LAPower bluetooth?
Old Mar 5, 2018 | 04:55 PM
  #106
Zettinger's Avatar
Zettinger
Originally Posted by TheBruce
Anybody have an issue with their USB cable no longer charging your iPhone? I just noticed mine wasn't charging the phone anymore. Not sure if my cable is bad or its something with the unit. On my Land Rover those cables last about a year before they break so I bought a higher quality one for the 997. I will have to pull the unit out to see what the issue is. Luckily with it under the dash its just one screw to get access to it.
No problem with charging but I had an issue yesterday.
I started the car and the unit didn't power up correctly, causing the PCM to say no Amplifier/CD changer detected.
Turned the car back off and 10 seconds back on and all was good.
I went this weekend on a trip and the unit worked great, except the first morning start mentioned above, the whole time.
Sound quality is great and phone charging worked like a charm.
Old Mar 6, 2018 | 12:58 AM
  #107
TheBruce's Avatar
TheBruce
Ive never had that error but ive had the PCM flake out a couple times and not recognize the bluetooth 2-3 times in 6 months. I haven't been able to pinpoint exactly why but think its a software glitch on the PCM side. Restarting the car or going to my bluetooth settings on the phone and manually connecting fixes it. Your issue sounds like a potential loose fiber optic cable. I would try pressing "148" simultaneously if it happens again. That will hard reboot the PCM. If the error goes away you can likely isolate the issue to being software related. If it doesn't its likely a hardware/bad connection issue.
Old Mar 6, 2018 | 03:21 AM
  #108
gary911's Avatar
gary911
Completed my install of LAPower Bluetooth in my 06 Cayman S today. Removed my CD changer from the frunk and just plugged the fibre optic cable into the bluetooth unit. Mounted unit to the bracket for CD changer with two zap straps. Wired the unit direct to be battery, using an inline fuse. Mounted the microphone on top of the steering column, just behind the factory location. Tool longer to remove and re-install the plastic covers in the frunk than to do the install. Turned on PCM and paired unit with my Samsung phone, and all works great, even the PCM phone buttons. Inserted in the bluetooth unit, a micro sd card with 6 folders, each with mp3 files in each and works it plays great. Shows on PCM as CD's 1 -6. Can also stream tunes from my phone to the unit. Totally happy and handsfree Time for start to finish about 90 minutes, including refreshment time before putting tools away. Now I get to help friend with his 997 install. Will supervise and keep hydrated.
Old Mar 7, 2018 | 04:20 PM
  #109
Zettinger's Avatar
Zettinger
the unit did the same thing yesterday. I drove for ~10 miles without any problem. stopped for 5 min to pick up my son.
When I started the 997 again, the PCM reported CD changer not functioning.
I tried your 148 trick what indeed rebooted the PCM but still the same.
Switched to FM radio what worked fine.
I stopped some where to test and restart of car fixed the unit again.
Since the fiber ring is not disconnected (Bose connected), It seems my LP1604 unit has once in a while start problems.
Old Mar 8, 2018 | 11:30 PM
  #110
SWO Daddy's Avatar
SWO Daddy
Am considering installing one of these but I am concerned as my 05 C2S does not have a cd changer. Looks like 91219 and Type_LT successfully installed and neither had a changer. My PCM is 2.1 (not 2.1a or 2.1b). Does anyone have another experience with unit to confidently say that the unit should work in my 911?
I'll also reach out to the vendor.
Old Mar 14, 2018 | 11:53 AM
  #111
sostick's Avatar
sostick
Default HELPPPP!
guys.... I'm going through the installation but I'm stuck.
I'm at the point where I test the system. The device doesn't switch on. no blue light and no signal. and the PCM says system error: navigation system, phone, amplifier, CD charger not available...
I changed fuse A8, which was Brocken... the outlet has energy... HELP!!!
Old Mar 14, 2018 | 12:15 PM
  #112
sostick's Avatar
sostick
I sorted the first issue about electricity. the red thingy didn't cut the cables... so I removed them, cut the cable myself as I will never use that socket...
but still no working as system error...
Old Mar 14, 2018 | 12:28 PM
  #113
sostick's Avatar
sostick
I discovered the big mistake I made. I looped the satnav and not the cd charger in the front trunk... any help?!?!?
Old Mar 14, 2018 | 12:35 PM
  #114
TheBruce's Avatar
TheBruce
Hopefully some other guys can assist. Fortunately or unfortunately mine was plug and play. The prior owner had an old Mobridge unit so I was able to use the existing wiring and it was plug and play.
Old Mar 14, 2018 | 01:15 PM
  #115
Zettinger's Avatar
Zettinger
I assume there is an problem with the fiber ring.
Reverse what you did and try the CD changer fiber connector to test if the LP1604 works.
Old Mar 14, 2018 | 03:31 PM
  #116
Zettinger's Avatar
Zettinger
The test above will help you to identify if the unit works.
To address your fiber I tried to use my paint skills to make it visible.
Here the OEM MOST ring.
MOST Fiber Ring with Bose Amp and CD changer
This is the way it has to look when you want to locate the unit in the foot well behind AC controls.
MOST fiber ring. LaPower Lp1604 in foot well and Fiber loop CD changer
Old Mar 14, 2018 | 03:36 PM
  #117
Zettinger's Avatar
Zettinger
LaPower to replace CD changer (test above) in Frunk
MOST fiber ring. LaPower LP1604 replace CD changer option
Hope that helps
Old Mar 14, 2018 | 11:49 PM
  #118
sostick's Avatar
sostick
Yes it does. I understand the concept now. I had to rebuild the car to get it operational today :-(
I’LL reverse what I have done and see if the unit start again and then make the test. And then try the loop again. I have another challenge that one fiber connector of the kit has broken. I’ll try to go to Porche and get a new cable... the beauty of the DIY!!! In Dubai!!!
Old Mar 15, 2018 | 12:23 AM
  #119
Zettinger's Avatar
Zettinger
you should have one spare connector since the LAPower set comes with two ends and the ring only requires one end.
Old Mar 15, 2018 | 12:49 AM
  #120
sostick's Avatar
sostick
I did not break the connector but the orange cable terminal. The wire came out of the plastic end. How did you set up the 4 pins at the bottom of the device?
