ATE Cayenne S Rotors for 996 GT3 - Where are they?!?!?
#212
Any updates? Are people still using mostly the brakeperformance ones? The guys that use the 350MM fronts, what do you use for rears?
Do 996 and 997.1 (steel brake) GT3's use the same front AND rear rotors?
#213
Part #'s are 226.37039 and 226.37040. They are ~$45 each from Amazon.
Fronts are not the same- I use Centric/Stoptech Cayenne rotors, 125.33090 and 125.33091.
-Larry
#214
Are you still running factory steel sized 330m rear disc or the PCCB sized 350mm?
Fronts are same 996GT2/GT2/CayenneS/997.1GT3
Rears if 350mm, can use 997TT/GT3/Panamera Turbo etc..
#215
I was interested in the Panamera slotted discs when Centric was introducing them, but haven't seen any pictures to see if similar to OE style. Could you take a few?
I installed a set of Centric slotted rotors on the back of my 6GT3 a few months ago. They cross-reference with Panamera rears.
-Larry
-Larry
#216
Links people links!
#217
-Larry
-Larry
Do you know if those same part numbers will work for 07 GT3 with steel brakes? I'm unclear if the 996 GT3 and my car use the same rear brake rotor. I think 997.1 steel brakes are 350mm front and 350mm rear, is it the same for 996 GT3?
#218
Yes...996 with 350mm discs are same discs as 997.1GT3
If you have PCCB calipers you have 350mm disc front and rear...if steel(red) calipers then you have 350f/330r mm discs...a spacer under rear caliper mounts can make them 350mm compatible as well.
Wow 45 a piece! Can't beat that.
#219
If that's true I can run these for fronts:
And these for rears?
Or are the rears above 350mm which are too big?
#220
996GT with factory steel/red caliper= 350mmF/330mmR
996 with PCCB/yellow caliper = 350mmF/350mmR
997.1GT3 with steel/red =350mmF/350mmR
Correction...was right the first time! lol I'm losing it...
Sorry are you referring to 996 or 997? I have red calipers and steel rotors on my 07 so I need 350MM fronts and 330MM rears?
If that's true I can run these for fronts: Amazon.com: StopTech 125.33090 Premium Brake Rotor: Automotive
And these for rears? Amazon.com: Centric 226.37039 Brake Rotor: Automotive
#221
#222
#223
#224
the 226.37039 and 226.37040(right/left handed) are 330mm diameter for lower-end Panamera's.
changing the last two numbers to 54 and 55 gets you 350mm from the PanaTT
Thanks, do you know if these rears are 330 or 350mm? Doesn't say on the Amazon page.
#225
About to pull the trigger just want to confirm these are the 4 part numbers I need for a 07 GT3 with steel brakes (350mm all 4 corners).
