LAPower bluetooth?
Old Feb 1, 2024 | 09:29 PM
  #751
gdonn7's Avatar
gdonn7
Welp whining sound is still there after doing the changing the ground from the passenger footwell negative port to the screw...
Old Feb 3, 2024 | 12:21 PM
  #752
RennKit-Dave's Avatar
RennKit-Dave
Former Vendor
Buzzing or Humming Noise
BTR-3
Issues:
1. There is a small issue where when I'm on a phone call there's a buzzing sound coming from the speakers. Same thing happens if I try to use iPhone voice control (Siri). Have you heard of anything like this before?
Resolution:
1. First confirm there is constant power to the BTR-3 Module (check with 12V DC tester) at the small connector that connects to the BTR-3.
2. Make sure the BTR-3 Module LEDs light up (Red power, Blue BT connected)
3. Make sure you can pair your phone with the BTR-3 Module (pair to CARKIT).
From factory:
1. Reset the BTR-3 MODULE.
a. Press the "Reset" button on the BTR-3 MODULE for a second then switch off the ignition. Wait for a couple of minutes and try again.
2. Test with another phone
a. Make sure it is not an issue with a particular phone.
3. Check the microphone and the jack on the BTR-3 MODULE
a. Take the microphone to another device, see if it causes buzzing;
b. Use another microphone on the BTR-3 MODULE, see if it causes buzzing;
c. This is to identify if the mic is causing the problem.
From a customer:
Through manipulation of the phone volume and car volume, I was able to eliminate the problem and I’ve been unable to reproduce it since.Also, take a look at these videos:
https://www.psaudio.com/ps-how/how-to-find-and-fix-hum/
Old Feb 4, 2024 | 09:25 PM
  #753
guppychao's Avatar
guppychao
The unit has an usb and extra aux ports. What have people used those for?
Can use the usb for charger for your phone. Anything else
what about the aux port
thanks. Just bought the unit and before I install wanted to know my options
Old Feb 4, 2024 | 10:58 PM
  #754
RennKit-Dave
Former Vendor
yes, the USB port can be used to charge a device. The USB and Aux are normally used to play content, instead of streaming with Bluetooth.
Old Apr 3, 2024 | 10:33 AM
  #755
gdonn7's Avatar
gdonn7
@RennKit-Dave Thanks! I'll try the reset
Edit: I see you mentioned the microphone, I did change mic's to the one that goes into the factory location, the buzzing did start around that time if memory serves me correct. I'll try removing the mic and see if that stops it too.
Old Jul 29, 2024 | 01:33 AM
  #756
ebingo's Avatar
ebingo
Having trouble displaying the song title and artist name. The song title is briefly displayed, before it reverts to Track 1. BTSTREAM is also displayed briefly before it reverts to CD1. Has anyone faced a similar issue?
Old Dec 8, 2024 | 01:47 PM
  #757
Yorik's Avatar
Yorik
I installed my Rennkit BTR-3PM / Mr12Volt and I've got it working. Music streams nicely and I've made a test call. However, I'm having the same issue that several others have had with an error message about the phone not being available every time I turn on the PCM.
I've read through this thread and there have been a few things thrown out as solutions, but no one has confirmed what they had to do in the end to get rid of it. What was the solution? And if it was that the phone had to be coded out via Durametric or Foxwell or other diagnostic software, can that be done with the fiber optic loop on the phone module or do the factory connections have to be reestablished.
BTW, all the dip switches on the Bluetooth module are in the off position. There is something in the directions about turning on dip 4 to bypass the hands-free unit. But it sounds like that disables the phone buttons on the PCM also. It wasn't clear.
Anyway, I'd really like to know what the solution to the error message is. Thanks.
Old Dec 8, 2024 | 03:14 PM
  #758
Yorik's Avatar
Yorik
Want to add that the steering wheel controls don't work either. I thought the volume and answer/hang up buttons are supposed to work with it.
And it would appear that my phone calls are only playing on the right audio channel. That I can live with as I rarely take calls while driving, but the "phone not available" error message stops the whole system from working once it pops up. Which it does just a short bit after the system turns on. It'll even pop up after my phone connects and I'm actually already streaming music. When it pops up, it stops the system from working until I clear it.
Old Dec 8, 2024 | 05:37 PM
  #759
Yorik's Avatar
Yorik
OK. So I went back to the beginning of this thread and re-read everything. Man, this thread is long. But I think I found the answer! I clearly missed it. Post #136 says he had to program out the phone module and then the error message cleared.
I have a Foxwell scanner. Does anyone know which menu item turns off the phone module in the PCM?
Old Dec 9, 2024 | 02:08 PM
  #760
Yorik's Avatar
Yorik
I was able to find the coding section for turning on/off the phone module in the Foxwell diagnostic scanner. If you're curious, it's in the Gateway section. I changed the setting to "not installed," but I still get the message. And the steering wheel controls still don't work (they did prior to installation). Does anyone know if you have to start the car for it to take effect? The car is winterized in the garage right now so that would have to wait. Can anyone help to shed some light on things?
Old Dec 30, 2024 | 02:59 PM
  #761
Yorik's Avatar
Yorik
I have finally gotten to the bottom of things with regard to the telephone error message. Hopefully, this will help someone in the same situation in the future.
There are two coding changes that have to be made. One is in the Gateway and the other is in the PCM control units. In the Gateway, follow the path Gateway => General codes => Required installed => Telephone and set the value to "not installed." The PCM path is PCM => General codes => MOST nominal configuration => Control unit 1,2,3, etc. Find the control unit that says Telephone and change the value to "not used."
No more error message.
Old Jan 28, 2025 | 04:29 AM
  #762
type987's Avatar
type987
Your steering wheel controls still don't work ?
Old Jan 28, 2025 | 08:59 AM
  #763
Yorik's Avatar
Yorik
The steering wheel controls do work now. I attribute the problem to running the battery down below acceptable voltage. When that happens, the car starts turning off control modules for safety. I did a vehicle handover procedure with PIWIS after charging the battery and everything worked.
Old Mar 17, 2025 | 01:45 PM
  #764
Oli_Box's Avatar
Oli_Box
Default CDR24/BOSE/NO CDC incompatible?
Originally Posted by speakerdesign
I know this is an old point but I'm wondering if you ever got your mr12volt adaptor working. I have a 2006 Boxster S with the CD-24 Bose radio and no CD changer. I have the unit installed but the car doesn't recognize it and I'm hoping that having the CD changer setting turned on in the cars software will fix it. Since we have the same setup I was hoping you got your working...
Thanks, Speakerdesign
Hi everyone,
Reviving an older one, it is my exact setup (I also have the CD changer preparation option, if that matters). S model with Bose, CDR24, no CDC and no phone. The unit (Rennkit BTR-3) is installed but not being detected by the head unit: pressing twice on CD shows "NO CD".
The BT unit is hooked to an external battery for testing, it was first hooked up to a switched power source and I wanted to rule that out, so it now has constant power. My phone is able to connect to it via Bluetooth and the blue LED lights up when I do so. I tried both possible FO loop orders by switching the FO cables from the long part to the short one, same behavior with both. The dip switches are currently set like this: down-down-up-up, I had also tried down-down-up-down. I believe the 4th one is for phone module.
I had gone to the dealership for them to program the CDC option, but that was before I had the constant power hooked up. Would I need to go activate it while the unit functions, or setting it up prior should be OK?
I bought the unit last year and have been trying many times to get it to work, but unless someone has a solution here, my conclusion would be that CDR24 with Bose but no CDC, even with CDC prep option, is incompatible.
Has anyone been able to use this with a similar setup?
