Cheap Android Head Unit Review!
Old 03-27-2023, 02:20 PM
  #781
myw
myw's Avatar
Originally Posted by DocNik
Done! It looks good and sounds good. Back up camera works. It was a bit nerve wrecking to run the cables, but easier than I thought. My only problem is not finding FM stations under about 99 MHz. Only got a single FAKRA connection in the box, so I tried a double FAKRA, but that killed all sound, in all apps. Not sure how or why. Went back to the single FAKRA. I can live with that.
Mounted a spare SIM-card and now it accesses the internet on its own.
Thanks for all your help, Michael Wong!
Lets see some photos!
Old 03-27-2023, 02:21 PM
  #782
myw
myw's Avatar
Originally Posted by OmairK
@myw, do you know if there is a new version coming up? Trying to get an upgrade for my 987.2 CDR30 with Bose.
Maybe in a year as I havn't finalized the design. May take me even longer as I still wish to learn more before fully commiting to it.
Old 03-28-2023, 03:24 PM
  #783
mumintrollet
mumintrollet's Avatar
More than happy, finally got rid of my CDR30. All I wanted was Apple Carplay!
The following 2 users liked this post by mumintrollet:
Graufuchs (03-28-2023), myw (03-28-2023)
Old 03-28-2023, 05:59 PM
  #784
myw
myw's Avatar
awesome. keep in mind the unit does more then just carplay
the good quality units are literally a decent tablet.
Old 03-29-2023, 04:31 AM
  #785
Belgian_Dude
Belgian_Dude's Avatar
Default APK from PCCM+?
hi guys,
read through the thread with much attention, and ordered an OWTOWSIN 2023 Qualcomm top of the line unit which shall be arriving today normally ....
I was wondering, has anyone worked on and succeeded in downloading the APK's from the Porche PCCM+ system to run in on the aftermarket android HU to access the porsche-specific functions?
does anyone with a PCCM+ feel like trying? I can probably help
example method: https://www.alphr.com/extract-apk-android/
thanks for all the dev and info!
The following 2 users liked this post by Belgian_Dude:
myw (03-29-2023), vokain (06-13-2023)
Old 03-29-2023, 08:46 AM
  #786
frenchtony
frenchtony's Avatar
Default steering wheel controls
Hi
Thanks for the detailed explanations.
Did you manage to resolve the problem with the right hand steering wheel controls? The rotating control does work with the supplied radio app but not with my preferred youtube music. Also I now have the remaining fuel display showing on the screen when I turn the unit on! So the CANBUS must be working.
Did you find any way to reallocate the existing button like car and nav to other functions?
Old 03-29-2023, 11:22 AM
  #787
myw
myw's Avatar
Originally Posted by frenchtony
Hi
1) did you go into the secret factory menu to set CANKEY
2) only after #1) above is done - then can you map all buttons (other then 2) in the steering wheel key app.
https://rennlist.com/forums/997-foru...l#post17544618
Old 03-29-2023, 11:23 AM
  #788
myw
myw's Avatar
the oem pccm+ android apk is available for download?
Originally Posted by Belgian_Dude
hi guys,
Old 03-29-2023, 11:54 AM
  #789
frenchtony
frenchtony's Avatar
can't find CANKEY, I have car model which is set at CAN Box type porsche /cayenne /CAN Box BG.XP, no other model
the setting original car agreement has an option CAN box upgrade
can't see any other option :-(
Old 03-29-2023, 12:04 PM
  #790
myw
myw's Avatar
do you have the high quality or low quality unit? which link did you buy from
they run different software.
also did you follow the exact instruction set in posted ?
Old 03-29-2023, 12:47 PM
  #791
frenchtony
frenchtony's Avatar
Thanks for the reply. I bought from Owtosin official store. I was the option 12, android 11 8 core CPU. Its not available for sale anymore!
I didn't follow the instruction set in posted , I'll try to find it.
Old 03-29-2023, 07:36 PM
  #792
myw
myw's Avatar
This isnt the right one i believe.
PX5 + PX6 + QCM processors with the higher end silver rear heatsink (similar to the Porsche pccm+) is the correct one.
if its gloss black or brown rear heatsink... it is the public/wholesale units with a completely different line of internal components model - none of my instructions, passwords, even wire harness stuff will work - as everything is different.
Old 03-29-2023, 08:50 PM
  #793
Graufuchs
Graufuchs's Avatar
Received 1,339 Likes on 495 Posts
Owtowsin Wholesale units: (Less Expensive Units)
Factory Pass Code: 3368 (allows you to change themes / Can Bus settings and some other options)
Android Auto Generic pass codes: https://android-headunits.com/pin-co...roid-headunit/
The following 2 users liked this post by Graufuchs:
myw (03-29-2023), scadams (08-23-2023)
Old 03-30-2023, 03:59 AM
  #794
frenchtony
frenchtony's Avatar
yes 3368 is the factory passcode for mine, its android 12. It has the black heatsink. Very pleased with it apart from the can bus keys on the right side.
Old 04-04-2023, 11:54 AM
  #795
TonD
TonD's Avatar
Hoping to find some help here. I ordered from Owtosin on AliExpress, trying to install over the past couple of days. Unfortunately, whatever I do, I can't seem to be getting any sound. I suspect the MOST fiber optic adapter is not wired correctly or not working. In fact, initially I did wire it wrong (used the thin wired going to the CAN box), but I rectified that now as per myw's suggestion in this thread (spliced black into thick black wire, yellow into thick yellow wire, and red (ACC+) into blue wire ANT wire. I verified that I have +12V between black and yellow, and between black and red. However, no sound. Nothing.
I actually have two MOST boxes (because I ordered systems for my 997 and 957, both with Bose), tried swapping them out but no difference. What are the chances of both being faulty, I'd think. So, I'm kind of at a loss. I read through all 53 pages of this thread over the past few days. Anyone has any idea what I might have missed or done wrong?
Also, when I disconnect the fiber optic (orange) connector from the MOST box with the system running, should I be seeing any red light/laser beams or anything. Because it's completely dark. By the way, if I put back my original PCM (which I now have), everything is working fine, so I don't currently suspect any fuses or broken optical wires or anything like that.
Edit: I think I might be on to something. I have two identical MOST boxes, saying "MOST-PC/ML V20160322" on a little white sticker. However, the two wiring harnesses are actually pinned differently! That doesn't make any sense to me. Can anyone confirm for me which would be correct? Looking into the connector, with the retaining clip on top, the one I have been using seems to be:
(left to right, top to bottom)
Yellow - (+12V/B+) red - black -white (audio RCA)
empty - red (ACC+) - black (ground) empty
The one I have unused in the box has the follow pinout (same order, orientation etc)
empty - red - black -white (audio RCA)
empty - red (ACC+) - black (ground) yellow (+12V/B+)
Quick Reply: Cheap Android Head Unit Review!
