LAPower bluetooth?
Old 01-07-2018, 06:26 PM
  #76
myw
myw's Avatar
Originally Posted by Racetwin2
Did anyone of you have TranzIt Blu installed before? If so - what are the major differences? What is better?
I'm wondering the same thing - especially the sound quality.
Old 01-07-2018, 10:48 PM
  #77
TheBruce
TheBruce's Avatar
I didn't have it installed before. I had an old Mobridge unit. My understanding of Tranzit Blu is: a) it connects to the antenna jack, b) streams over a set FM station, c) requires installing a button to activate calls, and d) cant be controlled via the PCM. If this is correct the LaPower is way better. It connects directly into your fiber cable, so I assume better sound quality, and you control music and calls directly via factory PCM controls. You can view current songs and incoming calls via the regular PCM display and it activates the TEL menu so you can store quick dial numbers.
In short, its the same as the Dension 500BT at 1/5 the price.
Old 01-08-2018, 01:09 AM
  #78
lisnter
lisnter's Avatar
Default Yes - I had a Tranzit Blu
Hi. I had a TranzitBlu installed in my car for 2 years or so. See my post above but in a nutshell, the LAPower is far better. LAPower integrates directly into the PCM so I can answer calls through the PCM instead of through the phone or their little external button and the Bluetooth connection is re-established right away each time rather than requiring an explicit reconnection via the iPhone settings menu each time I got in the car.
Sound quality is irrelevant - it's a car, not Carnegie Hall. The sound is good enough, I can hear the caller clearly and they can hear me clearly.
I would recommend it over the TranzitBlu. The Tranzit works well enough but LAPower works better.
Old 02-13-2018, 06:58 AM
  #79
MikeHRC
3rd Gear
MikeHRC's Avatar
Hi guys,
Just a quick not to thank you all for all of the information in this thread - I installed my LAPower unit in my Boxster yesterday, all working very well, just needs a little tidying of the cables.
One quick question (probably aimed mainly at The Bruce), as per the instructions I connected to an unswitched power supply - I used the power supply in the passenger footwell. I'm just slightly concerned about the power drain, if I am reading this correctly it sounds as if I should be OK so long as I keep the car locked when not in use - is this correct?
Is there any reason why the unit could not be tapped into the PCM power supply so that it switches on / off with the PCM unit?? I know that's not what the instructions say, but ...
Cheers,
Mike
Old 02-13-2018, 11:45 AM
  #80
TheBruce
TheBruce's Avatar
Hi Mike - glad you like it. As for the instructions, I think the actual LaPower instructions recommend tapping the PCM power. I only tapped the Aux power cable because the prior owner had already tapped that cable with the old Mobridge unit. I was going to switch and tap the PCM power if my battery drain continued but once I started locking the door at night it solved the issue and no need.
Ive had mine now for a couple months now and works great. Definitely a required addition. I do find every now and again the PCM wont recognize the bluetooth module and you will see "not connected" on the PCM display. The fix is just to go into your iphone bluetooth settings and click "CarKit". It will say "not connected" but after clicking it will change to "connected" and you will be good to go.
Old 02-13-2018, 12:09 PM
  #81
MikeHRC
3rd Gear
MikeHRC's Avatar
Thanks Bruce,
The instructions that I received with mine (I'm in the UK, but I can't see why it should make a difference), say "Important Note: When you connect the power harness please make sure that you feed the LaPower device with +12V non-switched constant power". I'll just keep an eye on the battery and keep the doors locked - thanks.
I'll keep an eye out for th enot-connected messages.
Cheers,
Mike.
Old 02-13-2018, 03:23 PM
  #82
Ben Z
Ben Z's Avatar
Good to know there's another reasonable-cost option if my Tranzit fails again. I replaced it recently because it stopped wanting to pair with my phone after an iOS update. The replacement unit probably has newer firmware (previous one was from 2014), works good again. Connects right up every time I get in the car. Not sure why yours didn't.
Old 02-13-2018, 03:52 PM
  #83
MikeHRC
3rd Gear
MikeHRC's Avatar
Thanks Bruce - the instructions that I got with my LaPower unit say to use an non-switched supply, just curious really as I would have thought that having it turning on / off with the PCM unit makes sense.....
Thanks for the note about BT connection, I'll keep an eye out for that
Old 02-14-2018, 04:10 PM
  #84
myw
myw's Avatar
great review will keep in mind! my tranzit connects automatically the second i get into the car... never had a problem with that. and the songs + caller info also does indeed display on PCM via rds technology.
having no external button sounds great as well.
i would assume that the sound via a direct fibre optic connection would be better. i love my tranzitBlu and overall the sound quality is excellent for my needs, but every once in a while there will be a song or a phone call in which the high frequencies get a little raspy .... and if there is a long period of silence in a phone conversation or between music i will hear static noise.
Old 02-15-2018, 05:05 AM
  #85
colinallcars
colinallcars's Avatar
Doesn't anyone know installer in the Los Angeles area?
Thanks!!
Old 02-22-2018, 01:00 PM
  #86
Zettinger
Zettinger's Avatar
I'm glad I found this thread and the fact that I'm not the first one to install this product as a guinea pig.
Someone from Germany posted a German eBay link to this device on Facebook a few weeks ago and asked if there is some information or experience about this product.
No one had experience but I ordered it from an american eBay seller from NJ to test.
Google couldn't find anything with the model number LP1604 except the eBay add.
The device took a while to show up last evening and became from (eBay add) UNBRANDED to Mr12Volt printed on the unit.
I watched Dension install videos all evening and found this thread. I assume LaPower 1604 is LP1604PO (PO = Porsche)
Your reviews sound great and I'm now very excited to tackle that project tonight.
My initial thought was to locate the LP1604 next to the CD changer and not use the Microphone.
This thread, and Dension videos, made my plan change to the passenger foot well.
Just wondering, my 997 has a CD changer, BOSE and no factory Hands free BT.
I read before I need to splice the LP1604 in the fiber ring or can I replace the CD changer connection to the LP1604?
LaPower LP1604 Mr12Volt
Old 02-24-2018, 01:27 AM
  #87
Zettinger
Zettinger's Avatar
Update. I had a delay yesterday. The video I watched said the radio side screw is an 8mm.
Check i have that in my tools.
Nope it is a 7mm and couldn’t find one in my household, universal wrench was too wide, nut too long and had to buy today.
Today I installed the lp1604 and guess what.
My box is dead. No function, LED indicators are dead.
Initially i check my fiber splice and power connectors.
Verified power and wired it, to test, directly to the battery. Still dead and no indicators lid.
Just finished reversing all my install, reverse the fiber splice and wrote the seller an email to get replacement.
Old 02-24-2018, 11:02 AM
  #88
TheBruce
TheBruce's Avatar
Sounds like a bad unit but I would double check your quick splice connector. Mine didn’t power up at first and it’s because I hadn’t crimped the connectors enough. The metal guillotine thing should be flush with the plastic housing.
Old 02-24-2018, 11:16 AM
  #89
Ben Z
Ben Z's Avatar
Personally I'm not a fan of crimp connectors in general, but especially those guillotine splice connectors. I've always done all wiring with solder and heat-shrink tubing. Takes a little longer but never needs to go back in and redo it.
Old 02-24-2018, 01:50 PM
  #90
Zettinger
Zettinger's Avatar
thanks for the clues. The crimp connectors were my first thought as well and I put them all in but didn’t help.
To test the unit I wired them directly to the battery poles with blank cables and unit was still dead.
I think Bruce is correct and the unit is bad.
Quick Reply: LAPower bluetooth?
