja-Nein-Eleven
Ja-Nein-Eleven's Avatar
Originally Posted by misterdega
how is it holding up? Any looseness ?
great. no looseness whatsoever. tight and crisp and cool to the touch. been very happy with this mod.
misterdega (09-28-2023)
Old 10-15-2023, 01:27 PM
  #238
misterdega
misterdega's Avatar
I'm thinking of having Dallas rewrap my sport steering wheel in my 997. Anyone have thoughts on if I go thicker or leave it the stock thickness? Anyone who has gone back and forth on thickness and liked one better than the other?
Old 10-15-2023, 01:58 PM
  #239
Petza914
Petza914's Avatar
Received 6,603 Likes on 4,198 Posts
Thicker with contours is so nice. I really like the flat bottom too. Makes entry and exit easier and is a natural resting position for your hands when cruisig down the highway without your wrist being twisted in.
Old 10-16-2023, 07:28 PM
  #240
nellborg
nellborg's Avatar
I did a wheel swap several days ago. My OEM 370 diameter 2011 C2S steering wheel for a Momo Prototipo 350 Heritage with distressed leather grip. My reason for the switch was that I felt like I needed the steering wheel 2-3 cm closer to me because I sort of have short T. rex arms. There was also something about the steering wheel that I didn't quite like though I can't put my finger on what it was. Was it too thin? Too large? Or simply too far away from me?
I preferred to keep the airbag, but the OEM GT steering wheels were so darn expensive, plus that wouldn't have solved the issue of needing the steering wheel closer to me. I read somewhere that an OEM steering column spacer kit was very expensive and very involved. Not sure how true that is, though.
Watched a lot of Youtube videos and read all that I could find on here, and it only took me a couple of hours to do. I took my time because I didn't want to mess it up and I wanted to be certain of each step so that if I ran into a problem, I'd be able to retrace my steps back to the OEM setup.
I used the Works Bell standard hub and a 20 mm Works Bell spacer (I ordered a 10, 15, and a 20 mm spacer with the intention of deciding which I preferred once I got the wheel on the hub). The Works Bell instructions are in Japanese. Google Translate does an ok job of putting it into English. Plugging in the horn and airbag resistor was confusing because the Japanese instructions say to plug the 6-pin connector into the 12-pin's top row and to have the horn wires to one side, while a youtube video shows a guy mounting a momo on a Works Bell hub with the horn wires off to the other side. The 6-pin would only fit the way the Youtuber did it and so far it seems to work fine.
The rest of the install was pretty simple. Here's the final result:
While I think the steering wheel position is a big improvement for me - I can now rest my left elbow on the door arm rest and reach the wheel with that hand, I'm not so sure about the smaller 350 diameter. I'm thinking that if I were driving primarily at 30-60 mph in the mountains or on continuous curvy roads then it might be ok, but I spend lots of time in the 50-90 mph range on the highway and on country roads and that smaller diameter makes the car feel a bit nervous. I do like having more room for my knees underneath the steering column and the easier entry and exit from the car. Maybe I will try a 360 or 370 Prototipo if I don't bond with this one.
Also, the Prototipo Heritage that I have is distressed smooth leather. I really did not like its feel at first because it felt dry and slippery so I started looking at a suede or alcantara replacement. But, after I rubbed in some Obenauf Heavy Duty LP, the leather surface now feels perfect.
The following 3 users liked this post by nellborg:
aasilvia (03-15-2024), Rayien (04-26-2024), waterpanda (10-16-2023)
Quick Reply: Show your 997 Upgraded Steering Wheel
